backing up files quickly - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-15-2006, 08:58 AM   #1 (permalink)
calrockx's Avatar
Send a message via AIM to calrockx
Right now when I copy my "My Documents" folder to my external hard drive to back up, Windows asks me if i want to replace "xxxxx" file with the new version? i say no, then the backing up stops.
is there something i can do or download a program that will just compare the folder to the back up drive's folder, highlight just the new or modified files, and only copy those over? that'd make backing up my files a lot quicker.
the ftp program i use at work, cute ftp, has that feature - press F11, and it'll hightlight only the new or modified files on the local drive to show you what needs to be copied to the server. i want something like that for my computer.
__________________
[2002 4Runner 4WD]
calrockx is offline
Old 02-15-2006, 09:07 AM   #2 (permalink)
Sponsoring Member
midiwall's Avatar
Find the command line!
Code:
xcopy /?
Copies files and directory trees.
XCOPY source [destination] [/A | /M] [/D[:date]] [/P] [/S [/E]] [/V] [/W]
                           [/C] [/i] [/Q] [/F] [/L] [/G] [/H] [/R] [/T] [/u]
                           [/K] [/N] [/O] [/X] [/Y] [/-Y] [/Z]
                           [/EXCLUDE:file1[+file2][+file3]...]
  source       Specifies the file(s) to copy.
  destination  Specifies the location and/or name of new files.
  /A           Copies only files with the archive attribute set,
               doesn't change the attribute.
  /M           Copies only files with the archive attribute set,
               turns off the archive attribute.
  /D:m-d-y     Copies files changed on or after the specified date.
               If no date is given, copies only those files whose
               source time is newer than the destination time.
               Specifies a list of files containing strings.  Each string
               should be in a separate line in the files.  When any of the
               strings match any part of the absolute path of the file to be
               copied, that file will be excluded from being copied.  For
               example, specifying a string like \obj\ or .obj will exclude
               all files underneath the directory obj or all files with the
               .obj extension respectively.
  /P           Prompts you before creating each destination file.
  /S           Copies directories and subdirectories except empty ones.
  /E           Copies directories and subdirectories, including empty ones.
               Same as /S /E. May be used to modify /T.
  /V           Verifies each new file.
  /W           Prompts you to press a key before copying.
  /C           Continues copying even if errors occur.
  /I           If destination does not exist and copying more than one file,
               assumes that destination must be a directory.
  /Q           Does not display file names while copying.
  /F           Displays full source and destination file names while copying.
  /L           Displays files that would be copied.
  /G           Allows the copying of encrypted files to destination that does
               not support encryption.
  /H           Copies hidden and system files also.
  /R           Overwrites read-only files.
  /T           Creates directory structure, but does not copy files. Does not
               include empty directories or subdirectories. /T /E includes
               empty directories and subdirectories.
  /U           Copies only files that already exist in destination.
  /K           Copies attributes. Normal Xcopy will reset read-only attributes.
  /N           Copies using the generated short names.
  /O           Copies file ownership and ACL information.
  /X           Copies file audit settings (implies /O).
  /Y           Suppresses prompting to confirm you want to overwrite an
               existing destination file.
  /-Y          Causes prompting to confirm you want to overwrite an
  /Z           Copies networked files in restartable mode.
The switch /Y may be preset in the COPYCMD environment variable.
This may be overridden with /-Y on the command line.
To do what you're looking to do:
xcopy {source} {destination} /d /e /c
Stuff it in a batch file and you'll only have to type it out once. The downside is that doing this from a prompt will be slower than from explorer since it won't take advantage of Windows' write buffering.
But... I'm sure that there's a freebie Windows app that will do this as well. Wander VersionTracker - it's a pretty good resource to find apps.
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 02-15-2006, 09:36 PM   #3 (permalink)
arjan's Avatar
When all else fails, revert to DOS. I had actually forgotten the XCOPY. I used to know it by heart. That and DELTREE where your friend in the DOS days.
__________________
2006 4Runner V8 Sports Edition
Red 1997 4Runner 3.4L Bushwacker Flares, 5spd, E locker
arjan is offline
Old 02-24-2006, 12:06 AM   #4 (permalink)
ldivinag's Avatar
you shoulda seen the DELETE util i wrote a LOOOOOOOONG time ago for a class.
you thought the ARGs for xcopy is confusing...
my plan was to use each letter as a switch option... lol...
professor was pissed and laughing as the same time.
__________________
leo d.
stock 90 4runner
ldivinag is offline
Old 02-24-2006, 07:05 AM   #5 (permalink)
calrockx's Avatar
turns out i fought what i needed. just google "directory compare" and all sorts of programs come up.
__________________
[2002 4Runner 4WD]
calrockx is offline
Old 02-24-2006, 08:20 AM   #6 (permalink)
li_runner's Avatar
A simple free program that windows finally realized was needed is Synctoy.
Google it, download it, it's exactly what you want.
__________________
-Pete
RIP *97' 4Runner SR5*
New baby: 07' Sport v6 Shadow Mica
li_runner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22re installation help......quickly please !! krustyroo 86-95 Trucks & 4Runners 1 05-28-2007 04:42 PM
Quickly! Everyone to CHAT! 04 Rocko Taco Off Topic Talk 4 09-06-2006 11:23 AM
Up Pikes Peak...Quickly BT17R Off Topic Talk 16 04-14-2005 12:20 PM
U-Joint information needed, quickly SteveO 95.5-2004 Tacomas & 96-2002 4Runners 15 12-08-2003 07:24 PM
Oil getting dirty quickly frick 95.5-2004 Tacomas & 96-2002 4Runners 11 03-28-2003 05:52 PM
2009 InternetBrands, Inc.
