Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Subs pop
I have on 04 TRD Prerunner. I installed my system yesterday & I am concerned over something. I have two 10" Punch's with a 500 watt amp & Kenwood deck. I've had the same system in my past several vehicles, so I know its a good system. My concern is that when I turn the truck off the subwoofers make a popping sound & jump. I noticed that when you play with the RCA jacks it will do the same thing. Never had the problem before. Any help?
| Sponsored Links |
#2 (permalink) | ||
Location: Selling turnips on a flatbed truck, I 15N @ 79S
sounds like interference to me
__________________
^Say GO DJ..Uh thats my DJ The Blue Biche 91 4x4 p/u 22re--elbow mod, 500ff's. BFG A/T ta KO's. Smokey the Bear I Work on my gas tank while smoking a cig...Sue me Dad- 1999 4runner base 2x4, 2.7, 5speed, 52k, cherry. Chat with meeee Quote:
Quote:
UltimateYota |
#3 (permalink) |
Make sure everything is grounded good! Amp, Head unit, Etc.
Bad grounds cause all kinds of weird issues and noises. You also might try a different set of RCA's just to rule that out.
__________________
DMN, D.D.S. "DOC" 2000 4Runner SR5 4WD- RADIANT RED, Toyota E-Locker, BFG AT's, Yakima Rocket Box, Toyota Ski Rack, Alpine Amp, iPhone interface, Focal 6.5" Components Front & REAR!, Monster Wiring, Husky Liners, Magellan Color GPS, Bilstein Sucks...I mean Shocks 2005 Sequoia SR5 4WD- BRILLIANT WHITE, Yakima RB, Husky Liners, 10.4" LCD/DVD Player, iPod interface, BFG AT's 1986 Jeep CJ-7- Hard & Soft Tops, Alpine CD, iPod interface, Polk Speakers, 31" BFG AT's, Bosch Lights, Mopar MPI |
#4 (permalink) |
They might of also left in the small helper amp toyota sometimes uses. I has the exact same problem and that was what the problem was.
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers. Yes, I am here to collect my 238$ worth of stock from AIG. "What do you mean a free market economy doesnt apply to the rich?" |
#5 (permalink) |
Did you run your RCA cord next to your power cord?
__________________
2008 TRD Tacoma 4.0L 6 Speed 4x4 T_O_Y_O_T_A Take Off Your Oversized Tires A**hole |
#6 (permalink) | ||
That sounds most reasonable to me, never do it, just causes interference, as I stated above
__________________
Quote:
UltimateYota |
#7 (permalink) |
Ground your RCAs.
__________________
1996 4Runner limited no mods as of yet except a 200 amp alt and a 140db sound system Looking for some euro style blacked out head and tail lights and a replacement bumper |
#8 (permalink) |
take some electrical tape or heatshrink wrap and put it over your connectors on the RCA's I had mine bump each other occasionally and produce a similar effect.
x2 on the grounding make sure you have a good connection take some sand paper and clean up the area where your ground wire contacts the chassis. Like scuba said dont run the rca's next to the power wire or anything else for that matter and if you can get the twisted RCA's they cut down on interference. |
#9 (permalink) |
sounds like a ground loop to me. check all your grounds as stated before, also if you have more than one amp make sure they are both grounded at the same spot and that you have a solid ground point, all paint removed etc. also try grounding your headunit somewhere else.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| my new subs | 89macrunner | Vehicle Audio & Home Entertainment | 2 | 02-19-2008 10:59 PM |
| Subs... | Anthology | Vehicle Audio & Home Entertainment | 22 | 07-29-2006 10:25 AM |
| Did the Dollar bill test and Pop Pop Pop - Now What? | MDToy | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-27-2004 03:15 PM |
| subs | fooddude | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 07-19-2003 09:43 PM |
| best subs? | doink | 95.5-2004 Tacomas & 96-2002 4Runners | 56 | 03-10-2003 03:33 PM |
