Help with a process that is using WAY to much memory - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-03-2004, 01:46 PM   #1 (permalink)
I've got WIN XP with SP1. Now, I just upgraded my memory, but there is a process LSASS.EXE that is sucking up 141,568 KB of memory. That's quite a bit, especially considering it never use to do this before. I've checked microsoft's help center thing (that really helped ) and I've googled it and can't come up with a really good answer as to why it's using so much memory. Any help will be much appriciated.
oly884 is offline
Old 09-03-2004, 03:36 PM   #2 (permalink)
tulsa_97SR5's Avatar
Not sure what that process is, but you could always just try killing it & see if your PC crashes. Just checked my wifes XP machine, and whatever it is, she has it too. Only using 1,200 k on hers though. Hopefully someone else will know what it really is.
__________________
Brian
85 sr5, 5spd - back on the road, doing DD duty for now
86 2wd reg cab - future project
90 sr5, 97 - gone
tulsa_97SR5 is offline
Old 09-03-2004, 04:55 PM   #3 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Mine too is using 1,236.
You may have a virus.
http://www.iamnotageek.com/a/119-p1.php
Quote:
The lsass.exe which is from Microsoft is located in the c:\windows\System32 folder. there's a few viruses that have been found to run as lsass to hide from you.
Update your virus DATs and do a scan.
Corey is offline
Old 09-03-2004, 07:36 PM   #4 (permalink)
Ok, so mcafee showed no sign of an infection. I restarted my computor, and now explorer is running at 83,772 KB and LSASS is running at 36,588 KB. Something is going on here and I know it isn't right. I can't find any thing on the net as to the cause of this. Any other suggestions?
oly884 is offline
Old 09-03-2004, 07:42 PM   #5 (permalink)
Staff
Corey's Avatar
26,964 for my Exploder shell.
That is weird what is going on.
Sorry I do not have an answer.
Corey is offline
Old 09-03-2004, 07:55 PM   #6 (permalink)
calg3's Avatar
I found this on the web:
Today I'm going to explain to you guys what lsass is.
What is it?
Local Security Authentication Server
What does it do?
It generates the process responsible for authenticating users for the Winlogon service. This process is performed by using authentication packages such as the default Msgina.dll. If authentication is successful, Lsass generates the user's access token, which is used to launch the initial shell. Other processes that the user initiates inherit this token.
You will not be able to end this through task manager!
If yours is using that much memory, I would be concerned about a virus. My Win XP PC is using 00 for lsass.exe I use Zone Alarm, AdAware, McAfee VirusScan 7.1 and MS Firewall and don't have it running. I also remove MS File and Printer Sharing. Good luck.
__________________
2006 Subaru Outback, miss my 4Runner!
2006 Mazda3, zoom, zoom...
Look at my previous truck(s) in the Yotatech gallery:
http://yotatech.com/showthread.php?t=42494
calg3 is offline
Old 09-04-2004, 05:14 AM   #7 (permalink)
MvCrash's Avatar
Greetings,
Sounds like the "Sasser" worm might be your problem. Go to your virus scanner support and download the instructions on removal. There is a tool I believe. Then boot into safe mode without net support (no authentication) and have at it.
My opinion, take your valuables off, repartition, reformat, reinstall.
FYI...http://securityresponse.symantec.com...oval.tool.html
MV
__________________
MvCrash
2005 Rav4L Stock for now
2003 Mustang Mach 1, 4.6 DOHC V8. Cold air intake,magnaflow cross over and cat back, Custom tune by Predator
SOLD:2001 Tacoma XCab, Michelin LTX, AmeraGuard Spray in Liner, Access Roll-Up Tonneau Cover, Synthetic Oils
MvCrash is offline
Old 09-04-2004, 10:05 AM   #8 (permalink)
Staff
Yoda's Avatar
My lsass is 1,480 k
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 09-04-2004, 11:15 AM   #9 (permalink)
Staff
Yoda's Avatar
This inspired me to run a scan on my computer. Had a trojan horse lurking in one of my son's folders. McAffee took it out.
He hasn't used my computer in months, and previous scans had not shown it!
__________________
David
TLCA 14788
Yoda is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Starting the process of the SAS... 4Runner92sr5 Solid Axle Swaps, All Years 143 04-12-2008 12:53 PM
In the process of bleeding brakes and keep getting bubbles... UNR.Grad 95.5-2004 Tacomas & 96-2002 4Runners 13 06-03-2007 10:04 PM
Invention Process iGGz Off Topic Talk 29 04-25-2007 04:40 PM
Job interview process... Now what do I do? SLC Punk Off Topic Talk 6 11-04-2004 08:11 AM
Anti-rustification process has begun! Plays_with_Toys 95.5-2004 Tacomas & 96-2002 4Runners 1 10-28-2003 08:50 AM
2009 InternetBrands, Inc.
