| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
My CB Setup/ New Bracket for Antenna
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. 1983 SA Axle Frameoff Restore. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5 -=NO BAMA 08 =- |
#2 (permalink) |
nice, wats with the fan where the center console should be?
__________________
1997 Toyota 4x4 SR5 4runner 3.4 auto Toytec 3 inch coil spring Lift Custom Front bumper Trail Gear Rock Sliders Modified Stock skid plates Maxxis Bighorn M/T's / Goodyear Wrangler TD's Amp Custom Rims Cobra CB, 5ft Firestik http://www.cardomain.com/ride/3008195 Near Future List Rear Bumper Lockers 1st Gen Roll Bar Winning the Lottery? |
#3 (permalink) |
That "fan", keeps my transistor box cool when I am talking on the radio. The reason it has a fan is because on long keydowns, when I hold the mic keyed for awhile that box will get really really hot. That is just part of my cb. I removed the center console to fit it there. It's weird looking and odd if you have little knowledge on amature radios or cb radios.
__________________
#4 (permalink) |
nice setup. i like the cut down 102" whip as a stinger - we had to do something like that too on my friend's MM. i like the mount on the bar - if i had the skills and equipment, that's something i wish i could do myself.
3300HP - good radio! should have plenty of output and swing to drive a volted 5-pill. your stock alt and single batt might be taxed kinda hard. it's not too hard or expensive to upgrade the alt - you can either go aftermarket or stock rewound (cheaper, as long as you use your original as a core exchange). some of the more hard core guys replace their a/c compressors with additional alts, some even go so far as to have custom brackets made, use serpentine belts from mustangs, and run three or more alts. if you don't have one already, an optima yellow top or blue top might help you with a long keydown if you're limited to a single battery. lots of folks here have added additional batteries under the hood as well. a rewound alt. and optima yellow top have served me well for years, but i'm nowhere near 800w, much less 1K. re: check engine light- as you speculated, it's probably due to RFI. your box is kinda close to your computer, and a box that size probably generates a fair bit of RFI when driven hard. the Connex probably isn't the problem, i've been using a tuned SS3900GHP for years near the dash of a 98 T4R w/ no problems. if you had enough distance, you might be okay. i ran a six pill in the trunk of a maxima, and in the rear cargo area of the T4R, w/ no interference, noise, or check engine lights. ground, ground, ground. just my .02 on the RFI. nice setup! |
#5 (permalink) |
yeah i dont know much about them, i run a cobra 27 nightwatch with a 5ft firestik, just simple stuff
__________________
#6 (permalink) | ||
Quote:
Quote:
__________________
#7 (permalink) |
Staff
Crazy set up man... don't you get hassles going under bridges and stuff with that whip? What kind of range are you getting with that combo?
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
Staff
holy smoke! If I ran a set up like that around here I'd be hitting the streetcar power lines all the time which would probably not be good lol...
you could have a sweet little pirate radio stn. there... be hard for the FCC to nail you too being mobile and all heh heh heh
__________________
#10 (permalink) | |
Quote:
i've seen large amps with multi-battery, multi-alt setups actually stall a 350 chevy unless the owner is flooring it at keydown. for max voltage to the amp, you probably want to run a decent size power cable. for an amp that size, i'm thinking/guessing 4/0 minimum. many times, the amp will draw as much current as you can feed it, so if you can minimize resistance, the amp will put out more watts. i've seen multi-battery and amp setups in the beds of pickup trucks with camper shells, i've even seen amps and batteries mounted in tool boxes (bed mounted kind) but gotta be careful to ground well and keep them cool. also, if you're using regular marine batteries and not the sealed gel cell types, ventilation is also important to prevent hydrogen gas buildup in the box. remote switching is not hard, some mfrs sell kits with little faceplates and labelled switches, but you can do the same thing with some surplus wire and a switch - just extend the wires to the factory switches on your amp to a switch (or switches, if you have variable power), mount on little project box or directly to your dash, and you're good to go. |
#11 (permalink) | |
Quote:
you stated run the biggest wire possible, well I am running 2 gauge fine-stranded welding wire to the amplifier, and the same gauge wire to the engine block for the ground. one more thing, WHAT KIND OF GUYS are you running around with that have that kind of ridiculous power as to stall out a small-block chevy!?!?! That's nuts man. I can't imagine the rf those kind of "big radios" are putting out. I imagine that would interefere with tv's and computers for miles!? My small 1000watt mobile tears up toooo much stuff already, so much so I won't even key it down in town anymore.
__________________
#12 (permalink) | |
Staff
Quote:
"That #$^%# mgrchad! He's on that #$^$ radio of his again!" I could'nt resist...
