| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
cb antenna.
#2 (permalink) |
any advice would be great!
#3 (permalink) |
Staff
Tunable antenna would be better, I'm told since it allows a more precise matching to the radio. A non-tunable is set at the factory to a more or less middle of the road setting which may or may not work well with the radio you choose. As for location you want to mount it as high as you can to get the best radiation. A 3' antenna mounted down near the bumper on one side would be partially shielded by the body of the vehicle which would cost you tx/rx range but if you're only using it for close in trail comms you probably won't notice too much of a difference.
Several members here are far more into CBs and can give you much better advice than me but I hope this helped you a bit anyways. Aviator
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
#4 (permalink) |
Make Sure All Your Ground Connections Are Good, Secure And Clean. A Bad Ground On A Cb Antenna Will Make It Very Hard To Transmit And Receive. Happy Squelching.
#5 (permalink) |
yes thank you. i am mounting it about the tail light so it will be about 6 inches about the top of the car so would a 4 foot be more reasonable?
#6 (permalink) |
The Higher The Better. I Use A Magnet Base And Slap It Right On Top Of A Shop Rag.
#7 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
you won't notice a big difference between the 3, 4, 5 or 6 foot firestiks. the primary difference other than size is how much transmit power they handle- the longer ones handle more power. if you are not using a linear amplifier, then any one is acceptable.
as for tunability, firestik antennae are allegedly tuned in the factory but if you're using the upper channels exclusively, you can clip the firestiks down to better tune them to the upper channels. if you're using the lower channels most often, the firestik works well (and can't be tuned to optimize the lower channels anyways). most tunable fiberglass whips only adjust the impedance of the antenna to better match it to the radio than to the improving transmit performance. tunable steel whips are tuned by sliding the element in or out, effectively changing the length of the antenna and tuning it to the different frequencies. if you install one of the spring loaded mounts that let's the antenna flex at the mount, the antenna should be tuned since the antenna is now longer. and you'll need a VSWR meter (voltage standing wave ratio) to do so. now, more important is where the antenna is mounted. if you're mounting it to the side of the tailgate, the metal of the body will direct the signal (it's called 'ground plane effect'), so if it's say on the driver's side of the gate, the transmit and receive signals will be slightly stronger in the direction of the passenger side. if it were directly on the corner, next to the taillight, the signal will be stronger along the side of the truck and along the back- any signal coming from the opposite corner of the truck. this is why most truckers put an antenna on each side cause the cab and trailer direct the signal front and rear and partially blocks the signal from the opposite side [through the body] draw a line down the center of the cab and draw a half-circle on one side of the cab and you can get an idea of where the antenna's sensitivity is greatest. the second antenna is matched to the other antenna and picks up signals on the other half of the truck. this technique is called co-phasing and when done properly works as well as one antenna in the middle of the roof. which brings me to the optimal location to mount a single antenna- as high as possible and centered, meaning the middle of the metal part of the roof. probably not an option for your truck though since it is already fairly tall. if it were me, I would do two 7' 3/4 wave firestiks, one on each side just in front of the taillights, with a cophasing harness. the signal would be strongest to the front of the truck, but not appreciably lower to the rear. something that may help you visualize what I'm describing about antennas would be to imagine that the antenna is a very bright lightbulb. imagine how the light would shine and reflect off the body of the truck, and where the body of the truck would cast shadows. *edit- sorry for the dissertation... 10-8, 10-10
__________________
Quote:
Insomnia: it's a way of life.
#8 (permalink) |
but just for talking to your buddy up ahead of you or behind you on the trails wat would be the best option? and would just buying a non tunable antenna be fine?
#9 (permalink) | |
i have a radioshack 4 foot whip works great!
__________________
GO TEAM LAZY!! my name is ALLAN yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear Quote:
www.myspace.com/whatsadisplayname |
#10 (permalink) | |
you'll be fine with the 3' firestick. expect about 4 miles range on flat open ground, maybe 1/4 that in mountainous territory. but basically, if you can see each other, you will be able to talk.
__________________
#11 (permalink) | |
... off topic.... allan- change your location, unless that pic of you with the gun is a bobblehead...
__________________
#12 (permalink) |
would getting a 4 or 5 foot non tunable increase that range because it would be higher about the top of the car because were i weel most its very mountainous? thanks
#13 (permalink) |
or would 6 or higher be even better?
sorry for all the ?'s newbie to cb's. |
#14 (permalink) | |
wouldn't increase the range much. but they're not that much more expensive than the shorter one.
__________________
#15 (permalink) |
ok so i read earlier that you said you would to tune it if i got a spring for the base. well if i go to a 4 or 5 foot antenna will i need to tune it just for what i'm doing? thanks by the way for awnsering all my questions
#16 (permalink) |
I won't be any help with the antenna question so this is a little hijack.
Where did you mount the CB? I'm trying to find a place to mount a Cobra 29 and it's so dang big I just can't find a spot to put it.
__________________
RB4R Life Member. 1989 SR5 4runner. Tread Wright 31/10.50/15's. 4.56 thirds, an Aussie in the @$$, Budbuilt plate, Marlin Crawler front, modified MC rear, Supra MAF conversion, ZUK coils in the rear and 4crawler BJ's in the front, LCE header. |
#17 (permalink) |
i actually have the new compact one so i could squeeze it right under my head unit for my speakers. you might have to mount it to the glove box.
