Dual monitors - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-23-2004, 04:54 PM   #1 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Dual monitor help.
Anyone running dual monitors? I've been wondering if I can run duals off of a laptop (probably 18's)? I plan to be doing alot of CAD work and will get a decent laptop that can handle the horsepower needs. More screen real estate will definitely help since I usually need multiple windows open (catalogs, specs, drawings) all simultaneously.
Are the new flat monitors USB these days? I'm using a 15" LCD now and will not go back to CRT's!
Anyone have any experience in this area?
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 01-23-2004, 05:11 PM   #2 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
I am not yet, but I have been tempted to bring the 19" from the other PC into my room and hook it up.
My vid card and XP supports two of them.
That would be cool.
Corey is offline
Old 01-23-2004, 05:15 PM   #3 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
using a dual monitor at work
running a laptop (15") and a lcd (17") which helps me motor through more coding....
Good Times is offline
Old 01-23-2004, 07:01 PM   #4 (permalink)
WT
WT's Avatar
Re: Dual monitor help.
Most the laptops I seen that are fairly new will allow you to hook up an external monitor or LCD and the have the display show the same things on both or you can turn on what XP calls in the driver section I think it is can't remember of the top of my head but its just a check box to turn expand or something like that and you can have more desktop space. Just got to get used to moving your mouse across 2 monitors.
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2|
WT is offline
Old 01-23-2004, 07:05 PM   #5 (permalink)
Cebby's Avatar
What I want to do is have two separate 18" LCD's (aside from the built in which I'll disable) and have the laptop in a dock, then also use separate keyboard/mouse. I won't be lugging the laptop around alot, but I want to have the ability to take it along occasionally.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 01-23-2004, 07:47 PM   #6 (permalink)
Shane's Avatar
Send a message via AIM to Shane
Depends on the laptop and dock. The larger Dell docking stations (not the "port replicators") can take a PCI card so you can definitely get a dual-head card. Careful though as I've found the C series isn't able to power a hot card, not sure if they've fixed that issue in the new D series yet. Otherwise you're stuck with the laptop's LCD for one of the screens. It will work though, I use it all the time.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!"
Shane is offline
Old 01-24-2004, 04:08 PM   #7 (permalink)
I know running duals with a regular PC just requires a cheap vid card to be dropped in to replace the stock one. I run 3 18's side by side by side at work, and that's a lot trickier - it took our IT guys a few tries to get the software to do it. But 2 is easy...
__________________
2003 SR5 V6 4WD. Dark blue. Demello square sliders. Used to be waiting on lift options, now just procrastinating. Also I own a 2006 White 2wd (ugh) Sequoia (wife's truck).
Hannerhan is offline
Old 04-18-2006, 09:00 AM   #8 (permalink)
MNBOY's Avatar
I'm trying new things so I actually did a search and am dredging up an old post.
I was just given a Sony Vaio laptop that I am going to use for running navigation software on our boat, and possibly mapping software in the truck. The nav software has three different windows of information, which turn into micro-windows on the small screen. The Vaio has a great little screen, but the important word there is little. I would like to mount a 15" lcd screen in the boat, and use both the laptop screen and the 15", not as a repeater but to expand the desktop. That way I could have at least one of the nav windows running full screen. I'm running Xp pro and understand that it can handle this, but I think I also need a card. Can someone point me to the cheapest decent solution for this. Thanks.
__________________
____________________
Greg
93 4x4 pickup
MNBOY is offline
Old 04-18-2006, 09:05 AM   #9 (permalink)
ac808m's Avatar
Just hook it up and cross your fingers. Well, not that easy. Do a search for drivers. If you cannot find drivers for dual-display then your card probably cannot handle it. Vaio #$%&@ drivers are "fun." Once you enable the external display it should pop up on both screens. You will probably have to install a few drivers to find one that works. I would try the oldest version on Sony's site and work up from there (older>newer till it crashes). If it does crash. Reboot w/ F8>VGA mode and install a newer version.
