GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
painting a firestik
Old 09-25-2005, 01:41 PM
northfacer581's Avatar
painting a firestik
well i thought i ordered a plain black 4ft firestik, but apparently i ordered the "special edition"...its red white and blue. i do love my country, but i would like my antenna to be black. is it ok to just spray paint it? one of my friends also suggested wrapping electrical tape around it...what are your opinions? thanks
Old 09-25-2005, 01:43 PM
Spectre's Avatar
Can't you just have them swap it out for you?
Old 09-25-2005, 02:17 PM
Silver_Truck's Avatar
black electrical tape works good
Old 09-25-2005, 02:56 PM
4Crawler's Avatar
Or do like Firestik does and use heat shrink tubing. Buy a length large enough to fit over the antenna (an good electronics store will have it), slip it over and hit it with a heat gun and it'll shrink right on there. Will last longer than paint or tape.
Old 09-25-2005, 03:53 PM
wrapped some electrical tape around it. you cant even tell theres tape over it. i figure a roll of electrical tape at 47 cents a piece, and it only took about 1/4 of the roll, it was the easiest/cheapest way to do it.
Old 09-26-2005, 08:23 AM
deathrunner's Avatar
Plus, now you have electrical tape ready when you need it, just peel it off your antenna.
Old 09-26-2005, 04:05 PM
haha good point. well i finally got around to wiring it up today, and the whole setup works great. i highly recommend this setup to anyone looking for a solid cb setup for a 3rd gen 4runner...the cobra 18 wx st II fits PERFECTLY in the din area, and the 4ft firestik is a great match.
Old 09-27-2005, 02:23 PM
I run the same cb/antenna combo and it works great for me as well
Old 10-07-2005, 05:43 PM
rocket's Avatar
http://www.firestik.com/Tech_Docs/Ant_paint.htm
On occasion we are asked if it is okay to paint one of our antennas to match the color of the vehicle. The answer is, "Yes … you can!"
To achieve the best results there are a few things you can do,
1. Start out with a white antenna. It will have little or no effect on the base color of the paint.
2. Clean the antenna with paint thinner or denatured alcohol and let dry before applying paint
3. Use a lead free paint. Choose those that are compatible with plastics. We recommend plasti-kote ultra vinyl color paint or compatible.
4. Most car dealerships have paints made for painting plastic that also match the vehicle color.
Adding paint could add to the electrical length of the antenna. Therefore, either recheck the SWR after a previously tuned antenna has been painted, or wait and tune it after the paint job is finished.
Old 10-07-2005, 05:56 PM
thanks very much!! thats the answer i was looking for. i think im going to take off the electrical tape and paint it to green to match my 4runner.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
Toys4parts
09-26-2015 01:56 PM
Obmi
09-10-2015 03:36 AM
Quick Reply: painting a firestik
