| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Big trouble... Can't figure out the fix...
__________________
***WHEELIN' ON THE CHEEEEP*** '87 4-Runner SR5, 3" lift, 33's, nerfs, engnbldr inside. RUST FREE!!! Engine complete... Ready to wheel! Hmmm... Sneaking back in here after a 2 year absence... |
#2 (permalink) |
Does the Cd-rom work at all? I cant get any thing cd/dvd related to last more then 2 years....doesnt a cd rom use a generic driver, something that is built in...I never loaded a driver for a cd-rom....the computer has read the drive just like any other drive, 3.5", hard drive....both I've never installed drivers for an initial start up....did you try formating the entire system and starting from scratch? sorry i couldnt have been of more help....
__________________
06 Subaru WRX |
#3 (permalink) |
You should be able to find a setup file from the Microsoft website that will let you split up the files onto seperate floppies. I've done this for WinXP, and it took 7 disks.
Check this out... http://www.pcguide.com/vb/showthread.php?t=5751
__________________
-Chris If you can't explain it simply, you don't understand it well enough. Click here to search! My Website |
#4 (permalink) |
All I've ever needed is a DOS start-up disk/boot disk - that has all the generic drivers that you need. They are getting hard to come by, but if you can find the MS DOS 8.0 w/scsi, that should get the 98, ME and 2000 up and running with no problems whether you're running a "normal" or scsi setup.
#5 (permalink) |
Well... I found the fix...
I had to replace the CDROM, make a setup disk (1.44MB 3.5" floppy), burn the WIN98 directory off of my computer, insert setup disk, load with CDROM support. It created a virtual drive. I then had to go to A:\FDISK and repartition the HD, format the HD (using the command FORMAT C: /S, to save the DOS as the OS for later), and reload WIN98SE using the WIN98 directory off of my box. I also had to use MY product key, since the other box has ZERO stickers on it (not even the brand). For future (unlucky) repairmen, I put a copy of the setup disk, the WIN98 directory (basically an OEM OS disk), and the NERO software from the CDRW drive I installed inside a Ziploc bag, and left them in the bottom of the case. I also wrote the product key on the inside wall of the case, on the CD case, and on the CD with a Sharpie. Now, on to the next issue... It seems that the VGA adapter in this computer only goes up to 16 color capability... Do I need to change the graphics card in it, or is there a way to get a better driver for it? My box has the NVIDIA RIVA adapter, but this one does not. Can I use that, or do I need a new card installed? TIA for all the help...
__________________
#6 (permalink) | |
Quote:
It should work that way, Unless I read your question wrong. :bounce2:
__________________
[-Chris-] 1988 X-Tra Cab 4x4. V6. Stripped to the frame. 1998 Chevy Chyenne Extended Cab, pretty much stock, except for a few cosmetics. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| What is it that you just can't figure out with your rig? or can't fix | keithguts | General Vehicle Related Topics (Non Year Related) | 76 | 06-08-2009 03:43 PM |
| big rig in big trouble!!! PICS! | yotasavg | Off Topic Talk | 17 | 07-09-2007 01:15 PM |
| Big Trouble!!!! | kawicowboy | Maintenance & Repair Archives | 3 | 06-26-2005 09:09 PM |
| Big Trouble & $$$$$ | data | 95.5-2004 Tacomas & 96-2002 4Runners | 23 | 11-13-2002 05:10 PM |
