How to check memory settings in BIOS? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-03-2008, 09:36 AM   #1 (permalink)
BT17R's Avatar
I want to see memory timing and ECC settings in BIOS, but don't see it on the setup screen (F12 at boot) on my Dell desktop.
I'm replacing the OEM 2 Gb DDR2 800 ECC (it's a workstation) with 4 Gb DDR2 800 non-ECC (faster) to speed up hi-def video rendering. The new ram is 4-4-4-12, CAS 4, and I'd like to verify it's running as advertised.
Also, I'd like to memtest after install. Would that show the timing settings too?
Lastly, the OEM memory runs at 1.8V, the new sticks 2.0V. Is there a voltage setting somewhere I should tweak, or will the X38 mobo do it automatically?
TIA...
__________________
'07 FJ Cruiser TRD SE 6M/T
BT17R is offline
Old 08-03-2008, 01:44 PM   #2 (permalink)
Kinked's Avatar
hey,
i don't know if you can see the mem timing in the bios. but if you downloaded a a good bench mark program it should be in there.
__________________
91 4Runner <- 3.0, Auto, Alpine IDA-X001 Head Unit, Alpine 4" Front Spkrs, Alpine 6X9 rear Spkrs
93 4Runner <- 3.0, Auto, Alpine Head Unit
92 S-10 Blazer <- Selling
Kinked is offline
Old 08-03-2008, 02:42 PM   #3 (permalink)
89macrunner's Avatar
this depends on what mobo you have.
You won't notice much of a speed difference in the ram. I would keep the ECC ram just to avoid any hiccups in your rendering. Rendering is all about raw cpu power. you will get much bigger of a boost in speed from a new cpu then new ram for rendering.
if you have an intel mobo you probably cant bump the voltage to 2.0. if you arent overclocking there is plenty of ram that will run at 1.8v @ 800mhz. im running my ram at well over 950mhz on my desktop @ 1.8v
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles
Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008)
2006 Mazda3 GT
2000 TRD Tacoma..Bought back and crushed
1988 4Runner SR5 V6 5 speed..sold
89macrunner is offline
Old 08-03-2008, 05:33 PM   #4 (permalink)
BT17R's Avatar
I have the X38 mobo with a 3.0 Ghz dual-core. I got the X38 mobo with upgrading in mind, so when prices fall maybe I'll eventually get a quad core.
I'm looking at more memory since it's so cheap. I can get 4 Gb of DDR2 800 for $40, so I was thinking of replacing the ECC with it.
http://www.newegg.com/Product/Produc...82E16820227139
Do you know how to access BIOS memory settings on this mobo?
__________________
BT17R is offline
Old 08-04-2008, 01:38 AM   #5 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Bob, one more thing.
Which OS are you running?
XP does not utilize more than 2 GB, even if you add more.
Vista can see around 3 GB I believe, and if you run 64 bit Vista, it can see up to 8 GB I think.
This is why my new PC with XP I built I only built it with 2 GB.
My Vista Dell laptop is 32 bit with 2 GB of RAM, but I am bumping it to 3 GB later.
I think I was told since it is 32 bit it will not use 4 GB as it can not see all of it.
Corey is offline
Old 08-04-2008, 06:00 AM   #6 (permalink)
XP supports up to 4gb of ram and will use ALL of that ram if you are doing enough to support it.
the 64bit versions of vista should take as much ram as your mobo can support.
x38 is not the model of your motherboard, that is an intel chipset....usually pressing delete or f10 will bring up the bios during POST
__________________
2006 Mazda3 GT
Old 08-04-2008, 06:53 AM   #7 (permalink)
Team420's Avatar
^^Keep tapping delete while booting^^, dont be alarmed if it starts beeping, that just means it knows what you want, and its telling you to stop so it can finish loading...lol
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock.
It's becoming an addiction.
Team420 is offline
Old 08-04-2008, 07:04 AM   #8 (permalink)
Staff
Corey's Avatar
It gets conflicting since I have read several things in the past about it.
http://www.sharkyforums.com/showthread.php?t=292548
Corey is offline
Old 08-04-2008, 09:21 AM   #9 (permalink)
BT17R's Avatar
Corey, I'm running XP Pro. Awhile back, Dell tech support said what 89macrunner wrote, XP supports up to 4 Gb but will only show 3 Gb in Setup.