__________________
-Aaron
1998 Tacoma Limited XtraCab 4x4 | De-badged TRD | 3.4L Auto | Factory E-lock & Moonroof | 882 2.5" OME Lift | 17" Enkei RTS Rims | Brembo Slotted Rotors | Slee Brake Lines | K&N Filter w/Deck Plate | Custom 654 Weatherguard Box | Stubbs Sliders | LineX-ed Bed & Sliders | Kenwood KDC-MPV6022 | OmniFi | JL 250/1 Amp | JL 8" w/Hidden Box
ac808m is offline
Old 04-18-2006, 09:23 AM   #10 (permalink)
turboale's Avatar
Send a message via AIM to turboale
Good luck finding a laptop that will support dual monitors aside from the connected one. I have yet to find one, but I haven't really been looking either. Do you really need all that power with you at all times? Why not get a desktop, that will be able to do the job better in the first place, and get either a used or base model laptop? A word to the wise, having a super high power laptop will be heavy, bulky, have horrible battery life, and they tend to run really hot. My buddy just had a monster laptop and it actually caught fire!
My roommate just told me the Dell 20" flatscreen has a $150 rebate right now, I'll see if I can get more information from him. Once you go big, you will never look back. Ive got a 23" widescreen and a 19" 4:3 and I love the setup. It takes multi-tasking to a whole new level. Though I primairly do imaging stuff and I don't know much about cad programs, it sure is a big help for me.
__________________
--Austin
RHaus NYC
06 M45 Sport - Beauty
96 4Runner - The Beast
turboale is offline
Old 04-18-2006, 09:36 AM   #11 (permalink)
li_runner's Avatar
Ta Daaaa!!!!
__________________
-Pete
RIP *97' 4Runner SR5*
New baby: 07' Sport v6 Shadow Mica
li_runner is offline
Old 04-18-2006, 09:39 AM   #12 (permalink)
MNBOY's Avatar
[quote=turboale]Good luck finding a laptop that will support dual monitors aside from the connected one. I have yet to find one, but I haven't really been looking either. Do you really need all that power with you at all times? Why not get a desktop, that will be able to do the job better in the first place, and get either a used or base model laptop? A word to the wise, having a super high power laptop will be heavy, bulky, have horrible battery life, and they tend to run really hot. My buddy just had a monster laptop and it actually caught fire!
QUOTE]
If you are referring to me then you should reread my post. I'm not sure how getting a desktop is going to help me on the boat or in my truck, and an old slow Sony Vaio would probably not accurately be described as "super high power".
__________________
Greg
93 4x4 pickup
MNBOY is offline
Old 04-18-2006, 09:42 AM   #13 (permalink)
MNBOY's Avatar
Quote:
Originally Posted by li_runner
That looks like it would work. Wondering if $169 is considered a cheap fix for this. My last two computers were free and I'm completely out of touch with what things cost.
__________________
Greg
93 4x4 pickup
MNBOY is offline
Old 04-18-2006, 10:20 AM   #14 (permalink)
Cebby's Avatar
Quote:
Does the laptop have an external VGA jack? That's what I'm using. I don't need a card. If you use XP, just select "extend my desktop to this monitor". It just makes the real estate larger - not a repeater, but more area for windows. I run AutoCAD or Photoshop on my 24" widescreen and other apps on my 15" widescreen laptop panel at the same time.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 04-18-2006, 10:22 AM   #15 (permalink)
Cebby's Avatar
Here's a link to more info: http://www.yotatech.com/showthread.p...hlight=monitor
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 04-18-2006, 10:49 AM   #16 (permalink)
MNBOY's Avatar
Quote:
And what would an external VGA jack look like? It has a docking station that came with it that has a bunch of ports. Would be very good to be able to do this with the equipment I already have.
__________________
Greg
93 4x4 pickup
MNBOY is offline
Old 04-18-2006, 11:04 AM   #17 (permalink)
Cebby's Avatar
Likely 15 pin like this: http://www.bbdsoft.com/video.html (except female, not male). The other deal breaker would be that with the internal video display driver, can it drive both the laptop panel and the external monitor simultaneously? Some of the older laptops couldn't do both.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 04-18-2006, 11:06 AM   #18 (permalink)
MNBOY's Avatar
I've got a couple of those on this thing. Once I get the laptop and monitor in the same place I'll have to give this a shot. Sounds like I may just be in luck.
Thanks for all the help.
__________________
Greg
93 4x4 pickup
MNBOY is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Dual Monitors - Laptop and External display - Extending Desktop Cebby Computer Talk 12 08-07-2005 04:18 AM
Multiple Monitors phorunninduke Computer Talk 4 06-26-2004 05:02 PM
Monitors (LCD) jrallan26 Off Topic Talk 12 01-24-2004 07:07 PM
LCD monitors Corey Off Topic Talk 0 12-20-2003 06:24 PM
2009 InternetBrands, Inc.
