Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Subs acting crazy
Recently put subs back into truck after about a year of sitting in my closet, and they are acting very strange. They will start BLASTING out a steady bass tone at random times while I'm listening to music (I know how retarded that sounds; isn't that what they're supposed to do, DAR???).
It does not matter what volume my deck is at, the bass will blast at the same pitch and volume, and will not stop until I turn the bass off. Also, when I go over bumps, I can hear the subs thump. Also, when I eject cds, I can hear my subs still pumping out while my deck is flipped down to remove cds? Anyone know what is going on here? I am fairly sure I have everything wired correctly, as I had them installed for a couple of weeks before everything started going crazy. I havn't really gone over everything anally yet as this really turned into a problem on the way back from a road trip recently, and have been sick as a dog since then. Seen this section for the first time and figured I'd ask the brains on here what they thought. Thanks in advance for any replies, ideas.
__________________
89 pu 3.0L 320K+ (and growing daily) Downey headers, custom exhaust 4" trailmaster (block) susp, 3" body 33" boggs |
| Sponsored Links |
#2 (permalink) |
Start by tracing the speaker wires back to the main source and make sure that there are not any breaks , fray's or cuts grounding out somewhere.
Next have the amp checked to make sure it is not having issues sending out a signal to the speakers it is possible that the wires inside the amp could have broke or frayed wire to the RCA jack Then if they both check out OK try the deck and make sure that it is putting out a good signal and not have a broken or frayed wire to the output RCA jack You should also check the speaker wires to the voice coils to make sure they don't have a broke or frayed wire to them causing the hit and miss signals you are getting.
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only Streached 5.5 gal. tanks 16" Ape Hangers 3" open primary 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#3 (permalink) |
bad rca's. i bet they are pinched or wore thru in some place.
__________________
88 dodge lancer shelby, 2.2 intercooled turbo, alpine 5.1 setup, 8 k hids, suede headliner flat black paintjob. 94 toyota 4runner v6 33x12.5 bfg mt's, cruiser coils, bj spacers, 4.88's, aisin manual hubs, the usual. 65 fj45lv stock, rust. SOLD!!!! |
#4 (permalink) |
Right on, thanks for ideas!
I'll be chasing wires today and let you guys know what I found.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| A/C is acting strange. | 4WDYotaShop | General Vehicle Related Topics (Non Year Related) | 6 | 03-26-2008 07:30 PM |
| Crazy Temp Problem (very crazy) | SPC | 86-95 Trucks & 4Runners | 10 | 04-24-2007 10:04 PM |
| Thermostat Acting Up? | 894Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 12-06-2005 02:43 PM |
| 91 T case acting up | tystoy | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 04-15-2004 03:18 AM |
| My Gateways acting up | Yoter | Off Topic Talk | 6 | 10-24-2003 02:34 PM |
