| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Co-Founder/Administrator
Staff
CT Helper
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
#2 (permalink) |
Corey, there's also a function within Spybot>Advanced>Tools>System Startup that works like MS Config but shows even more running processes than MS does. I found it useful to disable a couple of things taking up processor % as shown on Windows Task Manager Performance tab.
__________________
'07 FJ Cruiser TRD SE 6M/T |
#3 (permalink) |
Corey, thanks for the heads up. Alot of PC users are having problems with CTHelper.exe. Most, just like you (Corey), just remove it from startup using MSCONFIG.
I am guessing CTHelper.exe is either a) using too much memory (about 4 megs) b) It's causing problems with API interface locking up process threads. Root cause from bogus API programming but not seeting the following variables; 1) failing to set a KillTimer() 2) timeKillEvent() Either way, CTHelper.exe is not needed. |
#4 (permalink) |
Staff
Also make sure you turn off in either MSconfig two more apps from Creative.
They are: UpdReg ADGJDet Those are both in the Registry. I rebooted, and all seems to be well. BT, did not know about the Start Up area in Spybot. Will have to check into it this weekend. Amusement, I'll see if this speeds up the PC too. I hate it when stuff not needed runs in the background. I think us tweakers spend an awful lot of time fixing things that software screws up. I like the PC to run as wide open as possible, and not be bogged down by bloatware. |
#5 (permalink) |
Greetings,
In other threads you were taking steps to speed up your boot process. Just a reminder about MSCONFIG. Even though you choose not to let a program start on boot, the entire boot record must be read by the OS. If you have alot of items shut off in MSCONFIG, you may want to remove them from the registry so your machine won't have to read them in the boot file. This can speed up your boot considerably. You should also take a look at what processes are running. Some don't show in MSCONFIG but are started on boot and indicated in the system process. You can use regedit to do this, but be careful you don't delete the wrong files.
__________________
MvCrash 2005 Rav4L Stock for now 2003 Mustang Mach 1, 4.6 DOHC V8. Cold air intake,magnaflow cross over and cat back, Custom tune by Predator SOLD:2001 Tacoma XCab, Michelin LTX, AmeraGuard Spray in Liner, Access Roll-Up Tonneau Cover, Synthetic Oils |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear end sag '88 4 Runner helper springs | spudrunner | 86-95 Trucks & 4Runners | 11 | 11-27-2006 12:32 PM |
| Helper Leaf Springs | ElwayLite | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 12-19-2005 12:51 PM |
| Helper Spring install ?'s... | brendonv | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 05-09-2005 06:26 PM |
| ON EBAY TRD AIR Helper Springs | dedicated2detail | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-15-2005 08:53 AM |
| Trail Master Helper Springs...??? | brendonv | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 06-14-2004 05:06 PM |
