| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
computer won't start
__________________
[2002 4Runner 4WD] |
#2 (permalink) |
Ha, you have come to the right place.
This is what some of us would like to call a quickee BSOD. Basically, you have a BSOD (blue screen of death) error that doesn't last long enough for you to know what you have. The cure: A reformat of your hard drive should do the trick. The cause: In my expiriences, it has been due to the use of either a Western Digital hard drive, or some other brand that I can't think of the name. Seagates and Maxtor are probably some of the best out there for master drives, and you won't be dissapointed if you are willing to buy a new one. If you want to save your files, it is possible if you slave the drive, and then put the files on another computer. I sincerely doubt it is a virus, considering that your antivirus should have blocked or killed it. Again, I have had this happen several times, and in my expieriences, it was a Western Digital, or just too much messing with the drives capabilities.
__________________
Jim Montana Pictures Myspace 1992 "Toyota" Ranger XLT 4X4 4.0 EFI Auto. Lots of mods on and to come. 1995 Dodge Ram 1500 single cab short bed 318 V8 with a 5 speed manual transmission. The big ugly bastard of a work truck. 2000 Toyota Tundra SR5 Access cab. My grandmas truck. |
#3 (permalink) |
Is this a desktop or laptop?
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#4 (permalink) |
BSOD's are usually hardware related (at least, on win2k and better)... assuming it's a desktop, try taking everything out of the system that doesn't need to be there (any pci cards, cdrom, floppy, all but one stick of memory) and booting like that. if that works, start adding hardware until you get to the one that makes it not boot.
#5 (permalink) |
as dz said.. they are hardware related... try running some diagnostics on your memory and harddrive (2 main sources for a BSOD, crashes and reboots). formatting your harddrive should be your last resort as that will take you a long time to finish, and you still won't be sure if it was indeed a software problem. I recommend doing the memory test first, if your memory was bad and you tried to do a hard drive diagnostic it will tell you that there are errors, leading you to believe your hard drive was the culprit. when in fact it was the memory.
click the links below for the appropriate diagnostic... all of them will create a bootable floppy disk, just put it in, adjust your bios to boot to floppy and follow the onscreen instructions. memtest86 - great memory tester (some boards have this in the bios, such as the DFI LanParty) - western digital - WD's diagnostic - maxtor maxtor's - samsung samsung's - ibm/hitachi hitachi's... pretty sure ibm no longer makes drives - seagate seagate's
__________________
1991 4Runner SR5 3.0L 4wd 5Spd, 31x10.5 ATs, HG replaced 02/05, 320,000km 2008 Acura CSX 2.0L 5Spd, Leather, Sunroof, Wing, Fog Lights, VSA, TC, 10,000km Last edited by green91runner; 06-11-2006 at 03:04 AM. |
#6 (permalink) | |
Sponsoring Member
Quote:
That is SUCH bad advice. There are TONS of ways to get around reformatting a drive. Cal, start with Green's ideas...
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#7 (permalink) |
mark you know about just about everything, it cracks me up, i love it
__________________
2006 Tacoma 4x4 TRD Sport with 20's and 285 Goodyear Furtura's and 2 inch cornfed lift 2002 Tacoma Extra Cab V6 (SOLD) |
#8 (permalink) |
Since you're having random symptoms, I'm going to bet it's the motherboard. No real way to test that except but to rule everything else out. Well, there is, but it requires expensive equipment.
Run all the free hardware tests you can, then if that doesn't solve it, try to re-install windows (you dont' have to reformat), then if that doesn't work, try a clean install.
__________________
-Chris If you can't explain it simply, you don't understand it well enough. Click here to search! My Website |
#9 (permalink) |
thanks for the tips guys.
another thing - last time i got it to start up, well as far as after a minute or two of the black screen, it went to a blue screen with a frozen cursor and a little folder icon in the upper left corner. anyway, i'm on the laptop now and can't make a floppy. i'm just gonna take it to my boss's friends house, he's a real computer whiz with his own shop and all. he'll get to the bottom of this. here's to hoping it's something simple. (either that or totally gone so i can get a new, better computer )
__________________
[2002 4Runner 4WD] Last edited by calrockx; 06-11-2006 at 03:23 PM. |
#10 (permalink) | |
Quote:
__________________
1991 4Runner SR5 3.0L 4wd 5Spd, 31x10.5 ATs, HG replaced 02/05, 320,000km 2008 Acura CSX 2.0L 5Spd, Leather, Sunroof, Wing, Fog Lights, VSA, TC, 10,000km |
#11 (permalink) |
turns out it was the video card. easy fo sheezy fix.
__________________
#12 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3vze won't start when hot, now won't start at all w/o starter fluid? | Schump | 86-95 Trucks & 4Runners | 44 | 03-02-2009 11:18 AM |
| Clutch Start Cancel Switch REQUIRED to start now?? | thirdeyebrian | 86-95 Trucks & 4Runners | 1 | 12-27-2006 06:54 PM |
| Getting a new computer... What do you think of this one. | Jason B | Computer Talk | 3 | 06-13-2004 08:46 PM |
| Need Computer Help | PutzRunner | Off Topic Talk | 7 | 03-09-2004 03:27 PM |
| Computer Q | KING | Off Topic Talk | 2 | 01-26-2004 06:30 PM |
