Endless bootup loop - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-08-2006, 09:49 AM   #1 (permalink)
PirateFins's Avatar
Send a message via AIM to PirateFins Send a message via Yahoo to PirateFins
Endless bootup loop
Hey guys,
Thought I would run this by the mind power that is Yota"PC"Tech. I'm fairly competent when it comes to PC troubleshooting but just wanted to check myself before I advise someone to spend money.
A coworker gave me their PC to look at saying it "doesn't work" (you all know how much info they can give you). I take it home hook it up, it starts up fine runs thru the BIOS checks. Then I get the Windows was improperly shutdown last time, would you like to start from last know good config or normal mode or yadda yadda. I choose safe mode as I still have no idea as to what is wrong with it. Windows starts to load and then after a bit blue screen with some sort of error message and the system restarts. This happens no matter which mode I choose normal, safe, last know config. Same thing gets thru the Windows XP splash screen, the num lock/caps lock/scroll lock all flash like its going to start and then blue screen and imediate reboot. The time frame between the bluescreen error message and reboot is a nano-second and I cannot for the life of me read what it is saying or stop it to read what it is saying. I did make out the words "bad physical memory" in with a buch of other text.
So this brings me to my diagnosis. Would anyone that might have experienced something like this say the RAM chip has gone bad and needs to be replaced? I am thinking it is not passing the physical memory test and that is causing the reboot. It only has one chip in it and I don't have any of that type lying around to swap out and test with.
It's an EMachines T1840
Intel Celeron 1.8GHz processor
128MB DDR RAM PC2100 266mhz
Win XP Home
I tried putting in the system restore disks that came with the system but all that wants to do is format the HD and start fresh, there are no diagnosis tools on it.
Like I said it's not mine and they want to spend as little as possible to get it back running again. So a new PC wasn't the answer they liked when I told them that the first time. Heee Heee
Thanks
__________________
Brad
Work is for those who don't know how to plunder!!
Quote:
Originally Posted by habanero View Post
I'd experience an O so big it'd show up on the richter scale.
92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money!
04 F150 FX4 SuperCrew
PirateFins is offline
Old 02-08-2006, 09:58 AM   #2 (permalink)
cootees's Avatar
Send a message via AIM to cootees
That could be a wide range of things. For some reason microsoft likes to use the "bad physical memory" message on just about any blue screen error code. It sounds like trial and error may be the best thing to do in this circumstance.
For what it's worth. What it sounds like to me is that there is an overheating problem with the way it is rebooting so quickly.
__________________
-- '90 4Runner 2Dr
3.0 / sas /OME 860 coils / rear e-locker / 32's/ MC Rear bumper / TG Sliders / surco basket / cobra 18 wxstII / ISR / Magnaflow exhaust
cootees is offline
Old 02-08-2006, 10:10 AM   #3 (permalink)
PirateFins's Avatar
"Might" be able to rule out the overheating. It did it from a fresh start after it had been sitting in my garage overnight which is around 40*. I did make sure I cleaned it out heatsinks included and had the cover off to verify all fans were running includding the chip fan. When I looked at the BIOS the CPU temp didn't look high (don't remember the exact number, but didn't raise any flags). But I won't rule it out that is why I said "might". So how would I test for over heating? Thanks by the way.
__________________
Brad
Old 02-08-2006, 10:38 AM   #4 (permalink)
Epic Ed's Avatar
I'd start by swapping out another RAM chip. If that doesn't solve the problem, start disconnecting devices from the board, particularly any "new" device they may have just installed. Reboot after each device is disconnected to narrow down the problem. Reload the OS if nothing solves the problem.
Ed
__________________
'95 4Runner|32x11.5 BFG TA KOs|Hi-flow Cat|Dynomax muffler; 2.25" exhaust| Downey Headers|4.88 gears |Detroit EZ locker |Detroit TruTrack|BJ spacers|Downey HD coils|2" rear spring spacers|Rancho RS9000X/RS5000s|WARN hubs|TJM T15
Epic Ed is offline
Old 02-08-2006, 11:41 AM   #5 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
What I would do in this order:
  1. Run Memtest86
  2. Find out what kinda hard drive it is and run the manufacturers diags.
  3. Boot to the Windows install CD if you have it, and from recovery console run fixboot.
  4. Also from recovery console, run scandisk /r.
  5. Do a repair install
  6. Worst case scenario, backup files and reformat
Obviously if one repairs the problem, stop there. Most of this stuff is tailored towards Windows XP, but you get the general idea. If you can't use his disks, use your own assuming you have the same OS. Might even be able to use a different OS, but I haven't tried it.
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Old 02-08-2006, 11:43 AM   #6 (permalink)
Send a message via AIM to Localmotion
Quote:
  1. Run Memtest86
excellent
Localmotion is offline
Old 02-08-2006, 12:16 PM   #7 (permalink)
PirateFins's Avatar
  1. Run Memtest86
Yes I agree excellent, I was just at another "PC" site and downloaded memtest from a post there and linked myself back to the diagnostics page they have for the HD mfg's. (great minds think alike). Why did I need to visit there to begin with? lol
I have their (her) recovery disks with the windows files and drivers but they are hidden in it and it is crap. No options for repair or diagnostics/recovery console. Pop it in all you get is "welcome to the Emachines recovery center. !Warning this will format the hard drive and restore the system to its original configuration!" I pulled up the cd dir in dos and there wasn't anything on it but "restore.exe". What kind of crap is that?
