YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-24-2007, 05:25 PM   #1 (permalink)
Intalled Cobra 75
Hey I thought I'd put this question out there to see if anyone has experienced this. I just installed my Cobra 75, directly wired it to my battery and grounded it to a screw in my engine bay. Eveything works but my radio channels are all messed up. All my channels are different and the ones that came in clearly are scrambles. Is this normal? Any ideas of what is causing this? Thanks for any input
FIRGURED THIS ONE OUT. ONE MORE QUESTION BELOW
sbikes is offline
Sponsored Links
To remove this ad, register today!
Old 05-24-2007, 07:04 PM   #2 (permalink)
ewong's Avatar
You mean you set it to channel 5 and you show up on channel 22 on your friends radio?
you didnt do somehting like attempt to transmit before the antenna was connected did ya?
ewong is offline
Old 05-24-2007, 10:52 PM   #3 (permalink)
OK, my CB was working fine earlier today when I installed it. No I don't have an antenna yet, but I was just listening to the weather making sure everything worked. And everything worked fine, till tonight. Tried getting a weather reading and it came on for a split second and now I cant get it to work. I didn't try talking to anyone, just listening. Is this all because I don't have an antenna yet? Is it fixable? Cuz I'd be bummed and feel like an idiot if I just burned my radio.
sbikes is offline
Old 06-15-2007, 01:52 AM   #4 (permalink)
mehret's Avatar
Location: Williamsport (School,Work)/Palmerton (Home), PA
Send a message via AIM to mehret
If you don't have an antenna, you're only going to hear static. If its not powering up, check your power connections obviously, and if they seem to be good, check the fuse. Assuming it is powering up, the next thing I would look at would be the speaker inside the CB.
__________________
87 Toyota Pickup 22r, 5pd., 220,000 miles, 15x8 steels, 31x10.5x15 BFG A/T, tiger camo
There are excuses and results: No one cares about the excuses.
mehret is offline
Old 06-23-2007, 02:07 PM   #5 (permalink)
I have a Cobra that will not work for a couple hours after being in a hot car. I see you posted in May...are you somewhere in a hot climate?
Shimajilosan is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Cig lighter mounted cobra 75? Compass Creek GPS & Communication 0 06-18-2006 12:47 PM
installed my cobra 75! lee GPS & Communication 12 12-10-2005 07:00 PM
Finished install on my New Cobra 75 WXST Noliwan GPS & Communication 16 08-16-2005 12:30 PM
Cobra 75 WXST Setup Qs Darx GPS & Communication 22 02-08-2005 05:32 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
