Sub options for a first gen 4Runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-30-2009, 07:08 AM   #1 (permalink)
Lotus1's Avatar
I've seen some custom setups before but can't seem to locate them. I have a 1988 first gen 4Runner and I want to put a shallow 10" or 12" sub in the back mounted to the side.
I don't want a big box sitting in the back because I use this area a lot for stuff. Any ideas?
I would like to mount it in that storage space to the right where my tow strap is.
__________________
"Tell them I'm comin', and hell's comin' with me !!!!!"
Lotus1 is offline
Old 12-02-2009, 02:40 PM   #2 (permalink)
tj884Rdlx's Avatar
i am about to do this same thing. i've just finished purchasing all the hardware, i need to get wires (monoprice.com) and then i need to strip the interior and start building cabinets.
i have a JL Audio 8w0-4 which was my replacement sub when i had the lexus. it's been a paperweight for the last year. i'm going to put it in that space on the right where your tow rope is.
my plan is to pull the right side trim panel, and build a small box out of mdf (the speaker paperwork gives the necessary volume, but i'm not too worried about matching the exact dimensions. it's not a competition vehicle.
but i will build the cabinet behind the panel, so that once i replace the panel, i can also replace the removable door and keep it out of sight.
by building the box, i don't have worry too much about reinforcing the qtr panels, which would flex if i just stuck a sub in the open space.
meanwhile, the factory rear speaker locations (the circle of holes poked in the panel under the rollbar arms) i think will hold 5 1/4" rounds when you pull the factory speaker housing out. i will stick to alpine 5 1/4" there, for full range sound when i'm in the back of the truck. they will resonate in the quarter panels, so they should have decent midrange. but the sub airspace will be separated because it's in that box.
in the front i'll put 4" coax with an aimable tweeter in the stock dash location, and in the rear seat i'll be cutting in 6x9s. those will be the only visible speakers unless i conjure a way to conceal them. i may build boxes for these as well, to tighten up their bass response, inside the quarters.
my problem is where do i stick my 5ch amp? i don't know where to put an amp in this thing. i am considering under the driver's seat, attached to the bottom of the seat to keep it off the floor. or on the ceiling of the cab. (no really) any other ideas?
__________________
88 4Runner DLX, 15x8 soft8s w/ BFG 33x10.5 A/Ts. 1.5" SDORI spacers, OME CS009s, 1" 4crawler b.l., original Canback top
tj884Rdlx is offline
Old 12-02-2009, 05:54 PM   #3 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
You could always put the sub in a jerry can and ratchet strap it down using the tie downs in the back...I've seen that somewhere on here...
__________________
Logan
aka: BBP
Kiss my IFS. RB4R Life Member VP.
'86 4Runner SR5 22R-E 4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear. Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000. Pics
'06 4Runner Sport 270/65R17 BFG All Terrain KO's
THE ULTIMATE TOYOTA RESOURCE
Quote:
Originally Posted by Junkers88 View Post
Admit it, you like reading my posts. It reminds you of the days before your runner was the monster that it is now.
BigBluePile is offline
Old 12-14-2009, 07:30 PM   #4 (permalink)
tj884Rdlx's Avatar
totally unrelated pic, but it's pretty nice truck. i dig raised red letters:
__________________
Old 12-14-2009, 07:46 PM   #5 (permalink)
tj884Rdlx's Avatar
this guy's got his amp in the rear qtr:
http://forum.ih8mud.com/80-series-te...read-ever.html
__________________
Old 12-14-2009, 07:51 PM   #6 (permalink)
tj884Rdlx's Avatar
another completely unrelated
just hittin the jackpot with crazy pictures tonite so i'm posting em up:
don't know if that's photoshop but if its real its sick
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
