| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
computer surgery
__________________
Semper Fi, Alfred '91 4Runner SR5 4wd 3.0 V6 '10 Scion Xb |
#2 (permalink) |
It would probably depend on how similar the hardware in the new box is, since the kernel & modules in linux are setup to use your current hardware. If you build a new box & install linux on a new HD, and move your current linux drive over as a secondary drive you can mount it up no problem & access all your current files. What distro do you run?
__________________
Brian 85 sr5, 5spd - back on the road, doing DD duty for now 86 2wd reg cab - future project 90 sr5, 97 - gone |
#3 (permalink) |
I know for a fact XP won't work, because of chipset issues.
However, I'm not sure about Linux. I don't know if it relies on chipset info. Common sense says it would. However, I agree with tulsa... install Linux on the new then move the old over and read the files from it. However, this could also be done with XP. If you aren't getting a new drive, I'd just back up whichever drive has the smallest number of files and transfer that one over.
__________________
-Chris If you can't explain it simply, you don't understand it well enough. Click here to search! My Website |
#4 (permalink) |
the stupid piracy prevention of XP will make it extremely hard to move to another computer - but there may be a way around it, i don't know as i never use windows.
linux will be most likely trivial to move to another system. at least i never had any issues moving linux installations around.
__________________
mike '89 4Runner DLX: 2" OME rear springs, 1 5/8" RB BJ spacers, Diff Drop, 32" MT/R. '90 4Runner SR5: Stock Suspension, 32" MT/R . '07 4Runner SR5: 2" OME Rear Springs, Donahoe Coil Overs, Total Chaos UCA, 275/70-17 MT/R. '76 Jeep CJ-5: 4" Lift, 33" BFG MT. '87 Saab 900S: All stock '99 Subaru Legacy GT: All stock |
#5 (permalink) | |
Sponsoring Member
Quote:
![]() When you try to move an 2000/XP system onto a new motherboard, Windows getting PO'd about the IDE and host chipsets being different and refuses to boot. So, the gest of what you want to do is to swap out the specific IDE drivers to "Standard", then shutdown Windows, pull the drive, move it to the new motherboard and boot. In steps...
The _ideal_ thing is to wipe the drive and reinstall your world on a new machine. I generally REFUSE to do that and as such I've used this a number of times in the last couple of years and I haven't had a problem yet.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams Last edited by midiwall; 07-21-2005 at 02:29 PM. |
#6 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Laser eye surgery | Toys-R-Us | Off Topic Talk | 28 | 08-03-2007 07:05 PM |
| My son's surgery UPDATE! | Tacoclimber | Off Topic Talk | 12 | 06-08-2005 10:39 AM |
| ACL surgery---anyone? | Bob_98SR5 | Off Topic Talk | 33 | 12-14-2004 08:33 AM |
