| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Dual DHCP Scopes with different subnets on one server?? Possible??
__________________
The Money Pit: '96 FZJ80 - Locked | Safari Turbo w/ Intercooler | Unichip | 3" Exhaust | IPT VB | OME 3" Lift | ARB & Kaymar | Winch | DBA Slotted X-Drilled Rotors | Aussie Drawers | HID's | BFG AT's... '78 FJ40 - Finally got my Mustard Baby!!! - Resto Project... Clicky for Pics! |
#2 (permalink) |
Hmmm, I think I got it. I'm experimenting with superscopes, lets see how this works....
__________________
#3 (permalink) |
Two NIC's makes it easier, You can use SuperScopes but they are a PITA.
I have 4 Nics in my websever right now. Each bound to a set of IP's |
#4 (permalink) | |
Guest
Quote:
#5 (permalink) | ||
Quote:
No, just that the gateway and subnet info is already in place, just to rule that out as an issue. Each of our networks that are seperated by a router has its own w2k3 server with DHCP enable. We don't relay DHCP requests at all. Basically I'm running two subnets on one physical network. No segments, VPN's, etc. Quote:
__________________
#6 (permalink) | |
Guest
Quote:
#7 (permalink) | |
Quote:
Yup. Sorry I should refresh up on my tech lingo. I just tried using a Superscope and shrunk both pools down to 15 addresses for testing purposes, then fired up a 30 system lab. The primary block (32.x) filled up first then moved on the the next block (34.x). The only minor issue I ran into is when joining the domain with a new machine that grabbed a "new" 34.x address, I had to use the FQDN to even see the domain. On a system with the "old" 32.x I just used the shorter Netbios name. No big deal, just more typing. (And no, we don't use WINS). With these test scenario results I'm assuming I should be fine. When school starts up in a few weeks and 300+ systems fire up in this building I don't want ANY surprises.
__________________
#8 (permalink) |
Guest
You could have just added another block of IPs on the DHCP server and it will work just fine. No need for extra network cards.
Why not renumber the network and 'do it right' before school starts? All nodes on the same network. Easier to troubleshoot, especially once it’s full of whiny users. |
#9 (permalink) | |
Quote:
Why not use a non-routable addresses (trusted network) on PC's and use NAT/PAT on your border routers and firewalls? If you use PAT, you only need one routable address. NAT/PAT require logging if your interested in security but they are flat files so they don't get very large quickly. You can assign two subnets on most decent routers and firewalls and that increases your security also.
__________________
MvCrash 2005 Rav4L Stock for now 2003 Mustang Mach 1, 4.6 DOHC V8. Cold air intake,magnaflow cross over and cat back, Custom tune by Predator SOLD:2001 Tacoma XCab, Michelin LTX, AmeraGuard Spray in Liner, Access Roll-Up Tonneau Cover, Synthetic Oils Last edited by MvCrash; 08-22-2005 at 04:54 AM. Reason: I'm not too smart |
#10 (permalink) | |
Quote:
Hmm, not sure if I follow the renumbereing thing. We have over 350 sytems in the bulding, so one block just won't cut it, I have to use two seperate net numbers. (They are both class C's...) Please explain, I want to make sure I'm not missing something really obvious
__________________
#11 (permalink) | |
Quote:
Thanks for all the input though, I love hearing what approaches other IT dudes take. It's soooooo easy to get stuck in you own way of thinking when you work in the same place for too long. Always nice to get some different insight.
__________________
#12 (permalink) | |
Guest
Quote:
Make all desktops say have IPs between x.x.32.1 and x.x.33.254 with a netmask of 255.255.254.0. That's enough for 510 systems/IPs, same broadcast domain, no need for unnecessary tricks with routing. |
#13 (permalink) | |
Quote:
__________________
MvCrash 2005 Rav4L Stock for now 2003 Mustang Mach 1, 4.6 DOHC V8. Cold air intake,magnaflow cross over and cat back, Custom tune by Predator SOLD:2001 Tacoma XCab, Michelin LTX, AmeraGuard Spray in Liner, Access Roll-Up Tonneau Cover, Synthetic Oils |
#14 (permalink) | |
Quote:
So machine A starts, broadcasts its MAC to the server and picks up specific IP address 10.1.10.2. (non Routable) The the user makes a request to the internet and then the firewall translates the address from the non-routable to a IP address within the routable addresses that are assigned to your place by IANA. Sounds complicated but its really not. AND everytime you get a new machine, no hardcoding the IP's, you plug it into the wall and the LAN and the server assigns the IP, Default Gateway, subnet and DNS numbers. Makes things easier in the long run. Print servers are a nitemare. Assign specific IP's to the printers and then create an IP port on each machine. This way if the Print server breaks, everyone can keep printing. Makes it a little more difficult to switch printers, All you need to do is assign seperate IP Ports for printers. I know it works on a system of 73 sites!!
__________________
MvCrash 2005 Rav4L Stock for now 2003 Mustang Mach 1, 4.6 DOHC V8. Cold air intake,magnaflow cross over and cat back, Custom tune by Predator SOLD:2001 Tacoma XCab, Michelin LTX, AmeraGuard Spray in Liner, Access Roll-Up Tonneau Cover, Synthetic Oils Last edited by MvCrash; 08-22-2005 at 05:09 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Server problems? | Dublin | Off Topic Talk | 4 | 02-28-2007 05:53 PM |
| Low Light Rifle Scopes | AgRunner06 | Off Topic Talk | 42 | 12-13-2004 09:19 PM |
| Server will be down | Corey | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 01-18-2003 10:54 AM |
