| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
linksys wireless router wrt54g w/speed booster
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#2 (permalink) |
heres what you can do.
plug the router directly into the laptop using an ethernet cable. Then go to 192.168.0.1 type in admin as the user name and admin as the password from there go to the wiresless tab, and then security, there you can configure the Network name (SSID), and security settings.
__________________
'95 4Runner SR5 130k 3.0 - Auto - 4WD - 4.88 Gears - Aisin Hubs - Downey Headers - Performance Cams - 2.25" CherryBomb Turbo - GY Wrangler RT/S 31x10.5x15 Sony CDX-310 - Polk dB401 - Sirius Hardwired - iPod Touch 32GB Finished putting engine in Apr-26-09, 108k |
#3 (permalink) |
If you have any questions post it here, or PM me. Ill be happy to help.
__________________
#4 (permalink) | |
Quote:
Sounds like you may need to reset it first and depending on the age you will have a different combination to Log in. The instructions for most of it is located here http://www.linksysbycisco.com/US/en/support/WRT54G I have one and I need to go to 192.168.1.1 (Depending on your version it will make a difference) I will be happy to help as well. Let us know how we can. Andy |
#5 (permalink) |
anything?
__________________
#6 (permalink) |
I search that 192.168.1.1 and it gets me to wikipedia but I can not get to that site to try to down load also I have wrt54g version 5 please help lol
__________________
#7 (permalink) |
Are you wired or wireless on the laptop right now?
Right click the status icon [2 flashing squares, or a square with ))) ]to the left of the clock and click Status, then click the Details tab. Tell us what the IP address's listed are.
__________________
#8 (permalink) |
Thats not showing up if you are talking about the reception gauge not even the icon that tells what the how much kp per second is there.
__________________
#9 (permalink) |
But are you currently wired or wireless? If wireless, get an ethernet cord and connect to it.
__________________
#10 (permalink) |
Yea I am running the cable from the comcast box right into the laptop if I do it the other way into the router it just don't work for some reason my computer crashed and this is the last issue that I know that I can't fix.
__________________
#11 (permalink) |
ohh I see.
Ok so connect the Ethernet cable from the Comcast box into the WAN port of the Router, then use another Ethernet cable and connect it to the Ethernet port in your laptop, and one of the four LAN ports on the router. Unplug the Comcast box, and router for 30 seconds. Right after you unplug them, restart your laptop. Now, through the wired side of the router you should be able to access the Internet. Now you can go to 192.168.0.1 (or 192.168.1.1) in the address bar. Now once you get to this screen the User field will be admin, or blank, and the password will be admin. From here, navigate to the Wireless set-up tab, you should see Security, select that and use WPA-Personal Use anything you like for example yotatech1. This is your wireless network password. Navigate to Configuration, and check you SSID (Wireless Network Name), I personally put the last name, and family. e.g. ToscanoFamily. Then on your laptop, view wireless networks, connect to yours, put your password in (the one we just created), and you should be all set. Should the issue arise that you can't find ANY wireless networks, or it gives you an error, make sure all wireless switches ar eturned on, and that it is enabled in the Network Connections, in the Control Panel (For WinXP). If all above is true and you still can't connect successfully, find an updated driver either from the laptop manufacturers website, or even the manufacturer it self (e.g. Atheros, Broadcom, Intel, ect.). A few more questions to clear the air (if it still doesn't work). What is the make and model of your laptop? Is the wireless card integrated (inside) or external (USB, or PCMIA port)? Hope that helps!
__________________
#12 (permalink) | |
Quote:
Andy |
| Tags |
| boost, booster, comcast, km, linksys, router, speed, speedbooster, turbo, turn, v6, wireless, works, wrt54g, wrt54gs |
