YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-21-2008, 01:22 PM   #1 (permalink)
crbocaj125's Avatar
Send a message via AIM to crbocaj125
Sub cutting out
My subs have been flawless since install. Just yesterday on the way home they both stopped. When I turned it on today they worked for about 30 sec, then stopped. I checked the power fuse, plus the two fuses on the amp, all are fine. I retightened everything with no luck. My question is how can an electrically ignorant guy like myself test everything external, before I take the HU out to check the rear connections?
__________________
99 4runner SR5, 4x4, leather, black soft 8's, deckplate mod, ISR mod, tundra brakes
crbocaj125 is offline
Sponsored Links
To remove this ad, register today!
Old 02-21-2008, 01:44 PM   #2 (permalink)
89macrunner's Avatar
see if your amp is turning on. listen for a click or look for a light. Make sure its hasn't switched into protect as well.
check all of your connections.
the turn on lead of your headunit might have died. I have had that happen to me before. You can get a new headunit or use a switched 12v source (something off of your ignition) to turn the amp on.
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles
Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008)
2006 Mazda3 GT
2000 TRD Tacoma..Bought back and crushed
1988 4Runner SR5 V6 5 speed..sold
89macrunner is offline
Old 02-21-2008, 07:13 PM   #3 (permalink)
notanymore's Avatar
my first guess would be your amp, make sure your protect lights didnt come on or anything like that, so does the rest of your audio work, besides your subs or did it all die?
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust.
other ride: 1980 Honda CX500-
notanymore is offline
Old 02-24-2008, 06:02 PM   #4 (permalink)
how long ago did you have the subs and amp installed? was it done by a prof. shop? if so , call and find out about a warrenty(?) and see if they can look at it free of charge. if not, check to make sure the wires coming from the amp are still hooked up the subs properly in the box . if that checks out and the amp IS NOT in protect mode than there is a good chance that the preout on the head unit is bad or going bad. I have seen that before .
89trknwby is offline
Old 02-25-2008, 11:31 AM   #5 (permalink)
dijlop's Avatar
Send a message via AIM to dijlop
i would suggest pulling the sub out of the box and checking the wires in there. i personally am in need of a solder job on the connection between the cone and the sub outer terminals. that can cause a cut in and out, and eventually absolute silence. lol
__________________
Dead '94 2.4L 22re 2wd pu, k&n air filter, thrush glasspack, 4in over stock rear shackles, 1.5in ball joint spacers, 4in infinity reference dash speakers, pioneer head unit, 10in p2 sub, alpine amp. bed cap topper thingy. great for campin.
Current-2004 toyota tacoma, 2wd, 3.4L, prerunner, e-locker, tow package, trd package, ext cab, alpine head unit, polk speakers all around, punch p2 10" run off a alpine mono amp, silver paint. ohhhh its purty...
dijlop is offline
Old 02-25-2008, 06:02 PM   #6 (permalink)
crbocaj125's Avatar
Sorry everyone for not explaining a little better. Thankyou for all the responses!
It is two subs in one box, and the both cut at the same time, so that is not it.
I did the install myself, everything came directly out of my friend's truck because he was selling the truck.
I forgot that my amp had a light, I will have to check it at night, where I can be sure if the light is on or not.
I don't know what "protect mode" is, but I will look for that function on the amp tonight.
__________________
Old 02-25-2008, 07:28 PM   #7 (permalink)
notanymore's Avatar
protect mode is just what it says it is, whenever there are any outside issues that would affect the amp(short circut, overheating, improper load, ect.) its usually indicated by a light on the amp. make sure the amp powers on while your checking it.
__________________
Old 02-25-2008, 10:07 PM   #8 (permalink)
olharleyman's Avatar
Make sure you are getting plenty of air to it overheating the amp from lack of air flow over the cooling fins is real common and thats what it sounds like is going on there.
Get a couple mini fans and set them up to move air over the amp whenever it is on that will help your amp stay cool and last longer.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
Streached 5.5 gal. tanks
16" Ape Hangers
3" open primary
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 02-25-2008, 10:55 PM   #9 (permalink)
dirtyXplorer's Avatar
Are the two subs wired in parallel or series?
If they are wired in series and one stops working (blows or a wire falls off) both subs will stop working. If one is blown the amp will likely be in protect mode for the short circuit. If the amp checks out ok I would think it is a speaker wire loose or fallen off somewhere. maybe inside the enclosure?
This is what happened to my roommates subs, they both "cut out" one day and it turned out they were wired in series and one had blown with out him knowing.
__________________
93 4runner SR5, V6 3.0 Auto, Pro Comp ES9000s, 14" Magnaflow, Aisin manual hubs
93 Ford Explorer, lifted, 35"s
dirtyXplorer is offline
Old 02-25-2008, 11:04 PM   #10 (permalink)
JohnnyRanger54's Avatar
sounds like you're amp is clipping... turn down the gain on the amp, unbridge if bridged, try lower volumes for a bit, see if that helps...
