| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
My computer is SHOCKING me
#2 (permalink) |
There are capacitors in the power supply that will hold power for quite a while, so you need to try and drain it. Turn off the computer, unplug it and then hold the power button down for a good 30 seconds. Then find the 110/220 slider switch on the power supply and switch it to 220, and then back to 110. Hold down the power button again for another 30 seconds, this should have completely drained the power supply. (btw - this process will very often make a power supply that appears to have failed work again, not to say that it fixes the problem, but it will get you around it for a while) Wait a while and see if you still get shocked. If there was a faulty part that was responsible for bad grounding and therefore shocking you, I'd guess it would be the power supply. If you're still getting shocked then check the grounding for your water cooling system and see if that's the culprit. Try another power supply if you have one you can borrow from another computer.
#3 (permalink) |
Thanks for the reply BlackFlag. I didnt think to switch it over to 220 when draining the capacitors. It was just recently I gave my buddy my old powersupply, and my server, although it has two, powersupply is uncompatible.
Still shocking me with the capacitors drained. btw |
#4 (permalink) |
So is there anything else that has power direct into the machine? Does the water cooling system have it's own power supply?
#5 (permalink) |
The shock is normal kind of like static electricity but you can keep shocking yourself if you want to
#6 (permalink) |
mine has always given off a slight shock, not to sure why it does it, but has never had a problem. *shrugs*
__________________
[-Chris-] 1988 X-Tra Cab 4x4. V6. Stripped to the frame. 1998 Chevy Chyenne Extended Cab, pretty much stock, except for a few cosmetics. |
| Tags |
| button, case, computer, grounding, locate, me, pc, power, problem, shocked, shocking, supply, touch, touched, unplug |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Shocking increase in cow abductions reported | BT17R | Off Topic Talk | 8 | 03-08-2006 09:33 AM |
| Shocking | Hyperlite | Off Topic Talk | 2 | 06-20-2004 08:42 PM |
| Shocking Question?? | PirateFins | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-26-2003 10:46 AM |
| Computer | maleko03 | Off Topic Talk | 3 | 09-27-2003 01:37 AM |
| shocking development | markshoreline | Off Road Trip Planning, Expeditions, Trips, & Events | 10 | 08-30-2002 06:37 PM |