__________________
#13 (permalink) |
tuning in tokyo tuning in tokyo.. Jeez mang, Do you pick up tarnsmissions from space with that thing?? Hi powa!!
__________________
1988 4Runner, 3.Slow, 5 spd.... not stock.... I have 2 sets of BFG AT's 33x12.5x15 Brand New.. 660 per set.. Oh yeah http://http://www.geocities.com/serioustoys/home.html |
#14 (permalink) | |
Quote:
Unlike a lot of high-power radio users, I use a little common sense, and am polite about running my amp around houses. I travel alot, so it gets used over the interstates most....it helps to keep me awake and passes the time while I'm driving to west virginia, new york or n.c. for climbing. but let me tell you, if I wanted to ruin your evening of watching "Guiding Light", I certainly could
__________________
#15 (permalink) | |
Staff
Quote:
![]() I was just trying to find the worst posible show you could mess up... LOL
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. Last edited by aviator; 02-12-2008 at 10:43 AM. |
#16 (permalink) | ||||
Quote:
you can use a voltage regulated alt, too... lots of the comp folks use those, or use external voltage regulators with cooling fans. just got to watch the specs of the alt, though. many h/o alts don't put out rated output at idle, they're rated at a certain rpm. voltage at idle can actually be less than stock alts. unless you want to floor it every time you key up, you might want to look into overdrive pullies for h/o alts. Quote:
Quote:
Quote:
even if they floor it, the drag on keydown can dramatically reduce rpms, or even stall out a BBC if it's not floored. and yeah, they put out ridiculous RFI. there's some keydown videos on the internet that show the video totally fuzzing out when the competitors keydown. i've seen streetlights turn on in broad daylight, people light up flourescent tubes from 6 feet away, etc... tvs, bank intercoms/pa systems, store muzak, etc... all fall victim to irresponsible use of power. even cars with ECUs that aren't properly shielded, or systems that aren't grounded properly, can wreak havoc upon ECU/ECMs. i've seen windshield wipers turn on, power windows go up/down on their own, doors unlock, etc... at keydowns. |
#18 (permalink) |
Merlin, straight up, you know what your talking about. AWESOME. In your opinion what would you do if you were in my shoes. I want to see 1,000 watts solid at peak modulation out of my box. I don't care about the whole "s" unit theory and such. For no other reason than "just because" I want that 1000 watts. I know this box is capable of it no problem.
Cheapest best way? Extra alt w/ overdrive pulley+batteries. Add batteries in a series and get my current alternator re-wound so it can keep up with charging them? As soon as spring rolls around and my hours kick back up, I am planning on bumping up my system so I can turn this rig into mean skip-shooter....and still use as my daily driver.
__________________
#19 (permalink) |
hey... I can pick up alot of people on my cb but I cant get any of it very clear is it my antanna tha t needs to ve adjusted I wasnt very clear on the set up once i installed it ....???
__________________
"No free man shall ever be debarred the use of Arms" |
#20 (permalink) |
yeah, adjust it. then you probably could talk to aliens, lol
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#21 (permalink) |
How I Cut Off The Plastic Snd Its Just Fiber Glass Should I Saw It Shorter Or What????
__________________
#22 (permalink) | |
Quote:
if you haven't had the 3300HP tuned for the box already, you want to make sure you have a low enough d/k so you don't overdrive the amp and hurt it, and you want to make sure you have good swing (most people look for around a 1:4 d/k to modulation swing). 2w is a good starting point for a d/k and then tune for 1:4 swing ratio. do NOT clip limiters, etc... you may sound louder, but the signal won't be as clean, and you may get lots of splatter over adjacent channels. get that swr as low as possible. go for max ground plane to get out the best - power is good, but antenna setup is critical. gotta know what you want the 1000w for- are you going for all-around transmission, or are you going to use it for keydowns where directional is best? cable- 2/0 is good, but 1/0 fine-stranded welding wire would be better at this power level. coax- RG8X minimum. there are other coaxes available that can carry a much higher wattage, but i have no experience on these. i wouldn't want to give you incorrect info, so i can't comment on these. is your amp a high-drive, or does the mfr recommend a kicker amp to drive it properly? 