CB Install Help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-12-2007, 05:43 PM   #1 (permalink)
CJM
CJM's Avatar
Post CB Install Help
Just nabbed a cobra 19 ultra III at wally world, and I wanted to install it in my 96 T100.
I dont wanna run it from the battery, I want to tap the cig lighter for power..I dont ever use it so I think its good and less complicate and I dont have to worry about my wires melting from the heat of the engine.
Now bear with me, but I take a voltmeter (multimeter,whatever) and check the wires till I find one thats hot and tap that. Then of course I ground the black to the sheetmetal that is all behind my dash..
I mean I can wire stuff, but usually houses are different than cars...
Thanks
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 04-12-2007, 10:25 PM   #2 (permalink)
You could save yourself some time and trouble and tap the hot wire from the fuse block under the dash (hot when ignition is on, so you don't leave your radio on overnight) and then ground to bolt under dash.
If you don't want to do that, what my friend did is take apart the center console, remove cigarette lighter plug housing, and tap power and ground wires from that. Then reinstall plug housing, and you get a factory-looking clean install. He doesn't smoke, so no need to worry about overloading the circuit by actually using the plug as a lighter.
Merlin is offline
Old 04-12-2007, 10:37 PM   #3 (permalink)
91TPU's Avatar
Send a message via AIM to 91TPU
i thinking about the same thing, running power off the cig lighter, figure ground it to some clean metal, then run the hot to the cb...should be that simple, mine wont be any high tech model
__________________
87' 4runner...22re...31" Bridgestone Dueler AT-New project rig and winter dd.
91' 3vze...190k...31" BFG All Terrain's...K&N FIPK-SOLD
07' Civic Si-The Daily Driver.
Quote:
Originally Posted by Sonofmayhem View Post
god hates you.
91TPU is offline
Old 04-13-2007, 03:59 AM   #4 (permalink)
CJM
CJM's Avatar
Well, I think the hot from the fuse block could work. Which wire is that even, I would need a wiring diagram right?
So I could overload the cigg lighter tho, say if I plugged in my phone charger?
__________________
CJM is offline
Old 04-13-2007, 04:24 AM   #5 (permalink)
NaeSLaS's Avatar
Send a message via AIM to NaeSLaS Send a message via MSN to NaeSLaS
Or, just get a cigarette lighter adapter, cut and splice the wires, and plug your CB into the cigarette lighter when you need it (like i do).
__________________
Current Rides:
1988 Toyota Short Bed, 4X4, 33" tires, 4" Trailmaster IFS Lift, 2" Body Lift, MC Front/Rear Bumpers, rusted bed (in the process of fixing)
1991 Yamaha FZR600 (sucks off-road)
Avoid Davez Offroad Performance at all costs! Read the story here.
NaeSLaS is offline
Old 04-13-2007, 04:53 AM   #6 (permalink)
CJM
CJM's Avatar
Quote:
Nah, that makes it look ugly as its all exposed, a good idea if II cant do anything else tho. THanks.
__________________
CJM is offline
Old 04-13-2007, 05:35 AM   #7 (permalink)
Pest's Avatar
My CB is tapped into both the hot and ground wires running from my cig lighter. I use the lighter to charge my little jumper pack/air pump. Hasn't blown a fuse yet.
__________________
-Pest (Nate)
1985 4Runner
278,xxx miles and still young!
2" lift.
32" x 11.50" BFG A/T's on 15" American Racing Wheels.
Aussie Locker in the rear
Commando Car Alarm with Power Locks and Remote Keyless Entry
Rewired power windows to run with ignition off.
LCEngineering Header, Magnaflow Muffler, 2.25" Exhaust
Rock Crawling puts the FUN in Funeral.
Pest is offline
Old 04-13-2007, 05:47 AM   #8 (permalink)
NaeSLaS's Avatar
true enough...but then again, i switch my CB from car to car.
magnetized antennas don't get very good reception.
__________________
Current Rides:
NaeSLaS is offline
Old 04-13-2007, 11:40 AM   #9 (permalink)
surf4runner's Avatar
i like my K-40 w/mag mount. good reception too.
CB powered through the cig lighter.
simple to move to another vehicle.
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 04-13-2007, 06:33 PM   #10 (permalink)
CJM
CJM's Avatar
Well, I finally gave up trying to fab up a mount so I didnt have to remove anything. The T100 lower console area just doesnt work right b/c of where the radio, ashtray and cigg lighter are. So I ripped out the ashtray since I dont use it except to hold junk and with some minor trimming my cb will fit..
__________________
CJM is offline
Old 04-30-2007, 07:34 AM   #11 (permalink)
toy4wd's Avatar
Send a message via Yahoo to toy4wd
if you tap the cigarette lighter your going to get whine use one of these
http://www.jcwhitney.com/autoparts/S...1&sku=mh037093
toy4wd is offline
Old 05-01-2007, 05:41 AM   #12 (permalink)
Mark in MD's Avatar
Here's what I have, nothing to install because everything is in the hand held unit:
I have magnetic antenna. I only use mine on trips. It works nicely, range is around 2-3 miles.
You can also use it as a walkie-talkie (disconnect bottom part, add battery pack, antenna screws in), in case you get stuck in a valley or something and need to hike out on foot.
Mark in MD is offline
Old 05-01-2007, 08:24 PM   #13 (permalink)
CJM
CJM's Avatar
Update:
I installed it in the ashtray as planned, fit pretty well too. I originally just plugged the wire into the cig lighter plug for power but got noise whenever i had the squelch turned up. Also my lighter didnt work and my phone charger is handy.
So I took a simple plug and made it fit my cig lighter, then spliced two wires to it and made one with aplug for the lighter and the other for the CB. No electronic noise and it works great..now I need to run an antenna.
__________________
CJM is offline
Old 05-04-2007, 10:48 AM   #14 (permalink)
89silverpu's Avatar
Location: Vacaville/Sierra Nevada Mountains, CA/ UNLV (Las Vegas), NV
pictures?
__________________
'89 Beater Jeep Eater in progress
4.88's, TRD e-locker, Dual Cases, 33's, Armored,
Tread Lightly
Mixchallenge.info
89silverpu is offline
Old 05-04-2007, 11:55 AM   #15 (permalink)
91TPU's Avatar
yea show me some pictures of what you did with the wiring to the cig lighter marc!
__________________
god hates you.
91TPU is offline
Old 05-13-2007, 12:57 PM   #16 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
wiring to the battery takes under 30 minutes. LAZZZZZZZY
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs & 3" rear downey spring
Home made On-board air system
V6 4.88 lock rites F & R
Bilstein 7100 reservoir shocks
deserttoy84 is offline
Old 05-15-2007, 01:02 AM   #17 (permalink)
CJM
CJM's Avatar
Quote:
More like I didnt wanna run the wiring through the firewall..
__________________
CJM is offline
Old 05-15-2007, 09:35 AM   #18 (permalink)
there are so many plugs you can route the wires through on toyotas. you just gotta find them.
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Tags
antenna, cb, cigarette, diagram, fzr600, ground, install, k40, lighter, naeslas, optilux, professional, wiring, yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
My CB install jwbehm 95.5-2004 Tacomas & 96-2002 4Runners 26 12-27-2007 11:18 PM
CB Install hlpressley 95.5-2004 Tacomas & 96-2002 4Runners 3 06-17-2006 09:52 AM
My CB install! JRunner90 GPS & Communication 1 10-28-2005 10:32 PM
CB install beek GPS & Communication 4 09-08-2004 06:42 PM
2009 InternetBrands, Inc.