#18 (permalink) |
Get a tuneable antenna, the FireStik-II is great, they are very rugged and hold up to lots of abuse. I used to run a 4' then switched to 2' on the back corner of my 4Runner:
http://www.4crawler.com/4x4/CheapTricks/CBantenna.shtml Pop for an SWR meter if the local CB shop does not have one to tune your antenna with, I got mine at Radio Shack for like $15. And don't think of tuning as a one time deal. Good idea to check it periodically, coax cables age, ground connections can go bad and I even once had an SWR problem after wheeling at the ocean beach. I guess the coating of salt spray and dust on the antenna changed its impedance (salt is conductive). BTW, I do have a cheapie fiberglass whip from Radio Shack on my daily driver. One thing I found with it is do not touch it with bare hands after a few years of use as those glass fibers are like fine cactus stickers, BTDT! The FireStiks have a heavy shrink wrap covering and it will stand up to scraping on parking garage roofs, tree branches, etc. without damage.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#19 (permalink) | |
i'd say no you won't have to tune it. you're not looking to do the ultimate optimization for talking around the world.
__________________
#20 (permalink) |
Honestly The firestick is a good antenna but the radio is a less than desirable one (but it fits in a small truck). Move the anntenna closer to the radio and use the shortest coax possible (less coax = lower resistance = Lower SWR).
Buy a SWR meter and 6" piece of coax to test the SWR. If it exceeds 2 then you are not going to get out very well. Magnet mount antennas are problematic and fiberglass whips are the most economical solution (but I've had great luck in the past with the "K40 Gold Series" Steel Whips). BTW where do you mount a full size radio in one of these trucks, on the glovebox, only place where mine would fit, not enough room under the AM/FM radio, no room on the dash where It wasnt in the way, tranny tunnel was too shallow, and no roof bows where it could be mounted My setup is a "Peaked and Tuned" Uniden 68 LT with a 40"x3/8" Radio Shack Brand Fiberglass whip (same as found on most International OTR trucks) mounted at the very front of the bed on a custom bracket (its a 1"x5"x1/16" piece of angle with a 1/2" hole in it). (whole setup was approx $300-400). |
#21 (permalink) |
I used to run my old Uniden GrantXL radio on the driver's side door:
![]() Worked well there, but is in the way of my future roll cage bars, so went to a small CObra 75.
__________________
#22 (permalink) | |
Quote:
I gave up on Firestiks after I shattered a few of them on the trail (even trying different mounting positions and springs) Whips seem much cheaper and durable to me...dunno...
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#23 (permalink) |
Use a magnetic mount and slap it on your roof. My buddy had a 9' whip off his rear bumper and it flopped around so much he finally gave it up for a 4' mag. mount on the roof. I've got the same setup. Be cautious as the fibreglass antenas can break if they get caught on a low hanging branch or something like that, where as the mag. mount will just tip over. DON'T stick it on top of a rag though, it should have a rubber coating on the bottom to protect your paint and prevent grounding interference.
And if its just for close trail communications I wouldn't bother with a tuneable antena.
__________________
'90 Hilux Surf - sold '86 4Runner - sold Hoping to start another project soon, LT race build. |
#24 (permalink) |
I know its been a while for everyone on this thread, but I'll give it a shot anyway. I am actually looking to get the same cobra setup with the Cobra 18 WX ST II. I was going to get the firestik doorjamb mounting bracket and put it in the tailgate above the tail light, because I'm getting a marlin crawler rear bumper that seems to interfere with everything I want to stick on the back of my 94 'runner. I'll make peace with that in my own time, but I figure I could get away with the 2' antenna if the tunable tip of the firestik II protruded somewhat from the top of my roof. I dont want to reduce my clearance so much - I live in Los Angeles and often enough I have to bring my daily driver into places with low roofed parking garages etc. I'll get whatever I have to in order to get a decent SWR rating for the radio, but as far as a 101" whip antenna, thats not for me on this yota. I have a 89 K5 blazer back in New York where I'm from for all my solid axle funhaving around there, and the militart theme on the truck begs for that type of setup, but thats for a whole other forum!
If you have a cb antenna installed similarly on your 4runner, please do post some pics here so I can see how its going to look! Thanks! |
#25 (permalink) | |
I just got my 4 ft. firestik 2 installed with the doorjamb mount on the drives side rear corner. im just using it for trail use so im not too worried about getting it peaked and tweaked just right
__________________
Quote:
Addikted Riders - Riders for Christ
MySpace '98 Toyota 4runner Deckplate Mod, Cobra CB, 4' Firestik II, Hella 500's, Yakima Crossbars, Coleman Roof Basket '97 Nissan Maxima SE- sold '92 Toyota 4runner - sold |
| Tags |
| 3, 4ft, antenna, antennas, cb, fibreglass, firestik, international, maxima, milwaukee, nissan, power, removal, stacking, stuck |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Antenna Removal and Antenna Relay | PRNDL | 93-98 T100s | 3 | 10-22-2006 03:01 PM |
| Power Antenna Mast- how to get to the antenna assembly | xxspokan | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 02-18-2006 06:08 PM |
| Replace stock antenna w/CB antenna, good idea? | jdRunner | Vehicle Audio & Home Entertainment | 3 | 12-02-2005 12:58 PM |
| Power Antenna - Stuck Up and No Motor Sound and other Antenna Questions | PhxRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-28-2004 03:37 PM |
| antenna | foreigner | Maintenance & Repair Archives | 4 | 07-15-2003 09:24 PM |
