YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-23-2007, 06:34 PM   #1 (permalink)
killa b's Avatar
cb radio?
ok me and a buddy got our cbs installed and we cant seem to comunicate with them is there anything were missing or not doing correctly thanks
killa b is offline
Sponsored Links
To remove this ad, register today!
Old 09-23-2007, 07:43 PM   #2 (permalink)
cubcilecaptive's Avatar
Are they turned on? Tuned to same channel? just kidding...
Check your grounds. What type and model of antenna are you each running (mag mount/Firestick/steel whip)? Did you "tune" them with a meter? Can you hear anything on your radio (another person rather than your buddy)? What model CB?
__________________
Greg S. NWA
1995 FZJ80, slee'd, arb'd, ome'd, snorkled, winch'd, 315'd
1998 3rd Gen SR5 Limited-son's
I don't want to talk about paper on my off time...or my work time.
cubcilecaptive is offline
Old 09-24-2007, 05:12 PM   #3 (permalink)
killa b's Avatar
i have a steel whip atena and im not sure what he has. i have a cobra not sure what model and they are not tuned. shouldnt we atleast hear something and i have not been able to hear any body on mine at all. any help would be appricated thanks
killa b is offline
Old 09-24-2007, 05:36 PM   #4 (permalink)
Gator's Avatar
you may have already burned up the finals trying to use it. Find someone close by that knows how to tune an antennae. They will be able to tell you for sure.
__________________
Current Setup: 94 X-Cab 4x4 w/ 3.0, Auto, 1.5" BJS & Shackles, 33x12.5-15 BFG MT's, Detroit locker w/ 4.88 gears, ISR and Air Box mods.
Future Mods: Armor, winch, 12v Air Compressor & tank.
Lottery Mods: 4.3L w/ 4L60-E tranny swap, SAS w/ Detroit locker, Budbuilt Crossmember.
Gator is offline
Old 09-24-2007, 05:41 PM   #5 (permalink)
killa b's Avatar
what are those finals that i might have burent up. are there any shops that might be able to tune it. im preaty clueless about all of this but thanks for the help
killa b is offline
Old 09-24-2007, 05:51 PM   #6 (permalink)
KevinInSac's Avatar
Send a message via AIM to KevinInSac
Try to find a local truck stop. They should know of a good local place or two.
Try the weather channels, if you can get them. That way you can determine if you can recieve at all.
Make sure your squelch isn't maxed out, it'll block everything out...
Also, make sure your RF gain isn't turned down all the way, you won't be able to pick anything up.
__________________
92 ExCab Pickup SR5 3.0 5spd 4X4 Pretty much stock. I've done some stuff though.
KevinInSac is offline
Old 09-24-2007, 06:00 PM   #7 (permalink)
Gator's Avatar
Here is some basic info on what SWR is:
http://www.firestik.com/Tech_Docs/swr-intro.htm
They mention the use of dual antennas, but don't even think about it unless you are driving Tractor trailer rigs with at least 8' between antennas. There's entire forums dedicated to that whole argument.
__________________
Gator is offline
Old 09-25-2007, 04:34 PM   #8 (permalink)
killa b's Avatar
ok lookin at my cb and i have a swr cal knob does this do me any good.
killa b is offline
Old 09-25-2007, 04:40 PM   #9 (permalink)
KevinInSac's Avatar
That's the easiest way. So follow the instructions on firestik, and watch that meter.
__________________
Old 09-25-2007, 08:07 PM   #10 (permalink)
killa b's Avatar
ok got it workin i figured out i can calbrate the cb with the swr knob it even has a gauge on the cb thanks for all of the help.
killa b is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Best Cb radio shantz GPS & Communication 8 05-28-2008 10:40 AM
CB radio help! kent GPS & Communication 14 09-25-2007 11:10 AM
CB 40F Toyota OE CB Radio MaddMaxx Items Wanted 0 04-06-2006 09:58 PM
CB Radio uses? fiveofeen GPS & Communication 32 05-11-2005 02:55 PM
CB Radio Albuquerque Jim 95.5-2004 Tacomas & 96-2002 4Runners 10 08-06-2003 12:42 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
