Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
COAX cable routing for rear mounted CB antenna
So I'm putting a Cobra 19 in my ashtray slot and I was wondering how people routed there 18' of COAX to get to the back of the car. I'm getting the door jamb kit from firestik to mount my antenna on the right rear of the tailgate door jamb. How have you guys also powered your CB? I'm thinking of pulling straight from the battery, with an aftermarket fuse box in the engine compartment. What do you guys think? Thanks in advance for your ideas and advice.
Greg
__________________
NOR*CAL <IXOYE>< My Truck: '93 4Runner SR5 4X4, 3.0 V6, auto, removed foot boards and mud flaps, Flowmaster 40 w/ turndown, Cobra 19 Ultra III, 4' Firestik II, Hayden tranny cooler, Black steelies, HELLA 500's. www.noebrosracing.com -Some of my photography. MySpace |
| Sponsored Links |
#2 (permalink) |
I probably should have told you guys what I have. '93 4Runner SR5. Yes, I have done the search on this topic, and haven't found anything that really covered the subject.
__________________
#3 (permalink) |
I'd run power straight off the battery. its nice to be able to sit in camp with the CB on and not have to have keys in it. (the beer opener is on my key ring....
)as for the coax, pull the trim molding along the bottom and run it under the carpet. once its to the cargo area run it behind the plastic interior panel. that part can be a bitch to get off but it will pop off after you take out the rear seat belt bolt and the top part in the rear with the tweaters and dome light
__________________
3genRunner: including parts from 3 generations of 4runners, '92 pickup, '80something Land Cruiser, Chevy truck, Ford sedan 89 4runner: Project DD. 3.0, needs a new tranny 81 2wd pickup: 22R | 5-sp | long bed | quad hauler, leaks oil but gets 26mpg 91 Honda Prelude: the Daily Driver WA, OR or CA wheeler?? Check out pacific-crawlers.com and check out yotaworks.com Last edited by Tofer : 03-22-2007 at 01:02 PM. |
#4 (permalink) |
i just tapped into the memory power wire(which comes straight from the battery) and ground for my stereo.
#5 (permalink) |
Muddog, do you have any whine from the alternator from pulling off of the memory wire? Is that wire in the wiring harness or is it on its own and do you need the keys in the ignition to run the CB?
__________________
#6 (permalink) |
Along the door jamb works well. But if you have multiple lines like speakers/amp power lines running along there you can get interference at some point. I actually ran mine along the transmission tunnel *removed the seat* and back, cutting across under the rear seat and then under the plastic trim panel along the cargo area.
I pulled mine to a coil inside the storage compartment on the passenger side for the time being. this way I have several options for future antennas. The door jamb, or something mounted to the factory spare carrier.
__________________
1990 4Runner V6 SR5, "The Porkchop Express" "I'm just like every other normal guy, except I hit the speedbumps at 50, sometimes 60 miles per hour."
#7 (permalink) |
for my stereo i ran an extra power wire straight from the battery, i do get some whine but i beleive its just the radio setup, which isnt very good, that is causing it.
#8 (permalink) | |
Quote:
http://www.jcwhitney.com/autoparts/S...1&sku=mh037093 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Where Is Your CB Antenna Mounted? | Yota Tony | General Electrical & Lighting Related Topics | 17 | 02-22-2007 02:43 PM |
| coax cable | 90runnner | Misc Stuff (Vehicle Related) | 0 | 05-29-2006 02:36 PM |
| Where to run cb antenna wire when mounted on r/rack? | skshepherd | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-29-2004 08:22 AM |
| Bought my CB and mounted antenna! | StoryR | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 07-23-2003 01:45 PM |
| Running CB coax next to 4awg (power cable)---good idea or not? | Bob_98SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-02-2003 10:00 AM |
