Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Using relay between batteries question
Hey i have a system that uses a large amount of power, in my last car i had my main battery that ran to a relay, the relay was grounded at one point and the other point went to the ignition or something. Then from the relay it ran to a second battery and then to my amps. I bought the relay in order to have current flowing through it between batteries with the car running, but not flowing when it is sitting off with the key in so i can listen to music off the back battery and not pulling from the engine battery. My question is, where do i wire the ignition side of the relay to? Obviously the ignition, but last time i was thinking i could wire it to a switch turning it on and off myself. but that sounds kind of annoying. I drive a 97 toyota 4runner, curious where i wire this ignition side to? I attached a picture its simple really. I just dont know if there is a certain part of the ignition or really how it works at all... I just want current to flow when the engine is running and that is it. This might be a battery isolator? Much of a difference? Thanks hope to hear back.
[/quote] |
| Sponsored Links |
#2 (permalink) |
if you wanna do it manually, just wire a switch to a +12 volt source.
if you wanna do it automatically, i have just about hacked my radio wiring harness to tap everything easily. from lights, to ACCESS to ON to everything you need is laid out easily at the that harness...
__________________
leo d. stock 90 4runner |
#3 (permalink) |
what are the specs of the system? and what electrical upgrades do you have if any? also what kind of car did the system come out of? I only ask these questions because running more than one battery is rarely the proper solution unless it's a strickly comp. system.
I know I didn't answer your question, but if you answer mine I can be of more help Last edited by yotakid825 : 03-23-2008 at 07:43 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Relay question | jimsi | Vehicle Audio & Home Entertainment | 2 | 03-24-2007 09:21 AM |
| Question on running dual batteries (different than usual...) | Keggo | General Electrical & Lighting Related Topics | 14 | 04-10-2006 04:04 PM |
| Question - Optima Batteries | ErikJeanna | 95.5-2004 Tacomas & 96-2002 4Runners | 33 | 12-19-2005 10:26 AM |
| Relay / Switch Question | trdslinger | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 12-29-2004 09:04 AM |
