Stereo poping/crackling Issues
So my toyota has an older pioneer deck good speakers, will be taking pictures soon. But having an issue with the sound and really needing help, So it sounds great in the rear two speakers 6x9 but all the front four speakers are having a screeching/poping sound when loud especially if song has a lot of bass . To be honest I thought they were blown so I pulled them out and tested them, the one I tested is a 4x6 Pioneer in the door (which I assumed was blown), and it sounded great hooked up to an exterior sound source outside the truck, so then I believed it was the deck so I checked the fuses and motherboard all seemed good, so then I checked the wiring to the speakers and all was good, so I'm guessing it may be a ground issue or getting power through the speaker wire, possibly something else? Hopefully someone else has had an issue like this and can add some feedback and if someone could get me a wiring diagram or at least show me or tell where the ground leads to for the stereo that would be very helpful. Thanks.
I seem to be having a similar issue with my setup.
I have a older sony deck, running to a 4 channel amp, an 8" sub, and components in the doors (2 - 6-1/2 and tweeters.) Because my deck doesnt have an aux in, I had to split the 4 line-in rca's on the amp with a 4 y-splitters to retain my stereo line in, and be able to add a stereo plug to rca cable so i can plug in an ipod / my phone / etc that bypasses the deck. (I have to control volume with the audio source rather than the deck. Basically the deck is only used for the amp on signal.) Maybe I should draw a picture....
Im wondering if my stereo plug output from my phone is too much for the line in signal and if i need to switch it over to speaker level input... Im gonna look at it this weekend.
If I remember, I will post back with what I find.
I have a older sony deck, running to a 4 channel amp. An 8" sub. and components in the doors (2 - 6-1/2 and tweeters.) Because my deck doesnt have an aux in, I had to split the line out rca's with a crap ton of y splitters (to retain my stereo input as well) to the inputs on the amp.
Thanks for the input bro, I got it solved. Before I bought it the deck had an ground and a switched 12v ran to an amp....long story short before I bought it and the amp was removed whoever pulled the amp didn't rewire the deck to the original switched 12v and ground.
jasonty
41
12-23-2018 01:00 PM
r3dfish
54
05-16-2016 10:31 PM
theking11863
03-19-2016 09:36 PM
Esibnitsud
07-30-2015 08:19 PM
