99 4runner sat idle for a couple months. now it won't start. cranks over fine. i can spray alittle starting fluid past the thottle body and it runs. can't here the fuel pump run. i get power to the pump relay when i stick the key in the ignition. on the load and control side of the relay. a ground, from the computer, on the control side should activate the pump relay. so the computer is not turning the pump on. shouldn't the pump run for at least a second when the key is turned on? i even jumpered the relay to get the pump to run. with the pump on, motor still won't start.
This ad is not displayed to registered members. Register your free account today and become a member on Yotatech!
