| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | ||||||
cb questions
__________________
1987 4runner 22RE cupholders! 05 Tundra 16in aluminum rims BFG ATs Quote:
#2 (permalink) |
yeah sounds like that would be a good spot to put it on
__________________
85 4runner 4x4,3.slow v6 EFI auto,45k miles on rebuilt engine & tranny,SAS,dual magnaflow exhaust straight pipe,sunroof,billet grille,lifted,37" nitto mud tires,92 front bumper,shaved door handles & side marker lights,custom two tone paint job DD 2001 Tacoma Prerunner TRD ext cab,bf Goodrich all terrains,blacked out rims |
#3 (permalink) |
First off I,m a CB geek from way back!!!! Your best bet for performance is a Wilson 1000 mag mount smack in the center of your cab where its metal, you'll get some decent reflect off the metal of the vehicle. My personal opinion is the 102 inch whip looks cool and all but mounted at the rear won't give you the preformance that you can get with the Wilson. I guess it depends on what you want to do with your CB??? If it's short distance yaking ok , but if you want to "Get Out" you got to go for what works the best. Any CB radio is only as good as it's antenna, that is the heart and soul of the radio, also upon installation you have to adjust that baby with an SWR meter. The wilson mag mount will not blow off and tree branchs don,t bother mine. It's a strong magnet, unlike the cheapys you can buy at auto parts stores. It costs around 70 bucks but well worth it. Good luck!! Love CB radio,s!
Pigman |
#4 (permalink) |
Staff
102" whip? Are you nuts?
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#5 (permalink) |
Everyone needs an 8.5-foot whip flopping around on top!
__________________
'87 T4R Deluxe, mall crawler every non-SR5 option installed (sans AT), as well as: * Cruise Control (dealer installed) * Michelin LTX A/T2 31s on 1st-gen alloy rims * SmittyBilt granny step bar * SR5 Instrument Cluster |
#6 (permalink) |
The Wilson 1000 is 63 inchs high, not like a 102 inch whip up on top, sorry I forgot to mention it's height. But I know guys that run those 102 inchers right up on top, not exactly what I would want. Drop by cbradiotalk.com lots of good info and such. Will definitley get you up to speed on newer CB radio techniques.
Pigman |
#7 (permalink) | |
That's what's on my 1st gen. Although it's on the bed on the driver's side. But the meter liked it and on the roof was not an option for me.
__________________
Quote:
#8 (permalink) |
you'd probably want a pretty sturdy mount if you're going to use a 102" whip and spring combo, esp. if you're going to put it over the taillight area. if you're just going to drill into the metal (not mount it in the gap for the hatch) i'd probably reinforce it with something behind the sheetmetal as well.
and yeah, you *could* "poof the roof", but that's kind of overkill, IMHO. we do that for keydown vehicles that mount fighting sticks, but we also add extra sheetmetal under the roof skin for reinforcement. probably not something you want to do for a DD. i usually just bumper mount my 102" whips to either the bumper (drill that puppy) or to a mount that either bolts to the bumper or frame (or both). i can still get pretty flat SWRs and good tx/rx. a hustler quick-disconnect makes getting into and out or parking garage a two-second matter. any particular reason you are set on the 102" whip? the wilson 1000 suggested is also a very good choice, can handle way more power than your stock electrical system can provide it, and can be easily removed for parking garages, etc... and if you REALLY intend to get crazy with the power (note - anything over the FCC limit is technically illegal) then the wilson 5000 roof mount or mag mount can handle crazy, stupid amounts of power... way more than a stock electrical system can support. guys that run these often run multiple alts, a rack of batteries, and/or a maul. |
#9 (permalink) | |
thanks guys. i have a pretty sturdy mount and it is reinforced with a plate behind the sheet metal. what about grounding the antenna? the is some kind of grommet between the antenna and mount, doesnt that prevent a ground?
currently i just have a cheap radioshack 4ft fiberglass antenna and was planning to upgrade to the 102 which would be secured when not in constant use. the antenna is a cost issue as im a fairly broke college kid. i might even just keep the fb antenna but i feel like its gonna break even with the spring on it.
__________________
#10 (permalink) |
I've used a bumper mounted 102" whip on my old truck. The mount was bolted to the bumper. I used fishing line to hold it forward when traveling(kind of a pain). But the 102 whip is so flexible that I didn't even need a spring to bend it forward. It looked cool, but I had much better luck with a roof mounted K40 whip. The Wilson whip is also nice, but I chose the K40 because it's easily removable when you need to enter a garage or something. A few other tips: watch your cable routing, use good quality coax, and invest in an SWR meter.
__________________
Toyotas: 2000 4Runner SR5 4x4: 126K miles 2004 Tacoma 4x4 Ext Cab V6 TRD - sold 1-2006 - totaled 1-2009! 1992 HiLux 4x4 reg cab - sold 1-2005 1984 HiLux 4x4 reg cab - totaled 7-1997 |
#11 (permalink) | ||
Quote:
Quote:
i thought it was going to break and throw fiberglass shrapnel all over the garage (i was ducking for cover) but it just kept bending. raised the door up, ant. popped up, checked swr, etc... and all was fine. |
#12 (permalink) | |
finally got everything installed, pics later. i stuck with the 4ft fiberglass, who really needs a 102 whip? checked it with an swr meter and got about 1.7 without any adjustment. im happy. thanks for the input!