__________________
1988 4Runner, 3.Slow, 5 spd.... not stock.... I have 2 sets of BFG AT's 33x12.5x15 Brand New.. 660 per set.. Oh yeah
http://http://www.geocities.com/serioustoys/home.html
JohnnyRanger54 is offline
Old 02-26-2008, 03:58 PM   #11 (permalink)
notanymore's Avatar
if it was clipping wouldn't he have noticed it before it completely died?
__________________
Old 02-26-2008, 07:38 PM   #12 (permalink)
Quote:
To diagnose, I would start at the subs. You can test them by unhooking them from the amp and lightly tapping a 9V battery to the terminals on the enclosure (+ to +, - to -) If both speakers make a pop, they work. FYI, if you leave the battery on the speaker long you can damage it so just tap it on there for a split second.
If both speakers work, inspect your speaker wires. If they are good the next thing in the chain is your amp...If it is not in "protect mode" then there is something wrong with the signal going to the amp. I would check this by hooking up an Ipod or something like it to the inputs on the amp. If your speakers work with an Ipod hooked up to your amp, its something between the amp and HU, of the HU its self.
It helps to have a multimeter to check the RCA's or any other wires.
Thats just my .02
__________________
Old 02-26-2008, 07:52 PM   #13 (permalink)
dijlop's Avatar
what if you dont have an ipod? lol. thats a good plan to follow though. i wouldnt have thought of touching the wires to a battery. if anything i would visually inspect all the wires and fuses and connections, then if everythnig seems in order try an alterant amp. if u dont have one try to find a buddies to borrow just for a check.
__________________
dijlop is offline
Old 02-26-2008, 07:57 PM   #14 (permalink)
bigt's Avatar
i would think your amp is over heating or the load i.e the subs are too much for it to handle... have you bridged the subs???? is your amp 4,2,1 ohm stable?? is it a sub amp?? WE NEED DETAILS MAN
__________________
1991 HILUX SURF SSR-X
2-lte turbo diesel with upgraded head
tons of cool options you dont get in north America
RIGHT HAND DRIVE,auto,push button 4wd,turbo timer,31.1-.50.15 bfgs,factory fender flares,window flares.
CAR DOLLY
sirius TUNED TO HOWARD 100
trail ifs rig goldie
fate unknown
blue 93 srf 4runner NEW TRAIL RIG IN POGRESS
ifs welded rear few mods for now
rebuilding fj 60 series front axle for future s.a.s
bigt is offline
Old 02-27-2008, 05:48 AM   #15 (permalink)
crbocaj125's Avatar
HA! I dont know any details! I am not car audio inclined. The first time I heard the guitar solo for "the Joker and the theif" I knew that I had to have a louder stereo! I got the system from my friend, so no I can turn the bass all the way out of the door speakers, and the sub does it all. It sounds amazing, well...it did. Today is my day off, and I am heading out to figure it out. Update around noon.
I have no idea what bridging is. I know that there are two speakers in the box, and each speaker gets its own set of wires. I don't see why they would be wired together on the inside as well.
__________________
Old 02-27-2008, 07:12 AM   #16 (permalink)
here is what parallel and series speaker wiring looks like
__________________
Old 02-28-2008, 08:54 AM   #17 (permalink)
crbocaj125's Avatar
Well, I put the subs back in the truck yesterday after taking them out for a road trip, and they worked. They are still kind of weak though. I used to have them down to -9 or -10 on the HU, and it was still too much bass, today I had to turn it to +3 or +4 to get some good bass. BTW, they are parallel wiring.
__________________
Old 02-29-2008, 07:29 AM   #18 (permalink)
Send a message via AIM to yotakid825 Send a message via Yahoo to yotakid825
did you adjust gain level? if not check all the wiring
if all the wires(power, RCA, speaker, etc) are ok then or amp is "on it's last leg". I had an old amp that just moved the sub a little bit(to the beat), but there was no sound
yotakid825 is offline
Old 03-06-2008, 10:20 AM   #19 (permalink)
choover567's Avatar
your subs could even have just simply unconnected internally from the box, my kicker L7 15" did that once. alotta vibration in there. remove one and look =D
choover567 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
85 cutting out sully72 84-85 Trucks & 4Runners 16 01-16-2008 01:25 PM
Engine cutting out??? timk2915 86-95 Trucks & 4Runners 15 02-11-2007 06:37 PM
Stihl not cutting it for you? Try this... Tanto Off Topic Talk 16 07-19-2006 11:25 PM
Whistling, ABS light on, stereo cutting out, engine cutting out, HELP! Randomness Maintenance & Repair Archives 6
