Firesticks and Antenna Amplifiers - Distance in miles ? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-20-2006, 05:39 AM   #1 (permalink)
Hi
I am curious to learn what type of transmitting and receiving ranges can be had if you add an antenna amp or go with longer firesticks.
Currently I have dual 4 foot firesticks and a simple $130.00 Radio Shack CB with the 7 Wave / Surf reports.
It seems to work good, but am thinking if I get dual 8 footers or longer ( do they make such a thing? )that I can swap in before wheeling or trips I may be better off.
Also how well do those antenna amplifiers work?
what type of range, mileage wise can I expect.
Thanks!
__________________
305k MILES! 97 4Runner Khumo Road Venture MT's 285 75 16's LC wheels,Desert Dune,moonroof,safari rack,kc daylighters,3.4 Ltr. 5 spd,410s detroit ez locker, OME 891's, KYB shocks3 - 3.25 lift, Tokico,Taco springs,3 in lift in front Rev Tek spacers/top out 4Crawler diff drop, 1 in BL, 4 Runner altimeter, 2.5 in Flowmaster,high flow cat, mandrel steel air intake conical K & N. MSD DIS4,CB with 7 channel wave/weather report,4 foot firestick,Pioneer CD,30 gig IPOD.
www.sfaboston.com
BOSTON4RUNNER is offline
Old 12-20-2006, 06:43 AM   #2 (permalink)
An important thing to consider is that dual antennas make your transmission strong front-back but weaker side to side. This is o.k. for truckers that are driving on relatively straight highways, but off-road when you need 360* reception. For omni-directional transmission it is better to have one antenna as high as you can get it, like in the center of your roof.
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 12-20-2006, 07:10 AM   #3 (permalink)
can I simply unscrew one antenna? or do I need to run an entirely new lead?
__________________
www.sfaboston.com
Old 12-20-2006, 07:25 AM   #4 (permalink)
Unscrewing one would have the same effect, but I'm assuming it isn't mounted on your roof, but rather down by your mirrors or something... you might be able to make up for mounting position with a nice long antenna.
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 12-20-2006, 07:33 AM   #5 (permalink)
I have it mounted off my rear bumper...
think I should buy a pair of real long antennas? if so where should I get them online and what do they cost typically? thanks!!!
__________________
www.sfaboston.com
Old 12-20-2006, 07:38 AM   #6 (permalink)
It should be relatively easy to find nice long antennas, perhaps at truck stops or trucker stores. I have seen metal whip ones up to 10 feet long I think. I would check these kinds of stores forst before looking online since shipping would be bad news on an 8 ft. antenna.
Make sure you get your CB's SWR calibrated also. This can make a huge difference in available range of reception and transmission.
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 12-20-2006, 07:46 AM   #7 (permalink)
thanks again
I will check some local places
think I should get two long antennas?
__________________
www.sfaboston.com
Old 12-20-2006, 07:51 AM   #8 (permalink)
Sure why not for highway driving, but make sure to only use one off-road for better omnidirectional reception and transmission. Don't forget SWR either, lots of trucker CB stores can do it for cheap...
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 12-20-2006, 08:01 AM   #9 (permalink)
pennywize's Avatar
amplifiers help tremendously but are illegal. maximum transmit power allowed for a CB is 4 watts per FCC regs.
i once had a 17 foot ( 1\2 wavelength) fiberglass antenna mounted atop a 20 foot mast at my house with a 250 watt amplifier and on good days on SSB (single side band) i could talk to australia.
if your out wheelin' and you have an amplifier, you are going to transmit much further, but everyone else is still runnin 4 watts so they probably wont be able to reply if the distance is far.
like someone said before, i would get a good tunable antenna mounted on the roof in the center and calibrate your SWR.
pennywize is offline
Old 12-20-2006, 08:18 AM   #10 (permalink)
what do you think will work better?
dual firesticks as it is 4 footers
or run a new single lead and use only one of the 4 footers
__________________
www.sfaboston.com
Old 12-20-2006, 08:28 AM   #11 (permalink)
pennywize's Avatar
if it was me personally i would use a single firestick either 2 or 4 foot. get it tuned up and you should be good to go. use only one cable from the radio to the antenna. if it is set up now for 2 antennas replace the cable and run a single.
if it is set up for 2 antennas removing one and keeping the 'split' cable will change the load the transmitter sees and can damage the radio. one cable one antenna.
on my previous toyota i used a single 4 foot, worked great for what i needed.
my $0.02
Old 12-20-2006, 09:21 AM   #12 (permalink)
KD7NAC_07FJ's Avatar
Lets see if this helps.
With the antenna in the middle you have equal field strength all the way around your truck.
in the corner your truck blocks part of the field.
Duals in the back "focus" the field like so
firesticks-antenna-amplifiers-distance-miles-omni.gif   firesticks-antenna-amplifiers-distance-miles-corner.gif   firesticks-antenna-amplifiers-distance-miles-dual.gif
KD7NAC_07FJ is offline
Old 12-20-2006, 10:00 AM   #13 (permalink)
hi
thanks! I just bought a single cable, going to run that tonight
I will leave the dual cable, physically in the rig and leave the other firestick mounted in case I want to swap back, say for a long highway drive or something....
__________________
www.sfaboston.com
Old 12-20-2006, 10:01 AM   #14 (permalink)
how many miles, should this be good for,,,,rough estimate, if set up tuned right etc?
thanks
__________________
www.sfaboston.com
Old 12-20-2006, 10:09 AM   #15 (permalink)
Staff
Lysmachia's Avatar
Send a message via AIM to Lysmachia Send a message via MSN to Lysmachia Send a message via Yahoo to Lysmachia
Any particular reason you want to have such huge range? (Just curious). Also are you up in MA? If so wouldn't a long antenna on your roof get stuck in all the trees while wheeling?
