data transfer between computers? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-06-2005, 06:28 PM   #1 (permalink)
Glenn's Avatar
Hi
I want to back up some of my files on an old Win98SE computer.
Is there a simple program that will facilitate this? I am hoping to use USB to connect the computers to one another.
__________________
-Glenn-
Glenn is offline
Old 07-06-2005, 07:22 PM   #2 (permalink)
tulsa_97SR5's Avatar
win98 has an accessory 'direct-connect' or something like that. Should just require a cross-over ethernet cable & plug the NIC cards together. Not sure about doing this with USB, i never tried.
What is the new computer? It might be easier to physically move the hard drive into the new PC & copy them over directly. I've wasted hours & hours before messing with LAN setup on win98 pc's before.
__________________
Brian
85 sr5, 5spd - back on the road, doing DD duty for now
86 2wd reg cab - future project
90 sr5, 97 - gone
tulsa_97SR5 is offline
Old 07-06-2005, 07:34 PM   #3 (permalink)
Glenn's Avatar
I want to transfer files from my WinXP Home to the old computer which has Win98SE. I found some info on the net about Direct Cable Connection, which seems fairly straightforward. I need to find a cable that will work. I have some around somewhere....
__________________
-Glenn-
Glenn is offline
Old 07-06-2005, 07:45 PM   #4 (permalink)
Quote:
Ahhh, sounds like a plan. I don't think dropping the HD from the XP box in the 98 box would work very well. Not sure about the direct connect working with XP, if it turns into a headache you might want to buy a cheap little hub for $20 or so.
__________________
Brian
90 sr5, 97 - gone
Old 07-06-2005, 07:52 PM   #5 (permalink)
Glenn's Avatar
Already have a hub. So you are saying that I already have all the cables that I need? Just connect through the hub? I know I have a long USB cable somewhere...just gotta locate it.
__________________
-Glenn-
Glenn is offline
Old 07-06-2005, 07:57 PM   #6 (permalink)
An ethernet hub (or switch, or bridge) should work. Don't think a USB hub will, but I'm often wrong.
__________________
Brian
90 sr5, 97 - gone
Old 07-18-2005, 11:57 AM   #7 (permalink)
BlueTrane's Avatar
Send a message via AIM to BlueTrane Send a message via MSN to BlueTrane Send a message via Yahoo to BlueTrane
http://www.compusa.com/products/prod...437&pfp=BROWSE
__________________
2006 IS350
1996 SC400
2002 4Runner Sport -- SOLD
BlueTrane is offline
Old 07-18-2005, 12:02 PM   #8 (permalink)
jimbojones75's Avatar
Hub and straight thru ethernet cables is probably the easiest. USB would require a special cable designed to connect two PCs, I think they may be called null USB cables (named after the old null modem cables to connect two pcs via serial cables) or maybe they are called peer to peer cable. Anyway, networking(ethernet) the PCs is for sure the way to go.
jimbojones75 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Your computers! Jimmeh Computer Talk 28 06-07-2006 11:01 PM
Computers etc. MNBOY The Classifieds GraveYard 5 03-13-2006 09:43 PM
where are the EFI computers? darth brian 86-95 Trucks & 4Runners 5 03-08-2006 02:10 PM
Dell computers Localmotion Computer Talk 12 11-24-2005 11:55 AM
computers suck ChickenLover 95.5-2004 Tacomas & 96-2002 4Runners 2 05-02-2004 09:24 PM
2009 InternetBrands, Inc.
