YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-16-2007, 10:28 PM   #1 (permalink)
Hayes's Avatar
Send a message via AIM to Hayes
cb worked when removed and now it doesn't
I installed my CB and it workeed flawless. I snipped the wires so that I could install a quick connect, got it all set up and it doesn't work. Took it all apart, checked the fuse, etc, etc. All the lines are run properly and now it still doesn't work.
I'm out of ideas and I need the CB for tomorrow...
I'm going to go to the shop I bought it from and see if they have any ideas, but any help would be appreciated.
__________________
-Hayes
Hayes is offline
Sponsored Links
To remove this ad, register today!
Old 05-16-2007, 10:34 PM   #2 (permalink)
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
Send a message via AIM to drguitarum2005
is there no power at all? try checking the battery ends of your quick connects to see if theres a circuit, if there is, either something coincidentally fried in the cb (not likely) or something on the cb end of the quick connects
__________________
-David
2000 Taco TRD Access Cab
v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights
Pictures
drguitarum2005 is offline
Old 05-17-2007, 06:05 AM   #3 (permalink)
Hayes's Avatar
all the ends are connected...crap
__________________
-Hayes
Hayes is offline
Old 05-17-2007, 08:28 AM   #4 (permalink)
TXST8tj's Avatar
Send a message via AIM to TXST8tj
did you wire it straight to the battery? or another location?
in my jeep, i had my CB wired with a quick disconnect so i could take it in and out to avoid theives. i also wired a switch inline with the power wire to cut the power before the quick disconnect so i would not blow fuses. once the metal ends of the disconnect touch, they are just like bare wires touching and will generally blow the fuse. by flipping the switch and cutting the power, i was able to disconnect and connect without that connection having any juice. i.e., flip the switch to "off" to disconnect, that way you don't touch something in the process. also, when it's time to put it back in and reconnect, the line will not have any power, so you will be ready to connect without having to remember to flip the switch to "off". once it's all connected, flip the switch back to "on" and you're ready to rock and roll. the more connections and splices you make with a CB, they more interferance you risk; however, i would rather risk that over blowing fuses everytime i take it in and out.
__________________
2007 4Runner SR5
2002 Jeep Wrangler Sport
1995 Ford Ranger XLT
TXST8tj is offline
Old 05-17-2007, 01:11 PM   #5 (permalink)
Hayes's Avatar
That must be my problem. Got a new fuse and all is well!
__________________
-Hayes
Hayes is offline
Old 05-18-2007, 02:23 AM   #6 (permalink)
the in line switch is a great idea! i have a quick-disconnect for my radio as well (makes it quick to remove when servicing vehicle, etc...) but i never thought about the bare ends in the quick-discos causing problems. thanks for the great idea! got a project to work on this weekend now...
Merlin is offline
Old 05-18-2007, 03:56 PM   #7 (permalink)
TXST8tj's Avatar
i used a very simple (and cheap) switch. i mounted it under the dash in the jeep because it wasn't something i felt like i needed to permanently drill a hole and mount somewhere. if i had a full switch panel or something, i could see doing it.
__________________
2007 4Runner SR5
TXST8tj is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
I guess it worked... phorunninduke Off Topic Talk 20 02-13-2007 08:45 PM
anybody ever worked at a carmax before? neliconcept Off Topic Talk 1 07-19-2006 12:05 PM
Anyone ever worked at Harbor Freight? rwmorrisonjr Off Topic Talk 2 01-25-2006 09:29 PM
Help from anyone who has worked on a Dash funglenn 95.5-2004 Tacomas & 96-2002 4Runners 12 03-27-2005 07:38 AM
I dont know what I did... but it worked Hatchtec 95.5-2004 Tacomas & 96-2002 4Runners 3 06-27-2004 07:39 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
