Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Engine Noise in CB
So I've got my Cobra and Firestik installed. I've tuned it with an SWR meter and I'm between 1.0 and 1.4 on all channels. I can transmit and receive fine but the only problem I am having is a very high level of noise/static in the system when the truck is running. When the truck is off or idling, I get static on 2/6 bars on the signal meter (normal). When the truck is on and under load I am getting 4-5/6 bars, making it so that only the very strongest signals can come through clearly. With the engine under load, I have to squelch almost 75% to stop the noise, which of course allows very few signals through.
So here is my setup to answer as a precursor... - Radio wired into cigarette lighter positive line, grounded to seat bolt, seat bolt grounded to unpainted frame. - Antenna mount grounded directly to unpainted section of frame (also contacts unpainted section of body) My only thoughts at this point is that both of these grounds do contact the body at some point (the cb through the seat bolt and the antenna mount through the unpainted area where it is mounted)... perhaps the body has a band ground? Is it possible for the ground to be bad enough that the frame is transmitting interference? Any help here would be greatly appreciated... thanks! Here is a pic that might help: ![]() |
| Sponsored Links |
#2 (permalink) |
wiring your cb into your cig lighter power lead is one of your problems. Run the positive and negative directly to the battery and it will prob eliminate a lot of the noise your hearing. if that doesnt help then try an inline filter
__________________
1984 toyota sr5 4x4 22r w/ weber 32/36 Pro comp 4" front springs and 3" rear downey springs D-tech Shocks 33x12.5 M/T , 15 inch weld rims Hella 550/ Hella h4 conversions with HID Home made On-board air system Last edited by deserttoy84 : 09-24-2007 at 12:12 PM. |
#3 (permalink) |
Also, you might want to look into different spark plug wires. But even with the wires you have, a filter should work.
#4 (permalink) |
On my '85, I eliminated the ignition noise by two things.
1. Run power (fused) and ground wires from the battery, twisted together as they run back to the cab. Those wires feed only the CB, CD player and regular radio. Wires run away from igintion wires. 2. Install a noise filter inside the cab, before the power wires run to the radio. The real key is to minimize ground loops. By having the CB ground wire up at the battery, there can be no difference in ground voltage that you may see with an in-cab ground point. Also, if the above don't work, it may be the CB itself. I had one cheap CB that was noisy no matter how you set it up with the engine running. I finally moved that to my VW diesel where it worked fine (no iginition noise in a diesel). However, it was interesting that that CB would get noisy if a gas engine vehicle pulled up next to me at a stop light. So it must have just been a poorly shileded radio.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| engine noise in cb... really wierd | deserttoy84 | GPS & Communication | 3 | 08-20-2007 12:29 AM |
| CB picking up engine noise? | Kiff | 86-95 Trucks & 4Runners | 7 | 07-26-2007 05:52 AM |
| Whining noise thru cb speaker | Ironmike4x4 | GPS & Communication | 12 | 10-12-2006 12:05 AM |
| lotsa noise from my CB | HawkFanatic | GPS & Communication | 5 | 07-24-2005 02:44 PM |
| Alot of engine noise in my CB while driving ! | Stegall984R | GPS & Communication | 3 | 02-19-2005 04:22 PM |
