| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Broadband router question
__________________
2001 SR5 4Runner 4WD, Dorado Gold, 184,XXX miles 2007 Volvo XC 90 AWD V6, Silver 1995 Porsche 993, Polar Silver |
#2 (permalink) |
You have to give your PC a static IP address FIRST one that reflects what the router use's Im pretty sure with linkcraps its 192.168.1.2 (check the manual) (The routers address will than be 192.168.1.1)
Use Internet exploder to access the router (Dont even bother with the CD) go to http://192.168.1.1 in your broswer You can now setup ALL your router features and settings. |
#3 (permalink) |
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Here's how I set up my network:
1. Connect all in the following order with Cat 5 (Ethernet) cable: --Cable modem->router->pc 2. Power on the equipment in the same order. Make sure that the cable modem is fully connected to the cable ISP before you turn on the router. You can verify this by looking at the "cable" or similar light on the front of the modem. This will ensure that the modem has verified its address with the cable company since it has a static IP address. 3. Power on the router. You'll get some lights flashing on the front of it, one should read "Internet" or something similar. At the same time, you should see some flashing lights on the front of the cable modem. This means that the cable modem & router are talking, and that the router has recieved & verified the cable modem's IP adress. This also means that the router has set up it's own address table for use on your side of the network. 4. Turn on the computer itself. After it fully comes on, first make sure that your network card is enabled. If not, enable it and reboot your machine to get an address from the router. If so, go on to the next step. 5. Open a command window by going to "Start-Run" Type "cmd" or "command" in the box and hit Enter. At the command line, type "ipconfig /all". You should then get a list of various addresses. Look for the line "IP Address", it should read 192.168.x.x, this will be the address it got from the router. If not, unplug & replug the router to force a new IP address to your machine; also reboot your machine. If so, start surfing YotaTech again! Hope this helps.
__________________
DD: 2006 Jeep Commander Sport 4.7l Trail rig: 1984 BII, 2.8, MSD 6A & Blaster 2 coil, Holley 2300, C5, OEM 1350, 7.5 & D28 with 4.56s, 33x12.50 BFG AT KOs on 15x8 black steelies, new "jeep" seats. Ugly but it runs and its paid for! ----------------------------------------------------------------------------------------- "An armed society is a polite society. Manners are good when one may have to back up his acts with his life."- Robert A. Heinlein |
#4 (permalink) |
Thank you very much for the suggestions. I will attempt the install again soon.
Andreas
__________________
#5 (permalink) |
even though there is an ethernet cable between the modem and the computer.
is it in the right port. WAN port? on the back of the rounter I'm guessing there are 5 ports. could be more or less one is a WAN port. connect an ethernet cable from the WAN port to the ethernet port on the rounter. then hook and ethernet port from port one on the rounter to the ethernet port on your pc. plug it in turn it on. Something to try. Don't run the motorola program, run windows network setup. the broadband shouldn't need any connection program. just click on IE and it works also the ethernet cables. make sure you bought straight though cables and not rollover cables. <--just a thought
__________________
04 TRD 4x4 v6 Your Driving? Were we going? Last edited by redfox435cat; 07-24-2004 at 01:51 AM. |
#6 (permalink) | |
Quote:
Andreas
__________________
#7 (permalink) |
Co-Founder/Administrator
Staff
Another tip.
Win 98 came with an IP config tool that worked in Windows, and was not the DOS type one that you have to use with XP. I found out shortly after building my XP machine last August that the GUI type one for Win 2000 works with XP. You can get it from Microsoft, or from me here. No viruses 151 kIt is a setup program, and will install it for you by default here: C:\Program Files\Resource Kit\WNTIPCFG.EXE" Make a shortcut to it on your desktop, then drag it down to your taskbar, that is where I have mine.
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 100mbit Broadband Internet | midiwall | Off Topic Talk | 12 | 07-21-2005 01:25 PM |
| Vonage Broadband Phone | jrallan26 | Computer Talk | 34 | 01-25-2005 06:24 PM |
| TIVO via broadband | jrallan26 | Computer Talk | 2 | 10-18-2004 06:29 AM |
| Need someone with Xbox, Halo, and broadband. | OneTrickToy | Off Topic Talk | 7 | 12-05-2003 05:33 PM |
| Weekend is almost here (broadband) | Corey | Off Topic Talk | 6 | 08-16-2002 05:07 AM |
