| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Interesting computer problem...
__________________
06 Subaru WRX |
#2 (permalink) |
oh and btw...I have a WD SE 80 Gig and a IMB 20 GIG.....the bios can see both of them and tells me the correct amount of space on them....
__________________
06 Subaru WRX |
#3 (permalink) |
Guest
To be honest that problem description does not fit into my head, so no diagnosis.
But, one bit of information that might be relevant is: XP boot process is aware on which IDE channel the boot drive is, it also knows how many partitions are on each drive. Changes to the order of anything aforementioned will prevent you to boot successfully.Your best bet is: take the drive without any data you want to keep, plug only that one in into primary IDE channel. Repartition it, install Windows. Once Windows is working, connect the second drive to the secondary IDE channel. From within Windows move all your files to the current system drive. Repartition the second drive. Done. |
#4 (permalink) |
I'm sorry let me try to describe this better of what is going on now....
I have to blank harddrives....Both have been unpartitioned....after unpartitioning C: windows refuses to use it. It wont install windows on it, it wont even try to partition in. The other one was unpartitioned and windows has formatted it but when trying to install windows on it, it hangs. Wont complete install, and is VERY slow, doing anything too it.
__________________
06 Subaru WRX |
#5 (permalink) |
Guest
When you are trying to install, is there only one drive in the system connected to primary and set as master?
Almost sounds like physical problems, i.e. bent pins or cables going bad. |
#6 (permalink) | |
Quote:
__________________
06 Subaru WRX |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Interesting electrical problem. | Popak2 | 84-85 Trucks & 4Runners | 5 | 10-29-2006 11:14 PM |
| Interesting Idle Problem | leiniesred | Maintenance & Repair Archives | 0 | 11-11-2005 07:33 AM |
| computer problem? | 85TurboRunner | Computer Talk | 3 | 05-12-2005 05:29 AM |
| Interesting Electrical problem | NorCalVP | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 09-18-2004 06:24 PM |
| Interesting A/C problem/observance... | rpeAMP | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-27-2004 09:41 PM |
