YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-29-2008, 01:59 PM   #1 (permalink)
truck won't start really weird???please help
So i've been installing a stereo and all the sudden the truck won't start. Not because the battery is dead it just doesn't do anything when i try to start it. All the Electrical stuff seems to be working just fine. The Battery has 12.5 volts. and i even tried to jump it and no go. I've check every fuse in both fuse boxes and everything seems fine. The only thing i could think of is that maybe something came unplugged some where when i was working on installing speakers in the doors, but it doesn't seem like those wires would effect the starter like this. I have an alarm but the starter disable function is not hooked up. I can't here the starter click so something has to be up with that??? Any ideas or troubleshooting tips will help!:brickknoc
dgilling0714 is offline
Sponsored Links
To remove this ad, register today!
Old 02-29-2008, 02:18 PM   #2 (permalink)
keithguts's Avatar
Send a message via AIM to keithguts Send a message via MSN to keithguts Send a message via Yahoo to keithguts
Did you also check the fuses under the hood as well?
__________________
IF YOU DON'T DRIVE A TOYOTA, TEST DRIVE ONE TODAY!
MY PICS
95 4runner 3.0 auto 4x4
My Rig
My Rig
RangerMan
Enjoy
keithguts is offline
Old 02-29-2008, 02:22 PM   #3 (permalink)
yes i pulled every fuse and checked all of them and can't find anything. Like i said everything works as expected except the starter...nothing when cranked on not even clicking. The two areas i've been working on is in the right kick panel and behind the glove box and in the drivers side kick panel.
Old 02-29-2008, 03:09 PM   #4 (permalink)
nix4x4's Avatar
Wonder if by conincidence your starter is bad?
Unlikely, but stranger things have happened
__________________
The Stable...
2002 Toyota Tundra SR5 AccCab V8 4WD
1992 Toyota Truck DLX Xcab V6 5-speed 4WD
1995 Honda Accord LX 4 door I4
Check out my sweet myspace
nix4x4 is offline
Old 03-02-2008, 11:28 PM   #5 (permalink)
notanymore's Avatar
might want to post this up in the vehicle specific tech section to get more answers, is it possible you cut a wire on your ignition or something important like that?
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust.
other ride: 1980 Honda CX500-
notanymore is offline
Old 03-02-2008, 11:39 PM   #6 (permalink)
So it started, "didn't start after you installed the stereo?" Go back and check all your work, it probably got screwed up around there!
904_runner is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Truck making weird sound, please help L33T35T 4Runner Maintenance & Repair Archives 29 10-19-2005 12:21 AM
help my truck has a weird miss 1987 street toy 95.5-2004 Tacomas & 96-2002 4Runners 4 02-28-2005 10:09 AM
really, really, weird cold start problem creepycrawler 95.5-2004 Tacomas & 96-2002 4Runners 0 02-20-2005 01:18 PM
Truck making weird whining noice Juggalo 95.5-2004 Tacomas & 96-2002 4Runners 5 01-24-2004 08:09 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
