YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-26-2008, 09:15 AM   #1 (permalink)
MadJack's Avatar
Question Stock Radio, wiring question
When I bought this 89 P/U it had no radio...previous owner took out an aftermarket, left big hole.
I'm trying to install a stock radio from an eighties 2wd. I only have the pig-tail that goes into the radio.
It has a brown wire in the center, blue-green-gray on one side and blue-green-purple and pink on the other.
Question, are the pink and brown for continuous & ignition power?
Is there a separate ground or just the housing/antenna jack?
The wires in the truck (again no plug) are all marked.
I don't need or want anything 'nice' as it's a daily beater/woods truck and there's no need to tempt anyone to steal something I can't hear the difference in!
Thanks.
MadJack is offline
Sponsored Links
To remove this ad, register today!
Old 02-26-2008, 11:36 AM   #2 (permalink)
JAvendan's Avatar
this should help.
http://www.the12volt.com/installbay/...tail/2110.html
good luck.
joel
__________________
'88 4Runner 5-speed
22re rebuilt top to bottom May '07
Downey intake and header with custom 2.5" exhaust
JAvendan is offline
Old 02-26-2008, 12:35 PM   #3 (permalink)
MadJack's Avatar
Thanks Joel! Never heard of that site before.
MadJack is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
radio wiring harness question rickgoof Vehicle Audio & Home Entertainment 6 09-04-2005 08:58 AM
Stock Radio/tape/cd changer question travelinman Vehicle Audio & Home Entertainment 3 05-04-2005 01:00 PM
Help w/ Wiring Cobra CB Radio Theforce GPS & Communication 10 03-09-2005 03:22 PM
Radio Wiring Diagram bryontro 95.5-2004 Tacomas & 96-2002 4Runners 3 02-01-2005 12:34 AM
Radio wiring question??? Guerrero 95.5-2004 Tacomas & 96-2002 4Runners 1 01-01-2004 10:52 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
