| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Fdisk??
__________________
01 SAS Tacoma Double Cab. |
#2 (permalink) |
dont need to.
dell ships full version of windows. boot from CD. when prompted, format the HD using NTFS. then continue with installing the OS from scratch...
__________________
leo d. stock 90 4runner |
#3 (permalink) |
ya like ldivinag said....just put in your XP disk and boot from CD-ROM....start the install process and it will ask if you want to format....and like also mentioned use the NTFS format...its faster... good luck
__________________
06 Subaru WRX |
#4 (permalink) |
You might need to use fdisk and delete ALL of the partitions, then let the restore disk create a new one using the whole disk. Make sure to use NTFS and not FAT.
#5 (permalink) |
Did you try system restore first? If so and it didn't work follow the above mentioned instructions, that works well.
__________________
Brad Work is for those who don't know how to plunder!! 92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money! 04 F150 FX4 SuperCrew |
#6 (permalink) |
The XP setup will allow you to create and delete partitions all day long, so you only need to use it.
__________________
DREAD 2004 TRD SR5 Double-cab Tacoma Toyo Open Country M/T 265/75/16 Fabtech 3.5" lift Snugtop XTR Shell http://www.wattora.com http://www.genehobbs.com |
