YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-03-2008, 08:21 PM   #1 (permalink)
CJM
CJM's Avatar
RCA outputs?
I have an older (and by older I mean really old, like 10+ year old) pioneer super tuner head unit in my truck. I want to hook up a small tube type sub to it and while it does have 2 plugs on the back that look like rca cables I wonder if they will work?
It has a plugs thats def labeled out and one labeled rear iirc. Are those it, they look like the kinda plugs a VCR has on back.
I am only looking to run a small bazooka tube as I have 0 room for a sub box and I aint removing the extracab panels again to put subs in there.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Sponsored Links
To remove this ad, register today!
Old 06-03-2008, 08:27 PM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
if all else fails you should just be able to cut the ends off and hook it into the left and right speaker wires
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 06-03-2008, 08:59 PM   #3 (permalink)
CJM
CJM's Avatar
Thats what I figured.
My brother works for circuit city and what should cost 350 bucks + the wires wil only be 120 bucks
__________________
CJM is offline
Old 06-03-2008, 09:04 PM   #4 (permalink)
chrishf12's Avatar
Send a message via AIM to chrishf12
if the two plugs are labled out they are the RCA outputs and yes they do look as you described.
__________________
Chris
1990 4WD 22RE Pickup 5-speed
32x11.5 Trailmark A/Ts, 15x10 Mickey Thompson Classic II wheels
Total 3 inch lift, 1.5 inch BJ Spacers, Tuff Country 3 inch Add-a-Leafs
Custom Twister Exhaust, K&N filter with airbox mod
Pioneer 6700 CD deck, Boss 300W Amp, Pioneer 6x9s in custom box
Full Size General Lee CB Radio Ashtray Mod, Wilson 2000 Trucker antenna, Bugflector II & ventshades
chrishf12 is offline
Old 06-03-2008, 09:08 PM   #5 (permalink)
CJM
CJM's Avatar
Awesome.. Now I aint gotta buy a new head unit..
__________________
CJM is offline
Old 06-03-2008, 09:32 PM   #6 (permalink)
RobD's Avatar
Quote:
Uh, no you won't. If you cut the RCA cable off of a line level output, you're barely going to hear anything, if at all. Those carry a signal that must be run through an amp. Or, with a built in crossover, a powered sub, like the Bazooka or an Infinity Basslink.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is offline
Old 06-04-2008, 04:15 AM   #7 (permalink)
Quote:
^Exactly.
Just buy an RCA cable and see if it plugs into those places. From the discription it sounds like they will.
Clemsonfan15 is offline
Old 06-04-2008, 12:26 PM   #8 (permalink)
Send a message via MSN to Greg_Canada Send a message via Yahoo to Greg_Canada
Ok, you have front and rear RCA outputs on your deck.
You want to hook up a sub.
you will need an 8 gauge wire from the battery, a remote turn on from the deck and an RCA from the deck. you also need to make sure the bazooka has a built in crossover, because the deck will be giving it a full range signal, you only want a low range signal (sub based frequency) so you MIGHT need an external crossover (if the sub doesnt have one built in).
DO NOT cut ANYTHING... unless you want to be shadetree....
__________________
http://www.cardomain.com/ride/1147271/1 My 1989 Toyota 4runner
Greg_Canada is offline
Old 06-04-2008, 06:29 PM   #9 (permalink)
CJM
CJM's Avatar
I kinda figured that all out Greg, whatever the case I am gonna get the sub and go talk to the guys who install at my brothers job to make sure I am doing it right.
The only things I am not sure of is the remote turn on and possibly the crossover-but I think the bazooka has one built in. Wiring is VERY easy, I have a aux fuse panel on the firewall I can tap with ease.
__________________
CJM is offline
Old 06-05-2008, 06:32 PM   #10 (permalink)
if the radio has rca outputs it will have a remote turn on wire. it should be solid blue or blue with a white stripe. should be labeled if not you can twist both together and run your remote wire off them. one is remote the other is power antenna so it will do no damage to have htem both hooked up if need be. the amplifier should have a built in adjustable crossover so you should be able to adjust it that way.
what is the model of the head unit and the amp and sub as well
jason
drpdmazda is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
rca cables for an amp..how long? fireteacher Vehicle Audio & Home Entertainment 45 02-11-2007 08:09 PM
Do I need 3 pre-amp outputs? Whitey13 Vehicle Audio & Home Entertainment 8 10-20-2006 12:05 PM
RCA outputs ato178028 Vehicle Audio & Home Entertainment 3 01-01-2006 04:09 PM
extra wire on RCA cable? freshman Vehicle Audio & Home Entertainment 13 11-15-2005 08:31 PM
RCA Jacks on Stock Stereo? szf2 95.5-2004 Tacomas & 96-2002 4Runners 5 01-26-2004 12:25 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