__________________
#13 (permalink) |
Predator 10k beats any antenna Ive used including the 108" whip.
However its a trick to make it tree friendly. I mounted mine on a spring and its tuned flat both on 40 and 1. Steve at Sonoran Steel made me a custom bed mount |
#14 (permalink) | |
Quote:
and yeah, they are loads easier to tune than a 102" whip. |
#15 (permalink) | |
Quote:
haven't tree tested them yet since they're kinda pricy to go tree trimming, though. |
#16 (permalink) | |
Quote:
I've run just about every kind of popular antenna you can buy over the years. The absolute best antenna I found was 96" fiberglass tapered whip. I paid $22 for it in 1977. I ran it on 4 different trucks, and I still have it. I 4-wheeled heavily those days and never had a problem with it. It mounted to the front bumper, then I mounted it in the middle of the bed rail just behind the cab. I did not use a spring at the mount. I once mounted it at the rear tail light. As long as your antenna selection is top loaded and about 12" of the whip is above your vehicle you should be fine. Unless you one of those guys that likes to talk skip and impress a bunch of idiots, your set up will probably be great. Running the radio ground and hot lead directly to the battery terminals is very smart. The steel whips will "pick up" or receive better than most antennas. That's Just My Worthless Opinion, gNARLS. Last edited by Gnarly4X; 10-16-2009 at 05:33 AM. |
#17 (permalink) | |
Quote:
gNARLS. |
#18 (permalink) | |
Quote:
- http://www.firestik.com/Tech_Docs/swr-intro.htm
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#19 (permalink) |
I have used 102 whips they are great. the firesticks with the tunable end with the red tip they work as long as you dont run power the red tip blows up like a balloon and then melt. I know you got it done good job I am just trying to give you some more info for next time. The reason people mount in the center of the rig is because you get a even ground plane you shoot in all directions. if you mount on the back passenger side your strongest signal will go drivers side front. With that think about you have a firestick just sticking over the top a few inches the rest of the firestick is not being used because it is reflected from the back of the rig and will die off raising you swr from reflection going back into the firestick you want to try to get the ant as high over the rig as you can. Hope this helps. And the best antenna is a crank up tower mounted in the bed of a old toyota pickup on a mountain...
#20 (permalink) |
One thing to consider with the 102" whips is that off road, they can flop around a lot (if not tied down) and that might be a hazard to people beside the trail. In can the CA4WDC organized runs usually impose a limit of 52" on CB antenna lengths because of this.
__________________
#21 (permalink) |
I'm running a 102" whip on my truck mounted right behind the drivers side on my bed rail, works great and my SWR meter reads a perfect 1.0. besides I love the look
#22 (permalink) |
where do you get SWR meters at? i havea 4' fiberglass antenna mounted in the pass side bed rail and i dont ever get a signal. does the antenna itself need to be grounded or not? and i ran the hot wire of the cb to the hotwire that is under the dash when the key is on. is this ok?
__________________
93 xtra cab, 3vze, 5speed, 31x10.5x15 bfg M/T KM2 hella 500ff. cobra cb, front and rear diff breather mod, many more coming! |
#23 (permalink) |
I got mine at Radio Shack, on sale they are pretty reasonable. Or if you have a good CB shop locally, they will often test your antenna at no charge. Antenna ground depends on the antenna design:
- http://www.firestik.com/Tech_Docs/Mnt-Grnd.htm
__________________
#24 (permalink) |
i got a swr off ebay for like 10 bucks yea i had a 102'' whip for a little while its now in the shop next to the 4ft firestik i went with a 3ft wilson
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods Mom 07 Tundra d-cab limited 5.7L 4x4 auto sister 92 pickup SR5 X-cab 3.0L 5spd 4x4 Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck Last edited by Elton; 11-06-2009 at 04:23 PM. |
#25 (permalink) |
I have a new 40 channel Midland 1001z radio that I installed under the dash of my 01 Ford Ranger Edge. The antenna is a K40 Center load mounted in the center of the truck bed between the cab and truck bed. I ran an SWR test of channel 1, 19 and 40 as directed and got: Channel 1 1.8 Channel 19 1.8 and Channel 40 high 3's
I can hear others and tried getting a radio check and got nothing. MY rf gain is set correctly. I have been researching about antenna's and will prob get me a top loaded one "Firestik:. also will get a power mic. but in the meantime I have been working on this for two days. Need step by step help in my system. The antenna mount is very sturdy, its an aluminum, grounded to the bed of the truck. DO I need another ground??? or another radio?? (revert to smoke signals hahahaha) Need your help.. |
| Tags |
| 1000, 102, bumper, cb, distance, fighting, inch, keydown, mag, mount, questions, sticks, truck, whip, wilson |
