YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-02-2007, 09:06 PM   #1 (permalink)
Unhappy CB radio confusion, and antenna help?
I would like to get a cb radio. I don't like to spend a lot of money on stuff like this. I found a Cobra 19 at wal-mart for 35$. I am probaly going to purchase this radio. I am having problems with the antenna's, mounting them, and these coax cable things?
I found this sweet mount.
http://www.premiere-electronics.net/...nnamounts.html
Maybe this antenna?
http://www.radioshack.com/product/in...entPage=search
And some cable?
http://www.premiere-electronics.net/...coaxcable.html
There site says for best reception use 18ft cable!! Thats incredibly long. Where would I put all of that?
I just need guided in the correct direction. please
__________________
To be old and wise, you must first be young and stupid
Adawg_08 is offline
Sponsored Links
To remove this ad, register today!
Old 08-02-2007, 11:02 PM   #2 (permalink)
olharleyman's Avatar
For coax you want to do it in 3 ft. sections and yes 18 ft is best for all around input and output. If you go with 18 ft.(good idea) take the excess and twist it into a figure 8 and zip tie it then just stuff it out of site.
For an antenna go with a Wilson or Firestick but make sure you get a adjustable tip 3-5ft should be plenty. Try to stay to the middle of the vehicle for a good ground plain and it also helps keep from it hitting overhead obstacles.
As for mounting is this going on a truck or 4runner??? if its going on a truck where the bed meets the cab drill a hole to mount it in the lip of the bed and mount it there bring the coax from the cab along the frame and back up to the mount on the bed. If its a 4runner what i did was on my tire rack I placed a mount in the middle of it on the top bar and ran the coax from the cab to along the frame and back up to the right taillight and across the bottom bar of the rack to the middle bar and to the antenna. Also old truck driver trick is to put a small hole in a tennis ball and run it down to the point most likely to hit anything and it will take the blunt of the hit and not do damage to paint or in my case crack the rear window.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
Streached 5.5 gal. tanks
16" Ape Hangers
3" open primary
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 08-03-2007, 01:53 AM   #3 (permalink)
drew303's Avatar
I agree 100% with olharley =)
18ft is right,, just figure 8 it somehwere. I used 18ft under my rig and figure 8'd it under there... i have a 3ft firestik and a Cobra nitewatch CB.
I also purched a sWR meter to tune it all in( you NEEd a SWR meter to properly adjust ANY antenna).
make sure you ground the CB and the antenna well.
goodluck
__________________
1987 Toyota P/U 4x4 pics/info
drew303 is offline
Old 08-04-2007, 03:20 PM   #4 (permalink)
So you run the 18ft of wire outside the vehicle? I wanted to put it under my carpet? I that antenna very flexable? I need to be able to hold it down when I pull into the garage. (not every night, just when it gets worked on)
__________________
Adawg_08 is offline
Old 08-20-2007, 12:00 AM   #5 (permalink)
Zodiac's Avatar
the little cobra 19 is a ok radio im more into the big stuff .....lol
$35 bucks is a far deal for it you know i would run a lil wil antenna from wilson
its a mag mount and work really well and run around $25-30
you dont to have to run 18' it dose go in 3' so 3 ,6 ,9, 12,15,18
i have tons or rg-8x and mini 8 i can cut in 3 ,6 ,9, 12,15,18 foot
Zodiac is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
cb antenna for fm radio CGOULET Vehicle Audio & Home Entertainment 2 10-26-2007 04:19 PM
4runner cb radio antenna 91muddog 86-95 Trucks & 4Runners 11 05-08-2007 10:29 PM
cb style radio antenna...do-able? MattInTheCouv GPS & Communication 6 04-18-2007 10:27 PM
CB Radio & Antenna Installation - 97 4Runner Bob_98SR5 Electrical 0 01-02-2006 12:00 PM
CB Radio & Antenna...Finally! HBoss 95.5-2004 Tacomas & 96-2002 4Runners 8 07-17-2002 12:10 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
