DVD Shrink Users - Please Help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-10-2004, 09:16 PM   #1 (permalink)
yoda-g2's Avatar
Question DVD Shrink Users - Please Help
Hey guys I'm new to the DVD burning world. I have an NEC ND-2500A firmware 1.07, and I'm using Taiyo Yuden DVD-R's.
My problem is that after I finish my burn and use Nero DVD speed to check the disk and it comes up with read errors, and the test fails. When I put the disk in my TV top player it goes through all the chapters just fine, but I don't have time to sit down and watch every copy all the way through just to make sure. Has anyone else experienced this?
I'm wading through all the tech talk over at cdfreaks.com, and I get the impression that this isn't normal. Instead of being the "nube" on that forum I figured I'd see if anyone over here has some experience with this stuff.
Thanks!
__________________
The Money Pit:
'96 FZJ80 - Locked | Safari Turbo w/ Intercooler | Unichip | 3" Exhaust | IPT VB | OME 3" Lift | ARB & Kaymar | Winch | DBA Slotted X-Drilled Rotors | Aussie Drawers | HID's | BFG AT's...
'78 FJ40
- Finally got my Mustard Baby!!! - Resto Project...
Clicky for Pics!
yoda-g2 is offline
Old 08-11-2004, 04:37 AM   #2 (permalink)
4xJedi's Avatar
I don't ever check the burn after. I'm using an NEC 1300A with Shrink 3.0, (did'nt like 3.1) with Nero 6. It works everytime. Sometimes they won't read on my pc but always on my Panasonic dvd player. One weird thing is most wouldn't work on my Kenwood dvd changer so I swapped it out to the Panasonic. How much are you compressing. I have a 55" tv so I try not to compress as much, I'll still the extras and bring the menu quality down. You're not using dual layer media yet are you? That' spendy right now.
To answer you question, I have not seen that problem. What version of shrink are you on?
__________________
'86 Runner, 4"SAS, 5.29's, 30 spline Longs, locked frt/rr, dual cases w/4.7's, Twinstick, LCE header, K&N, Engnbldr cam, Can-Back, Armor by me.
4xJedi is offline
Old 08-11-2004, 07:43 AM   #3 (permalink)
WT
WT's Avatar
Thanks!
I would suggest 2 things first try another brand of DVD-R and check the drive manufacture for firmware updates, usually that fixes alot fo burn problems.. Maybe try to burn slower on current DVD's too.
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2|
WT is offline
Old 08-28-2004, 09:45 AM   #4 (permalink)
yoda-g2's Avatar
Thanks guys, I got all the latest versions of everything, and it did actually turn out that the first batch just happened to have defects, the second brand was just poor quality (got 'em for free what do you expect) and the third batch has worked flawlessly. So now I'm up and burning like a madman .
__________________
The Money Pit:
'78 FJ40
Clicky for Pics!
yoda-g2 is offline
Old 08-28-2004, 10:16 AM   #5 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Cool.
I only use Memorex or Fuji DVD+R media.
Never had a snafu with the Memorex discs.
And I like how DVD Shrink uses the Nero plug-in so you do not even have to fire up Nero to burn the video files to the DVD blank.
Corey is offline
Old 08-28-2004, 12:39 PM   #6 (permalink)
yoda-g2's Avatar
Quote:
Originally Posted by Corey
Cool.
Yeah that is a nice option. Just curious Corey do you ever actually use DVD Decrypter? Does it rip the DVD better, or is that just for if you want to dump them to your hard drive for a later. I always just use Shrink, and even as low as 60% compression my movies play perfectly.
FYI the Fuji -R's at Best Buy are by far the best, I learned over at cdfreaks.com that the trick to buying locally is to only buy discs made in Japan. That gives you a great chance that thery are Taiyo Yuden, which are about the best quality disc around. If not them, most of the high end discs come out of Japan.
__________________
The Money Pit:
'78 FJ40
Clicky for Pics!
yoda-g2 is offline
Old 08-28-2004, 01:38 PM   #7 (permalink)
Staff
Corey's Avatar
I have never heard of DVD Decrypter.
Is it part of Nero or Shrink?
I just use Shrink the way it comes, and sometimes I do have to deselect a region if it tries to set one for me after it tells me the disc was encoded that way.
Other than that, never had a problem with the Shrink.
Corey is offline
Old 08-28-2004, 01:49 PM   #8 (permalink)
jrallan26's Avatar
I have never had a problem with DVD shrink. Are there any other good programs such as "Shrink"?
__________________
My Profile
jrallan26 is online now
Old 08-28-2004, 03:00 PM   #9 (permalink)
BT17R's Avatar
Here's an online media source:
http://www.shop4tech.com/user.htm?go...rg=taiyo_yuden
I've also read to never use a paper label on any CD or DVD. Apparently they can vibrate and jam unless perfectly placed.
__________________
'07 FJ Cruiser TRD SE 6M/T
BT17R is offline
Old 08-28-2004, 04:01 PM   #10 (permalink)
jrallan26's Avatar
sharpie okay?
__________________
My Profile
Old 08-28-2004, 05:56 PM   #11 (permalink)
BT17R's Avatar
Quote:
Originally Posted by jrallan26
sharpie okay?
According to my friend who makes his living producing special interest DVD's, yes, that's the quick, easy and reliable way for casual home use. Although I think he called it something besides a sharpie. He has a type of printer that prints directly on the disc and said that's the foolproof way.
__________________
BT17R is offline
Old 08-28-2004, 07:00 PM   #12 (permalink)
95_4X4Runner's Avatar
I have been using Ritek G04's (DVD-R's) and have never had a problem.
One thing I recently noticed, on my desktop, Shrink works great, but with my new laptop, I have to use DVD Decrypt to rip it to the HD, then Shrink to burn it, which adds an extra 20 mins or so. Anyone know how to get rid of the "I/O Error...Copy Protection" that I get with the laptop?
95_4X4Runner is offline
Old 09-01-2004, 09:46 AM   #13 (permalink)
XtremeOff-Road's Avatar
I have been using Fuji Silver / White Tops...never have had one coaster!!
I use an Epson printer and print directly to the disk as well
Mike
XtremeOff-Road is offline
Old 09-01-2004, 05:31 PM   #14 (permalink)
Krash's Avatar
Send a message via ICQ to Krash Send a message via AIM to Krash Send a message via Yahoo to Krash
Arrrrgh. Now I want a Dvd burner even more, just two more paychecks Anywho, Dvd Decrypter workes pretty good for me to take my dvds with me on my laptop without bringing the disks. Just rip the iso then mount it as a virtual drive using daemon tools. Pretty quick too, only took about 30 mins.
About the writing on the dvds, I came across this a few months ago: http://www.videohelp.com/forum/userguides/179510.php Haven't gotten around to being bored enough to make one of my own, maybe will here soon. Figured you guys might be interested.
__________________
1990 Ext. Cab 22re 5speed 4wd SOLD
Krash is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Mac users... WolfpackTLC Off Topic Talk 3 01-15-2005 05:07 PM
DVD Shrink Users READ! Churnd Computer Talk 2 11-22-2004 02:16 PM
Comcast users Corey Computer Talk 7 11-20-2004 08:09 AM
DVD shrink jrallan26 Computer Talk 2 07-22-2004 12:52 PM
2009 InternetBrands, Inc.