__________________
Molly
aka Lysmachia
93 4 Runner SAS (Tippy) - All Broken in Junk Yard Goodness
Get your 4x4 VIDEO pr0n here
Quote:
Originally Posted by leebee View Post
from this gray haired old red head to you, EGO BOOST!! you go girl!
Lysmachia is offline
Old 12-20-2006, 10:22 AM   #16 (permalink)
dont need a long range, just curious of what they typically get for mileage
alot of my off roading is on beaches and beach areas, me and my friends are always on various parts of the coast checking surf spots, so would be helpful if we could talk via cb, during storms etc
thanks!
__________________
www.sfaboston.com
Old 12-20-2006, 10:23 AM   #17 (permalink)
Quote:
plus I want to talk to my relatives on melzabatron...I am an alien
__________________
www.sfaboston.com
Old 12-20-2006, 10:34 AM   #18 (permalink)
Staff
Lysmachia's Avatar
Bwa Ha Ha! Good answer. If you get ahold of Zork on Archimedes.... let me know!
Yeah often I wish I had better range when we ar ein Moab, because then I would be able to hail and hear some of our other groups across the valley.
__________________
Molly
aka Lysmachia
Old 12-20-2006, 10:50 AM   #19 (permalink)
ewong's Avatar
If you REALLY want range - get a HAM license
Its a tad easier to get a GMRS license (its just $75 I think - and lot of people dont seem to do that) and run a GMRS base. Then everyone uses those "FRS" radios when out of the rig... Set up a repeater in the truck and have a reall communications net
Also - the width seperation for dual antennas to work well is so wide that - well it works on big rigs but not so well on Toyotas... (dont recall the exact width)
CB "linear amps" are illegal.
Best bet for a CB is a center roof mounted antenna with a LONG (1/2 wave) whip - but thats too tall for wheelin.
I use a mag mount Wilson BTW...
SWR will help alot too.
I went and got a Ham license for "long range" talking - or use the cell phone
ewong is offline
Old 12-20-2006, 11:22 AM   #20 (permalink)
4Crawler's Avatar
I think you need approx. 9 feet of antenna separation for dual antennas to work right:
- http://firestik.com/Tech_Docs/SNGL-or-Dual.htm
I used to get pretty good range on my old Uniden GrantXL + 4' FireStick on high power mode. Could get 10-20 miles or so given good line of sight.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-21-2006, 07:58 AM   #21 (permalink)
set up the single firestick, seems to work well
checked the SWR - went by the testing features in the book, it shows to be like 1.3 or 1.4
tons of channels coming in, a world of difference!
thanks alot!!!!
__________________
www.sfaboston.com
Old 12-21-2006, 08:54 AM   #22 (permalink)
Sounds like you got your antenna tuned pretty good. You asked about what kind of range you can expect with your radio. Your range in the AM bands (CB) will depend a lot of your surroundings. Line of sight on a good non-solar activity day with your 5 watt legal limit you might get 10 miles maybe a bit more.
Start throwing in trees, hills, mountains, buildings and the like and your range diminishes to about line of sight period. Radio is conductive so you can be at one end of a valley and talk to someone 10 or 15 miles at the other end of the valley especially if there is a river running through it. The point is there are a lot of factors effecting radio transmission.
If you really want to understand radio theory take an Armature (ham) Radio course and get your license then you can easily talk around the world from your rig
If you do I'm KD7NAC on the Pilchuck repeater 146.920- Everett, WA
Old 12-23-2006, 08:56 PM   #23 (permalink)
big sky trapper's Avatar
Best advice on the thread...get licenced! A whole new world of comunications will open up to you from the whole world to satelite!
KD7CGL....Central Montana.
__________________
Big Sky Trapper
www.outtasightcustomcamo.net
big sky trapper is offline
Old 12-28-2006, 10:29 PM   #24 (permalink)
NC99T4R's Avatar
MAg mount wilson 1000 will extend your ground plane which will more 360 than directional front to back. A good radio like a 10 meter worked to run AM and upper and lowers can be tuned to 40-50 watts output. As for linear amps, if your moving and not giving your exact location the FCC has a hard time trianglulating your position. In my area unless your putting out 40 watts extra power is needed. I can run 44watts, 400plus or run amps off a 12\6v set up and can get 1000watts, which gets blow out here along the coast with skip. the more you add for power the more tunning you need b/c the SWR's will jump. Also the more power you have you can pull up to a thump thump ride key down and make his speakers squeal and tell them the cut the crap down. I've got friend's with four alternators to run everything and push 5k watts ina suburban
__________________
Proper Prior Planning Prevents Piss Poor Performance...the 7 P's
NC99T4R is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What is the most you've towed any distance? yamarocket630 Off Topic Talk 42 10-31-2007 12:22 AM
Going the Distance sirrdavid Maintenance & Repair Archives 2 07-28-2005 08:26 AM
Braking distance 4unner4life 95.5-2004 Tacomas & 96-2002 4Runners 3 07-13-2005 11:51 AM
Distance to work? jimstoy Off Topic Talk 9 11-29-2004 06:02 AM
Opinion on MA Audio Amplifiers? DavidA Vehicle Audio & Home Entertainment 4 07-09-2004 07:44 AM
2009 InternetBrands, Inc.
