Overclocked temps - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-09-2005, 11:48 AM   #1 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Overclocked temps
I have the Intel 2.4c chip that runs at 800 FSB.
I run it all the time overclocked to 2.88 GHz with no problems.
I was on Newegg's site earlier, and I see they have it dirt cheap right now.
Was reading the reviews of it, and many have been successful overclocking it to 3 GHz and above.
I decided to crank mine up in the BIOS for my Asus P4P800 motherboard to 3.12 GHz and recorded the temps at idle for both 2.88 and 3.12 GHz.
Intel 2.4 C 800 FSB chip on an Asus P4P800 mother board
Temps below are at an idle with no loads.
At 2.88 GHz:
CPU temp is 27c
System is 30c
CPU fan is 2700 RPM
Power fan is 2743 RPM
Chassis fan is 2812 RPM
At 3.12 GHz
CPU temp is 26c
System is 30c
CPU fan is 2721 RPM
Chassis fan is 2789 RPM
As you can see, the temps remained pretty much the same for both 2.88 and 3.12 GHz.
I tested the system further by firing up Halflife 2 multiplayer and played a game with a few others for 30 minutes.
Here are the results.
At 3.12 GHz
CPU temp is 30c
System is 34c
CPU fan is 2700 RPM
It creeped up a little bit, but nothing to be worried about.
This is with the stock Intel fan unit too on the CPU.
I could lower it further with a good aftermarket fan and Artic Silver paste compound.
Above temps are after playing the game.
That is a utility from Asus that works with my mobo, and you can also overclock the PCs CPU and memory right from Windows instead of the BIOS.
If anyone is looking to build a good gaming rig on the cheap right now, that is a very good price on the CPU, and I am sure you can still pick up the P4P800 mobo for a good price from Newegg too.
When I get my new case later this year, I was going to buy a 3.0 or 3.2 CPU, but I may just get the same one I have now and overclock it, and put the current CPU back into the old tower.
This way I will have to fast gaming rigs here.
The PIII 500 in the other room will not play the current crop of games out this year.
It is still good though for Unreal and Quake III.
Just thought I would pass along this info for someone thinking about building a gaming rig for low bucks.
Just add a good soundcard and graphics card, and you would have a great gaming rig.
Corey is offline
Old 01-09-2005, 01:01 PM   #2 (permalink)
wimpywade94's Avatar
thats the chip my other computer has, its overclocked to 2.8, ill have to try up to 3 gh
thanks for the info corey!
wade
__________________
86 runner, rebuilt motor, egr block off, headman header, 3"bl, 33x12.5 m/t's. Lots of work wanted to do. limited skills, funds, time and drive.
If you dont know where your going, anyplace will do.....
wimpywade94 is offline
Old 01-09-2005, 01:30 PM   #3 (permalink)
Staff
Corey's Avatar
You are welcome Wade.
I just checked the temps again, and they are low, just like above in the idle example for 3.12.
I am going to leave it at 3.12 this week and see how it goes.
I guess this 2.4c chip responds very well to overclocking according to the reviews at Newegg.
Corey is offline
Old 01-10-2005, 07:15 AM   #4 (permalink)
4Hummer's Avatar
My overclocked Cleron 1000 is running at 2.15 gig (A little more that double the speed) My CPU Runs at a max temp of 32. I have an artic fan on the CPU, a 5 1/4" bay fan, a PCI slot fan, 4 Case fans, And modded my power supply to have two fans in it aswell.
I have also upgragded the cooling fins on fan on the motherboard chipset's and video card, and added cooling fins to the memory sticks
My PC is a big wind tunnel
__________________
Michael
1991 4Runner 22RE.
CHOP
www.obsessiveoffroadclub.com
4Hummer is offline
Old 01-10-2005, 09:43 AM   #5 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
Corey -
Definitely get the Artic Silver. Makes a noticeable difference. I upgraded the processor in my laptop from a 1.6 to a 2.4, adding the Artic Silver while I went. My temps didn't change, which is pretty good for almost a gigahertz increase in processing power.
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Old 01-10-2005, 01:16 PM   #6 (permalink)
RED 85's Avatar
how do you over clock a cpu?
__________________
Brandi
You heard of the boy named Sue, Well I'm a man named Brandi!
'85 extra cab pick-up, Up on blocks waiting for time and money.
'85 4-runner with 3" lift, 33's, 4.88's, rear ARB (still trying to get air to it), Downey intake with K&N filter, some type of header, Camo Int.
RED 85 is offline
Old 01-10-2005, 02:19 PM   #7 (permalink)
Churnd's Avatar
http://www.hwupgrade.com/overclock/cpu/
__________________
-Chris
My Website
Churnd is offline
Old 01-10-2005, 03:32 PM   #8 (permalink)
Staff
Corey's Avatar
Check out my wind tunnel
That big dual fan setup blows right on all of the cards.
It added very little noise to the case too.
Chris, I will get some Artic Silver for sure.
Red, Asus mobos are the king of overclocking, and make it a cinch right from the BIOS, or from that utility as seen in the above pics in a few posts above.
I personaly OC it from the Asus Bios instead of that utility.
I have not even played around with overclocking my memory, doing just the CPU is enough and sometimes the GPU.
Corey is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Auto transmission operating temps 4mydogs 95.5-2004 Tacomas & 96-2002 4Runners 35 09-04-2007 09:11 AM
A340H temps snap-on 86-95 Trucks & 4Runners 81 10-14-2006 07:55 PM
3.4 temps w/s/c urd fuel mods? jrock 95.5-2004 Tacomas & 96-2002 4Runners 6 12-13-2005 10:10 PM
Plug temps with S/C? travelinman 95.5-2004 Tacomas & 96-2002 4Runners 2 01-07-2005 04:34 PM
Engine compartment temps vs PVC? ManyMods 95.5-2004 Tacomas & 96-2002 4Runners 3 01-30-2003 03:44 PM
2009 InternetBrands, Inc.
