| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
cant get CB radio working
__________________
1989 Toyota pickup 22re - K&N filter with custom air intake |
#2 (permalink) |
RF Gain all the way up and start turning your squelch up from the bottom. Done that yet?
__________________
. . . I said lie, for me lying under a process tree . . . . |
#3 (permalink) |
blown speaker? try an external speaker see if that works
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. Last edited by olharleyman; 03-18-2009 at 10:50 AM. |
#4 (permalink) | |
Quote:
I also have a delta - and + knob that I've adjusted. I've tried adjusting multiple combos of settings. I thought it was a blown speaker too, but it still clicks when using the mic, and I can hear interference coming from the radio inside my truck. So the speaker still works. Is it safe to say it's broken? :-( I won't buy a new one, i'll just take this to a repair shop (too much sentimental value)
__________________
#5 (permalink) |
Or your not getting the signal from the antenna into the unit
__________________
#6 (permalink) | |
Quote:
__________________
#7 (permalink) |
finals shot
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#8 (permalink) |
Antenna seems fine, as I can unplug it and watch the signal strength drop. There's a few additional switches I forgot to mention. There's 3, to be exact. One is for PA, and the other two I can't remember off-hand. would a picture help?
__________________
1989 Toyota pickup 22re - K&N filter with custom air intake Last edited by DupermanDave; 03-18-2009 at 11:15 AM. |
#9 (permalink) |
Heh i'm sure the shop will be able to get 'er goin
I've got my grandpa's old cb in my truck too
__________________
#10 (permalink) | |
Quote:
So which shop should I try first? CB radio shop or electronics repair shop?
__________________
1989 Toyota pickup 22re - K&N filter with custom air intake Last edited by DupermanDave; 03-18-2009 at 12:18 PM. |
#11 (permalink) | ||
You need to tune the antenna to the radio. Thats your problem. Go to radio shack, and purchase a RF/signal strength meter. It'll come with instructions on how to tune the antenna to the radio and the vehicle. Less than $20 (IIRC), and 1/2hr of your time.
__________________
Quote:
Quote:
------------------------------------------------------ 1991 Toyota 4Runner SR5 4x4, 3.0 V6, Auto, Alpine CDA-9807, 31x10.5's, 4.56's, 1" RB lift, 2" SDORI Coil spacers, Optima RedTop, Aisin manual hub conversion, and the all important FSM's Last edited by a4runnerfreak; 03-18-2009 at 12:42 PM. |
#12 (permalink) | |
Quote:
The antenna I have now is the one that's been with the CB radio for a long time now, so does it still need tuned?
__________________
#13 (permalink) |
you have to buy the cb tuner that hooks up inline between tthe antenna and the cb, buy lifting or shorting the tip of the anteena you (tune) the cb, the meter measures ressistance and your trying to get as little ressistance as possible for the best signal
__________________
80 pickup- built to wheel, locked f/r 36" sx's, curently working on exo-cage and 4.3vortec/700r4 swap Strong,Good,or Cheap pick two Has anyone seen my muffler bearings? My drinkin team has a toyota problem |
#14 (permalink) |
Ah, if I have the lengthen or shorten the antenna, I'll have to buy a new one. The one I have is pre cut and shortened. IT's about 2 1/2 feet long.
__________________
1989 Toyota pickup 22re - K&N filter with custom air intake Last edited by DupermanDave; 03-18-2009 at 12:56 PM. |
#15 (permalink) |
correction: not the anntena just the anntena wire that is wraped around the anntena
__________________
#16 (permalink) | |
Quote:
Could you guys also be talking about the length of coax cable running from the antenna to the radio?
__________________
#17 (permalink) |
the lenght of the cable can affect tuning also. just so you know im not shure tuneing is your problem. usally the cb will work out of tune, it just usally works much better after its been tuned
__________________
#18 (permalink) | |
Quote:
I just thought of this, but I have the antenna mounted on the toolbox behind the read window of my pickup. I know it's suggested they be mounted on the roof, but is it THAT big of an issue to have it mounted where I do?
__________________
1989 Toyota pickup 22re - K&N filter with custom air intake Last edited by DupermanDave; 03-18-2009 at 01:54 PM. |
#19 (permalink) |
I've been researching more online, and everyone recommends having the antenna rise above your roof by 3-4 inches. I checked my antenna, and it is up by 4 inches.
-edit- it's not the speaker. I have an AUX headphone jack I can use and it still doesnt bring any signals through. Took apart the radio and used a multimeter to verify the speaker was working still, and it is.
__________________
1989 Toyota pickup 22re - K&N filter with custom air intake Last edited by DupermanDave; 03-20-2009 at 06:06 AM. |
#20 (permalink) |
Third post just to get a final update: I think I'm going to take it to a shop to have it repaired. Question is, can it be repaired? Are some electronics not fixable? This thing is from the 70s, so I would think it can be fixed. I took it apart and seems pretty do-able. Anyone with experience know what it might cost? I'm going to a CB shop sunday and seeing if they can fix it.
__________________
| Tags |
| cb, harley, hear, pa, radio, squelch, works |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Radio, Clock and Cigarette lighter not working | Crawdad | 86-95 Trucks & 4Runners | 9 | 07-01-2008 08:56 AM |
| Clock/radio not working. | Nismo Convert | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-21-2007 07:53 AM |
| How do I change from a single din tape/radio to a double din tape/radio/cd | js058515 | Vehicle Audio & Home Entertainment | 17 | 08-09-2007 11:55 AM |
| Ham Radio and Satellite Radio | kvanderploeg | GPS & Communication | 5 | 04-20-2006 02:03 PM |
| XM radio prople or radio installers | Citykid | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-29-2004 06:08 PM |