89mac, when you wrote "doing enough to support it", is there a setting that needs changing after installing the extra 2Gb? I'll try the Delete/F10 tip. Now I'm wonder what mobo is inside. Maybe it shows in BIOS.
Thanks all. Sounds like I should instead stay with the memory type onboard and get 2 Gb more (for $110 vs. $40 of 4 Gb non-ECC).
__________________
BT17R is offline
Old 08-04-2008, 10:07 AM   #10 (permalink)
Workhorse's Avatar
Send a message via AIM to Workhorse Send a message via MSN to Workhorse Send a message via Yahoo to Workhorse
If you ever want to see what your memory is running at (timing's and speed) under windows. I use..
http://www.cpuid.com/cpuz.php
Changing your memory timings / voltage is done in the bios and of course varies per MB.
Window's OS's memory limits
http://msdn.microsoft.com/en-us/library/aa366778.aspx
Just remember as stated above, even tho it may be able to see 4gb of ram it does not mean that it will allocate all 4gb to windows and applications.
explained here
http://msdn.microsoft.com/en-us/libr...73(VS.85).aspx
I'm sure all that information is just about as clear as mud now. gotta love Microsoft's memory confusion.
__________________
1993 Toyota 4-Runner v6 3.0 SR5 4x4 (My girlfriend's)
2004 Toyota Tacoma v6 SR5 X-Cab 4x4 (My Truck)
Old Truck: Stolen and ravaged :( boy do i miss her..
1987 Toyota 4x4 (IFS) Standard Cab Pickup 22r: cam/distributor/weber 38/offenhouser c series intake, 4 inch suspension lift, 32's, 4:88's, all the fun stuff :(
Workhorse is offline
Old 08-04-2008, 10:51 AM   #11 (permalink)
BT17R's Avatar
Good stuff Workhorse, thanks. CPUZ is just what I needed.
What's your opinion about my memory quest? The non-ECC in the newegg link is 4-4-4-12, CAS 4 compared to onboard ECC showing 6-6-6-18, CAS 6. Application is hi-def video rendering in Vegas Pro and DVD Architect.
__________________
BT17R is offline
Old 08-04-2008, 01:54 PM   #12 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
your not going to see much of a difference with those timings, also some mobos dwont even support swapping of non ecc and ecc . what are the rest of your specs. with a dell or any other factory built pc they lock the BIOS settings so the users cant change them.
__________________
Dan
95 4runner 3vze A/T
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 08-04-2008, 02:23 PM   #13 (permalink)
BT17R's Avatar
Yeah, good point. Given that the computer is new and under warranty, it might pay to stick with Dell-branded memory. Dell said I could wind up melting a memory socket when running aftermarket RAM, which I took with a grain of salt, but maybe there's something to it.
Specs are E6850 (3.0 Ghz, 1333 FSB, duo core), twin 320 Gb SATA 3 Gb/sec w/NCQ HDD's running non-RAID. I don't want to mess with RAID configs yet.
__________________
BT17R is offline
Old 08-04-2008, 03:35 PM   #14 (permalink)
DudeBud's Avatar
even more important what video card are you using? a decent card would help.
__________________
Dan
95 4runner 3vze A/T
37X13.00 boggers
DudeBud is offline
Old 08-04-2008, 03:42 PM   #15 (permalink)
BT17R's Avatar
Agreed, I have an nVidia XFX 8800 GTS, 512 Mb DDR3, awesome card!
Well, I talked with Dell again and they knocked 20% off so I ordered another two sticks of the identical memory (4 Gb total now) for $80 shipped.
__________________
BT17R is offline
Tags
bios, change, check, checking, dell, ecc, extra, find, memory, nc6000, ram, running, settings, size, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
EQ settings on HU callmej75 Vehicle Audio & Home Entertainment 6 01-16-2006 07:02 AM
BIOS, graphic arperture size Corey Off Topic Talk 14 02-01-2004 10:47 AM
Speaker settings Churnd Off Topic Talk 0 12-01-2003 07:05 PM
Memory Settings nixmax 95.5-2004 Tacomas & 96-2002 4Runners 2 04-15-2003 06:04 PM
Flashing a bios? Flash bios? Bob_98SR5 Off Topic Talk 6 01-22-2003 07:22 PM
2009 InternetBrands, Inc.
