Rear speakers Above Rear window 2nd Generation - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-17-2006, 08:01 AM   #1 (permalink)
AJwhoisthat's Avatar
What Size are the very rear speakers right above the roll-down back window? and Whats a good replacement.
__________________
Wrecked my car.
AJwhoisthat is offline
Old 07-17-2006, 10:55 AM   #2 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
They are 4'' but you can fit some 6'' easily without trimming the plastic.
Some people trim the plastic and put 6x9's but I hate it...
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write...
Blizzard is offline
Old 07-17-2006, 11:06 AM   #3 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
No blizzard, he is referring to the small vents above the rear sliding window. No speakers will fit there...save maybe tweeters but why anyone would wnat tweeters back there is beyond me...lol
Now in the quarterpanels in the back, yes you can def fit 6.5's in there.
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 07-17-2006, 11:28 AM   #4 (permalink)
Epic Ed's Avatar
I had a pair of 5 1/4" speakers in the cargo area panels and it was pointless. Nothing worthwhile will fit in the space in question unless you plan to use it for campground/out of vehicle-tail-gate-down entertainment. Even then it's a stretch, IMO.
Ed
__________________
'95 4Runner|32x11.5 BFG TA KOs|Hi-flow Cat|Dynomax muffler; 2.25" exhaust| Downey Headers|4.88 gears |Detroit EZ locker |Detroit TruTrack|BJ spacers|Downey HD coils|2" rear spring spacers|Rancho RS9000X/RS5000s|WARN hubs|TJM T15
Epic Ed is offline
Old 07-17-2006, 03:01 PM   #5 (permalink)
Blizzard's Avatar
Ahhh!
I've my tweeters there, it's a perfect place becouse they point directly to the drivers and passenger heads.
I love having my tweeters there, as they're titanium ones they are a bit loud, so I wanted to put them a bit far from me. In that position they're very very nice, and I love the sound coming from the front, side and rear of me (I've 3-way component speakers + subwoofer)
David
__________________
Blizzard is offline
Old 07-18-2006, 05:22 AM   #6 (permalink)
I figured That was all I could do back there. Right now i have a pair of Polk db 6-1/2" speakers in the back panel and i had to put an adapter bracket for those. I was just looking for soemthing good to put up above the back window because that is such a wierd speaker size its bigger than a tweeter but smaller than a 4" opening. Ill probably have to fabricate some sort of bracket to mount a set of tweeters up there. I was also considering wiring a set of component 2-way speakers and just mount the crossovers under the back trim panels somewhere and run the wires up there for the seperate tweeters.
__________________
Wrecked my car.
Old 07-18-2006, 09:38 AM   #7 (permalink)
It should work then!
(I have never liked sound behind me, hence my comment earlier. But hey, differing wants and desires make the world go round! )
Definately take the time to amplify your speakers even if you have to use a "small" 25 watt per channel amp. You'd be surprise how much better it will sound over a factory deck.
__________________
SPL: 159.8db @ 42hz
Old 07-19-2006, 06:51 AM   #8 (permalink)
well here is a bigger problem that didnt arise until yesterday afternoon when I put my new head unit in. My old HU was an alpine. And I put the new CDA-9856 Alpine in which ended up having a slightly different wiring harness. So I changed the wiring harness, I cut the old one off and crimped each wire to its respective counterpart. I made double sure I had all the right wires matched up when i connected the wiring harness everything was plugged in nicely. Turned it on and the rear back panel speakers didnt work but the tweeters above the back window did. I cane across a wiring diagram and it shows that the tweeters and the back panel speakers are wired sorta like a component system so thats why i dont understand why the tweeters run and not the back panel speakers. Isn't it all run off the same speaker wires initially. I can make a copy of the wiring diagram and post it when I get home from work so someone else can put some input in because I am in need of some help.
__________________
Wrecked my car.
Old 07-19-2006, 09:32 AM   #9 (permalink)
Search my friend, search.
This is definitely the #1 install problem.
Strart here:
http://www.installdr.com/InstallDocs...PDF/869017.pdf
Look at page five:
http://personal.utulsa.edu/~nathan-b...11audiosys.pdf
__________________
1994 3.0 4Runner (Original Owner) 196K
2003 Jetta GLI
Astralplane is offline
Old 07-24-2006, 01:43 PM   #10 (permalink)
Fixed it!!! Finally took the last resort of splicing into the wiring harness and ran wires straight from the harness to the rear speakers. that way the origional wires still send a signal to my tweeters but now I just have a different set running to my back panel speakers. wile i was doing that I went ahead and ran the wiring kit for my amp.
__________________
Wrecked my car.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2nd gen rear speakers s_wall98 Vehicle Audio & Home Entertainment 1 04-24-2006 01:34 AM
speakers in rear of 3rd generation BigJohn 95.5-2004 Tacomas & 96-2002 4Runners 21 02-06-2006 06:11 PM
3rd Generation rear window/wiper issue chadvb Maintenance & Repair Archives 5 11-04-2005 04:06 AM
2nd Generation Rear Recovery Points CMD93 95.5-2004 Tacomas & 96-2002 4Runners 12 05-17-2004 06:39 PM
2nd Gen rear speakers Brad 95.5-2004 Tacomas & 96-2002 4Runners 7 10-05-2002 08:06 AM
2009 InternetBrands, Inc.
