GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB only buzzes?
Old 12-16-2010, 10:48 PM
DirtyOregonKid's Avatar
CB only buzzes?
Cobra 25, 7' firestik, 18' coax with fire-ring. Mounted on the back of my 87 4runner. I got the radio second hand but all the other parts are brand new. I don't know if the radio is broken or if I missed something on the install. I assumed it was all hooked up but I can't get anything but a low buzz from the speaker..
Old 12-16-2010, 10:59 PM
Elton's Avatar
try unhooking the antenna see if that helps ive got a swr meter if you haven't tuned the antenna yet
Old 12-16-2010, 11:08 PM
I just put it all together the other day. I read someplace that using a cb without the antenna can fry it. .
Old 12-16-2010, 11:13 PM
Elton's Avatar
same goes for having a antenna out of tune
Old 12-17-2010, 09:58 PM
Elton's Avatar
any luck ?
Old 12-17-2010, 10:04 PM
muddpigg's Avatar
Can you turn the squelch up?
Old 12-17-2010, 10:47 PM
I work a lot so I haven't had a chance to mess with it again. Adjusting squelch doesn't do anything. I hope to play with it again tomorrow morning. I'll check my connections again for the 4th time. If I still can't get anything I'll try to find someone local with a working head unit that can help me test things.
Old 12-17-2010, 10:50 PM
Elton's Avatar
i should be in albany 2morrow ill shot you a pm with my number
bvleonov
08-22-2015 11:39 PM
JHalcyonM
08-04-2015 01:19 PM
tuquoque
02-17-2004 03:12 PM
X-AWDriver
13
01-28-2004 06:11 AM
Quick Reply: CB only buzzes?
