GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB range issues.
Old 03-13-2013, 09:42 PM
branw97469's Avatar
CB range issues.
I've got a uniden pro520xl with a 3' firestik mounted to the side of my truck box. I can hear people clearly from about a mile away, maybe less. But they can't hear me past 100 yards. I need a couple mile range at least. Any pointers? I was thinking about getting a tunable 5' firestik tomorrow. I don't have an swr meter so I can't really test it.
Old 03-14-2013, 01:12 PM
swampfox's Avatar
Was the coax a pre-made piece or did you put the ends on it ? cheap coax can cause different problems.The antenna and radio should work fine for what you want. If atmospheric conditions are wrong or skip as it is called will cut the range a lot.
Old 03-14-2013, 01:18 PM
branw97469's Avatar
It's the pre-made coax. You just screw it in.
Old 03-14-2013, 03:48 PM
swampfox's Avatar
When people can hear you up close is your voice strong or weak ? It might be a mic issue.
zombie_barbarossa
10-02-2015 10:54 PM
whiteyota93
09-29-2015 02:31 PM
JPV
09-28-2015 03:15 PM
charlie_fong
09-27-2015 10:06 PM
rmill05
09-27-2015 01:43 PM
Quick Reply: CB range issues.
