YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-16-2007, 08:34 AM   #1 (permalink)
8yota9's Avatar
CB Help i can hear them but they cant hear me?!?!
The other day i was with my buddy and he says go on ch 40. ok kool i finely get to use my little midland he says "yo" nice and clear i say "yo" and he cant hear a damm thing. He said all he herd was a squelling sound thats it. i was about 10 feet away from him? Radio is brand new ,new colax cable, fire strike mount grounded to the body all paint is gone. radio i curled the power wire around the cig fuse power is fine grounded to a ground bolt by the fuse box in the cab. whats rong? is it the antena i never got enething tuned but i can hear everthing nicely? Help please!!!!
8yota9 is offline
Sponsored Links
To remove this ad, register today!
Old 03-16-2007, 08:49 AM   #2 (permalink)
881stGenRunner's Avatar
you have to tune it, or you will destroy your new cb radio. Dont key the mic without it being tuned or over time you will destroy it. i thik that may be a problem. Get an SWR meter from radioshack or take it to a cb shop.
__________________
-Brandon
1988 4Runner SR5 4x4 V6 5 Speed Swap SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5R15 Yoko Geolander M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~3' Firestik II~Marlin Crawler rear~Custom Front~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss.
My 4Runner and Other Stuff
881stGenRunner is offline
Old 03-16-2007, 09:35 AM   #3 (permalink)
getitdone's Avatar
Same happened here. Tune it(twist the tip on antenna) with an SWR meter.
Another weird thing that seems to happen only to me is when I am too close, within about 10 feet antenna to antenna, of the other person their transmission comes in all nasty and messed up. All I have to do is get away just a bit and it's gravy.
__________________
Chris Fischer
3D 85 4Runner SR5 | 33" BFG M/T on flat black rims | Chevy springs | Custom Grab cage with overhead cb mount | Custom fabbed center console | Freshly rebuilt axle with IFS hub/caliper swap | Rock Sliders | Lots more...
In Colorado, Dig.
getitdone is offline
Old 03-16-2007, 10:25 AM   #4 (permalink)
Yota Tony's Avatar
There's a lil washer in the antenna and mount.
Make sure that's in the right spot. Make sure it's not crushed!! Do not over tighten your antenna!!!
Tune it also.
Read this: http://forum.sotra.ca/viewtopic.php?t=27
__________________
Anthony
93 ZJ - Stockish (HP D60 Front, 14 Bolt Rear, 231/D300 Crawl Box...awaiting 40" tires)
Ballistic Crap Missile
ILikeMud.net
Mallcrawlin.com
SOTRA
Yota Tony is offline
Old 08-19-2007, 11:51 PM   #5 (permalink)
Zodiac's Avatar
make sure you have the plastic washer under the antenna between the antenna and mount sounds like the antenna is grounding out!
Zodiac is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Have you hear this product? Net4N6 Off Topic Talk 3 01-16-2007 10:22 AM
I hear noises 4rnr 95.5-2004 Tacomas & 96-2002 4Runners 4 11-16-2004 04:45 PM
Let's hear from the Econ Gurus MTL_4runner Off Topic Talk 12 08-11-2004 04:37 PM
I can hear the stereo! EOD30 Maintenance & Repair Archives 0 04-14-2003 05:30 PM
Can you hear me now? Corey Off Topic Talk 13 08-15-2002 05:13 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
