YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-14-2007, 08:23 PM   #1 (permalink)
Help - Receiving Weather Only
I bought a used Pickup with a Cobra CB already installed. Judging by the way the guy wired the sub and amp he probably didn't really know what he was doing...
Anyways, I'm now trying to figure out if the CB itself is bad or if it's just a tuning issue. Here's the run down:
On the receiving end I can only get weather on the weather channel. If I get on the main trucker channels in the area I don't hear any transmissions. All I get is dead silence on all channels.
I don't think I can transmit either as I've done several radio checks on the aforementioned trucker channels and I get nothing in response.
I'm almost positive the PO didn't tune the antenna (Firestik II). I'm planning on getting an SWR meter to tune the antenna, but I'm just wondering if this sounds like a tuning problem or is my CB shot from transmitting without being properly tuned?
Thanks!
aaronk is offline
Sponsored Links
To remove this ad, register today!
Old 09-14-2007, 08:29 PM   #2 (permalink)
bballchrism's Avatar
my friend had the same prob with his cg it turned out to be a his cb radio mount was grounded i think
__________________
1985 4runner just painted Toyota red, marlin crawler bumper, bull bar, bikini top and 4 inch procomp lift, 33x12.5 bfg mt and black steelies
bballchrism is offline
Old 09-15-2007, 01:42 AM   #3 (permalink)
Spanky's Avatar
Send a message via MSN to Spanky Send a message via Yahoo to Spanky
sounds like youre antenna is grounding itself out.
check to see if there is a little plastic washer on where the antenna is mounted. it might be in the wrong spot.
__________________
1992 Toyota Truck 22re 5 Spd (184K and going!)
Magnaflow Highflow Cat
Flowmaster 40 Series Muffler
2.25" Pipes
K&N Air Filter
Airbox Mod, AFM Mod,
2" Body Lift
BFG All Terrain 31x10.50's
American Racing "Chamber" Wheels 15x8
Spanky is offline
Old 09-16-2007, 01:20 PM   #4 (permalink)
Update:
I took off the electrical tape that was covering the antenna connection wires and found that the previous owner had used the metal shielding as a ground wire. I don't know much about this kind of stuff, but that doesn't seem right
Spanky, you can see the plastic washers in the attached pics. I believe those are in the right place as they're preventing the bolt holding the antenna from touching ground.
Based on this, do you guys think I need to buy a coax with a ground cable built-in? I did buy an SWR meter and on Channel 1 it was 1.5 and Channel 40 it was 2. I didn't try and tune the antenna though, I want to at least be able to receive/transmit before I mess with that. One problem at a time...
help-receiving-weather-only-dsc_0552.jpg   help-receiving-weather-only-dsc_0553.jpg
__________________
1994 5spd 22RE 4WD Pickup
aaronk is offline
Old 09-16-2007, 01:30 PM   #5 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
According to the picture, all is well with your ground.
One thing to check, and sometimes it is easy to overlook.
Make sure the squelch is not turned to the right thus blocking any signals from coming in.
I had mine all the way up one time simply by cleaning the rig one time when I was wiping down the whole interior.
I had spun the squelch knob all the way to the right, and it blocked all incoming sound.
__________________
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, roof top tent, so much more, see my website & buildup thread
PNW FJ CruisersDetailing 101Join TopsitesMuffler ComparisonsMaggiolinas In The Wild
FJ Cruiser BuildupNew Roof Top TentVideo Of My PenthouseRehinge Your ARB/Engel Fridge
Corey is offline
Old 09-19-2007, 05:35 PM   #6 (permalink)
Thanks all for the ideas thus far.
Corey - the squelch has been on minimum and I still get nothing.
We've got a semi at work and it's got a CB in it, so I tested mine with the one in that. Turns out I can transmit just fine as I could hear the guy in my truck loud and clear. When I responded on the semi CB the guy in my truck said he could just barely hear me, and that was with the volume all the way up and his ear to the speaker.
Again, the weather comes in nice and clear and if I can crank that pretty darn loud with the volume all the way up. Seems to be a problem with my speaker when on the CB channels though. I'll email Cobra and see what they say, as a faulty CB unit is all I can think of at this point. Or could it be something else?
__________________
aaronk is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
crazy weather Localmotion Off Topic Talk 22 12-05-2005 07:45 AM
Weather Changes Lone4runner Off Topic Talk 22 10-13-2005 10:59 AM
Weather iGGz Off Topic Talk 16 05-14-2005 12:39 PM
Weather here today.... Phssthpok Off Topic Talk 9 03-27-2005 04:07 PM
Inbound weather WolfpackTLC North Carolina 19 09-22-2003 01:25 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
