YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-25-2008, 02:19 PM   #1 (permalink)
881stGenRunner's Avatar
Cool Wire from voice coil is burning up (pics)
Well this is the second time this has happened to me so far. The wire leading from the voice coils to the frame of the sub, burn off at the connection where you put the wire in to power it. I burned the negative side first, fixed it, and now i have burned the positive one too.
I'm running two Kicker CVR 12's with dual 2ohm VCs and a Kicker ZX750.1 (birth certificate said max power at 850W) amp. The subs are wired up at 4ohms and since the amp is mono both wires run to one terminal and make the whole system running at 2ohms.
I guess im just pushing too much power and need to turn it down a little bit, but the amp is def not turned up all the way.
Is there anyway i can increase the gauge of the wires to try and keep it cooler?
Can this wire be bigger? These are the terminals that are burning up -
You can see the wire just burned off -
Heres the one i already fixed (re-saudered it). That is heat shrink, not tape -
Just for the hell of it -
__________________
-Brandon
1988 4Runner SR5 4x4 V6 5 Speed Swap SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5R15 Yoko Geolander M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~3' Firestik II~Marlin Crawler rear~Custom Front~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss.
My 4Runner and Other Stuff
881stGenRunner is offline
Sponsored Links
To remove this ad, register today!
Old 04-28-2008, 09:59 AM   #2 (permalink)
Are you hooked-up like this?
http://www.crutchfield.com/learningc...2Dohm%5Fmo no
__________________
1994 3.0 4Runner (Original Owner) 171K
2003 Jetta GLI
Astralplane is offline
Old 04-28-2008, 11:21 AM   #3 (permalink)
no i didnt, that is very helpful. I think that is what i need to do. Thanks
__________________
-Brandon
Old 04-30-2008, 02:55 PM   #4 (permalink)
notanymore's Avatar
just curious whats the rms power on your amp?
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust.
other ride: 1980 Honda CX500-
notanymore is offline
Old 04-30-2008, 02:58 PM   #5 (permalink)
I rewired it to that diagram and now it works much better. Thank you
375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
__________________
-Brandon
Old 05-11-2008, 12:51 PM   #6 (permalink)
i saw a few kickers do that when i used to work at an audio shop, almost every time it was because they werent getting enough power. what type of amp do you have, and what size fuses are on it and how many? fuses on the amp not your inline fuse
drpdmazda is offline
Old 05-11-2008, 01:20 PM   #7 (permalink)
bigt's Avatar
i have those same speakers i used to run a kx400.1 then upgraded to a kx600.1 kicker amp but it got stolen... now i run a 600 watt rocford fosgate and have no issues at all... mine are in a kicker livin loud box set up the same as you..
__________________
1991 HILUX SURF SSR-X
2-lte turbo diesel with upgraded head
tons of cool options you dont get in north America
RIGHT HAND DRIVE,auto,push button 4wd,turbo timer,31.1-.50.15 bfgs,factory fender flares,window flares.
CAR DOLLY
sirius TUNED TO HOWARD 100
trail ifs rig goldie
fate unknown
blue 93 srf 4runner NEW TRAIL RIG IN POGRESS
ifs welded rear few mods for now
rebuilding fj 60 series front axle for future s.a.s
bigt is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Mystery wire coupling (pics) San Martian Newbie Tech Section 22 03-05-2008 03:00 PM
ignition coil ground wire weakyota91 General Electrical & Lighting Related Topics 0 01-08-2007 07:51 PM
*whiney voice on* Dang it!!!!! *Whiney voice off* fustercluck Off Topic Talk 6 06-24-2006 03:23 PM
Plug wire retaining clips on coil pack etgunner Maintenance & Repair Archives 2 11-17-2005 12:19 PM
dual voice coil 04Tacoma4x4 Vehicle Audio & Home Entertainment 2 01-25-2005 07:39 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