I am running Win Media Center 2005 on my systems and have tried in the past to use the restore media in a XP home system (have not tried in a Pro) and it doesn't work. Just to let you know, it will give you an error message of "invalid operating configuration files".
I'll run those things tonight and try some others and let you know. Thanks for the help
__________________
Brad
Old 02-08-2006, 12:36 PM   #8 (permalink)
cootees's Avatar
Quote:
Well, a cold boot will help it some unless it's the cpu thats overheating. The cpu will overheat in no time. Easiest way to check them is with a digital thermometer. If you do not have one then the bios should be able to give you pretty good readings or you can leave the case open and have a large fan blowing directly in it.
You may also want to consider trying a boot disk to see if you can boot into safe mode off of the disk. If these don't work or churnd's list of 1-5. Then format.
__________________
-- '90 4Runner 2Dr
cootees is offline
Old 02-08-2006, 12:55 PM   #9 (permalink)
Buck01's Avatar
could also try swaping your harddrive into the pc...would let you know if it is th OS or hardware related.
__________________
94 Toyota Truck 4x4 22RE, 5 Speed 175,000
MOD's include High performance Head with bigger valves and cam, LC engineering Header and complete exhaust kit.
I have upgraded headlights with the wiring harrness and Hella H4 allweather bulbs.
lift shackels in the rear
3 inch BL
Buck01 is offline
Old 02-08-2006, 02:22 PM   #10 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
I figure you mean "swap the hardrive into ANOTHER pc...".
The problem with that is Windows XP will throw a halt when it sees that the IDE controller is different, BOOT probably won't get far enough to fail in the same way it is now.
Chris has the right steps at this point.
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 02-08-2006, 03:04 PM   #11 (permalink)
Churnd's Avatar
Valuable info on the Recovery console:
http://support.microsoft.com/?kbid=307654
Apparently, you can make the 6 XP boot floppies and use the first bootable floppy to run XP's recovery console:
Quote:
Originally Posted by Microsoft
If you cannot start your computer, you can run the Recovery Console from the Microsoft Windows XP startup disks or the Windows XP CD-ROM. This article describes how to perform this task.
After Windows XP is installed on your computer, to start the computer and use the Recovery Console you require the Windows XP startup disks or the Windows XP CD-ROM.
For more information about how to create Startup disks for Windows XP (they are not included with Windows XP), click the following article number to view the article in the Microsoft Knowledge Base:
310994 (http://support.microsoft.com/kb/310994/) Obtaining Windows XP Setup boot disks
Boot Floppies
I haven't tried it, but it's worth a shot.
__________________
-Chris
My Website
Churnd is offline
Old 02-08-2006, 03:23 PM   #12 (permalink)
Sponsoring Member
midiwall's Avatar
There's also the Ultimate Boot CD for Windows:
http://www.ubcd4win.com/
It's saved my butt a couple of times. It's a bit of work to build it, but it's well worth the time.
__________________
~ Mark
midiwall is offline
Old 02-09-2006, 03:33 PM   #13 (permalink)
PirateFins's Avatar
Just wanted to say thanks for the help guys. I ran both mem test and the "sea tools" utility for the HDD. Both turned out to be bad. Mem test had 10 failures in the first 6 test and the HDD utility found corrupt/bad sectors and also reported instability with the drive itself. The HDD utility also has a built in memory testor and the RAM failed that one also. So she went out today and bought a new HDD and our IS Dept gave her a 1gig stick to use they had.
On a side note once I get all of this done. "Where can I find out/ how do I" create a bootable recovery Windows CD for her, instead of the junk "format all" one that is with her system. This is not for me this is only for her (ok it is for me because she will ask me to fix it the next time something happens. lol), I was going to create it and put it inside of her PC case so it can't get "lost".
__________________
Brad
Old 02-09-2006, 05:34 PM   #14 (permalink)
Sponsoring Member
midiwall's Avatar
Cool to know you got it worked out!
Well, technically, you could copy an Windows XP Home CD and give it to her since she has a license for the OS. But... there's a sticky in here that may become an issue.
I THINK MS still runs the licensing such that there are different terms on an OEM license versus a full license. If that's still true, then she's not "allowed" to have a straight CD, only the "format & reload" thing that came with the box. The marketing behind this is that it greatly reduces the license cost to the OEM.
So... _legally_ I don't think you can do anything for her. If you go down the "technically" route, then you'd have to extract the XP Home license number that's used on the machine now - and I'm not quite sure how to do that. Chris may know. But (geez... ANOTHER "but"!), that license number may be locked to an OEM install and may not work with a straight XP Home install. In fact, I'd just about bet on that being the case.
Fun huh?
Given how cheap hardrives are these days, it may just be best to buy a new drive, load the box with the restore CD, image the install drive to the new one, then use the new one as a "known good". If you do that, say, once a month, then you end up with a "boot & go" copy of the machine.
__________________
~ Mark
midiwall is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
ECU doesn't go into Open Loop! TrackRunner 95.5-2004 Tacomas & 96-2002 4Runners 37 12-09-2007 07:59 PM
arghh 295's and endless rubbing... KyleT 95.5-2004 Tacomas & 96-2002 4Runners 10 12-11-2006 03:12 PM
More endless suspension questions FJ40Josh 95.5-2004 Tacomas & 96-2002 4Runners 6 11-27-2006 04:47 PM
4runner breather loop? Lone4runner 95.5-2004 Tacomas & 96-2002 4Runners 1 05-31-2006 04:41 AM
Nipple Creek Loop in CO? Tacotex Off Topic Talk 4 03-10-2005 02:07 AM
2009 InternetBrands, Inc.