1000w w/o a kicker may not have enough drive to get you to the 1000w goal (again, depends on the amp - some amps have kicker circuits built in (i.e., 1 driving 4) and some just straight up 2SC2879 pills. the larger comp boxes generally require a driver amp, usually a 2-pill. the second alt is functional, but not practical (most people remove their a/c compressor and bolt the second alt to that. convenient in terms of mounting and running belts, not so nice if you live someplace hot and need that a/c. some folks have mounting brackets fabbed up, but then you have to find a serpentine belt the correct length for your new setup (not always easy, kind of a trial-and-error proposition). again, for that level of current draw, i wouldn't waste time or money with a rewound factory alt. i would go straight for replacing the factory alt (stock Toyota alts on the 3.4 motors don't put out a lot - i forgot the exact amt. on my 98 T4R, but i'm pretty sure it wasn't even 100w). i would look at Powermaster, Leece-Neville, or some other h/o alt. a nice plus is that some of the comp alts have voltage regulators built-in. batteries - i would at the MINIMUM replace the stock battery with an optima yellow or blue top, or even add a second deep cycle battery with an isolater. a maul, as you mentioned earlier, is also a viable option, they can be configured for one or two alts, multiple batts, etc... after wiring your battery(ies) up to the alt(s), you want to make sure they charge and can feed that hungry amp. alts make their rated output at a given rpm, so you need to know that rpm for max output. you also have to take into account drag on the engine from the amp(s). after upgrading and tweaking up to this point, especially with the larger cable if you choose to go that route, the amp will be drawing a lot of amps from your alt and batts. like i mentioned earlier, lots of the comp guys at keydowns simply go up to the line and floor it when they key down to keep their alts' rpm up. lots of times if they don't just floor it, they may stall out the motor. sorry, this is kind of a long post... but this is a compromise between "ultimate cheap" and a practical, functional system that's optimized for what it is and what its intended use is. lots of it is just optimizing components and the way they interact to get the most out of what you have, before replacing/upgrading equipment. i've seen people try to get by as cheap as possible, and while it may work for a while, it's not necessarily optimum or good for the equipment. lots of times it results in a nice cloud of 10ohm smoke. hope this helps! i know there are more knowlegeable people than me out there, maybe they can jump in with their experience as well. |
#23 (permalink) | |||||
Quote:
Quote:
Quote:
Quote:
Quote:
ROCK'N-ROLL MERLIN....
__________________
#24 (permalink) |
Dual alternator in progress
It's Friday night and I figured rather than get into trouble with friends I would get started on my dual alternator setup. The first thing I need to do is remove my AC compressor (it doesn't work anyhow), because this is where I am going to be placing my second alternator. By removing the ac compressor and placing the alternator in its place, I won't have to upgrade to new pulleys.....I will only have to fab up some alternator brackets. This thread will be a kind of a "build-up" thread showing the steps I've taken to get my charging system capable for 1000+watts. I will post some pics of what's going on, and would like it if you all would critique, criticize, or inform me as I go along with this. I know very little about cb radios, but have done extensive fab work and automotive work.......I have a 130amp Gm Alternator if I can fit it in place, if not I will go for an aftermarket 160+amp.
alright I gotta get the air compressor fired up, and get out all my Mac and SnapOn tools...yeeeeeehaaaaa -yota167 pics to come later
__________________
#25 (permalink) |
Removed AC compressor and Ac lines
I have decided to go for a dual alternator setup. Mostly because I really want the extra power and adjustable volts for my radio, but of course this will also come in real handy with a myriad of other modifications that will be added to my tacoma as soon as I get another daily driver ie. winches and an onboard aircompressor.
Here are some pics of my rewoval. The process took about 15 minutes to remove the compressor and lines. Before removal I checked the schrader valve on the compressor line for pressure, and as I expected there was no remaining refrigerant in the system. Next step is aquiring an alternator that will be the easiest to fab brackets for. I'm hoping my extra gm 110amp alt in the garage here will work for the time being untill I get around to buying a sick160 or 200amp unit from ohio generator. Has anyone done this mod to their Tacoma? I can't even find a dual alternator bracket setup for this truck. I have to laugh because I have found all kinds of pre-fabbed dual alternator setups for silly import cars but not my Tacoma. Picture before removal: ![]() Picture after removal: ![]() Picture of compressor on bench:
__________________
| Tags |
| amp, antenna, antennas, bbc, bracket, cb, cbs, cobra, draw, fatboy, mount, radio, setup, windshield, wrangler |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS: Panhard drop bracket & LSPV lift bracket | freshman | The Classifieds GraveYard | 9 | 01-31-2008 06:13 AM |
| NMO antenna bracket fender mount | Baloo | General Vehicle Related Topics (Non Year Related) | 0 | 03-19-2007 09:09 AM |
| CB ANTENNA hood mount bracket. Whick one? | fadetoblack72 | GPS & Communication | 4 | 04-10-2005 12:21 PM |
| Better CB Antenna Setup??? | StoryR | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 07-23-2003 09:07 AM |
