Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
cb style radio antenna...do-able?
so if my current radio (yeah, like the music kind of radio) antenna sucks equine testes, and i wanna get a new one, but i think i can get better reception doing a custom-ish fiberglass rod wire-wrapped CB style one.... could this be easily doable? i'm asking this question here cause there seem to be a lot of knowledgable folks, but truthfully, i'm asking for my other vehicle, not my toyota truck. thanks, guys
__________________
93 pickup, ext. cab, 4x4, 3.0, 5spd, 230k miles, 31x10.5x15 general grabber at2 tires on factory steels, factory toyota canopy, manual hubs. |
| Sponsored Links |
#2 (permalink) |
firestik sells an adapther that uses your cb antenna as an am/fm radio antenna also.
#3 (permalink) |
You can use a regular cb antenna. Then get a cable that's got the proper end for your radio.
__________________
Anthony 93 ZJ - Stockish (HP D60 Front, 14 Bolt Rear, 231/D300 Crawl Box...awaiting 40" tires) Ballistic Crap Missile ILikeMud.net Mallcrawlin.com SOTRA |
#4 (permalink) |
i would look around more cause i know you can damage a cb if you don't use a proper antenna. something about the frequencies have to be compatible i think.
__________________
Tim ___________________________________________ 1994 4Runner | 3.slow Auto | 31" Bridgeston Dueler AT's | Bilsteins | Downey HD Kit | ARB Bumper | Warn M8000 | 2 KC's on the ARB |
#5 (permalink) |
He wants to use a CB antenna with his AM/FM radio. Not a AM/FM antenna with a CB radio.
__________________
#6 (permalink) |
The CB antenna will work great for your AM stations and, in fact, is used by many truckers for that very reason to pull in the weak stations. On FM it will be adequate when you are near the transmitter, but not nearly as good as if you have a antenna tuned for the FM band.
Maybe it's time to start thinking XM. ![]()
__________________
2001 Toyota Tacoma DBL cab.TRD Off Road. ISR & Deckplate. XM/Sirius. VHF/UHF/HF Radio, Laptop & GPS Mounts. FlexFuel Conversion. ------------- Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out screaming "WOO HOO, WHAT A RIDE !!" Last edited by Baloo : 04-18-2007 at 02:19 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| cb antenna for fm radio | CGOULET | Vehicle Audio & Home Entertainment | 2 | 10-26-2007 04:19 PM |
| 4runner cb radio antenna | 91muddog | 86-95 Trucks & 4Runners | 11 | 05-08-2007 10:29 PM |
| CB Radio & Antenna Installation - 97 4Runner | Bob_98SR5 | Electrical | 0 | 01-02-2006 12:00 PM |
| CB Radio & Antenna...Finally! | HBoss | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 07-17-2002 12:10 PM |
