Odd Power Antenna Issue - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-03-2006, 01:35 AM   #1 (permalink)
4x4Lamm's Avatar
I'm not sure what this is, a few broken gear teeth maybe?
When I turn my radio on, the antenna goes up but stops a few inches short of fully extended and the motor keeps running and running. If you get out and pull up a little on it the motor stops.
When you turn the radio off, the antenna cannot retract. The motor keeps running and running again though. If you give it a little nudge it will lower and stop as normal.
So what is busted? How can I replace it? I don't want to switch to a whip, I like having it down when wheeling.
Thanks for the help!
Lamm
__________________
-1992 4Runner SR5, Destroyed by fire. Lots of mods. I will miss it.
-1995 4Runner SR5 Limited, Also known as the money pit. Becoming a trail rig now.
-2004 Tacoma SR5 TRD, My new daily driver. I love this truck!
4x4Lamm is offline
Old 12-03-2006, 06:38 AM   #2 (permalink)
ac808m's Avatar
Sounds like the teeth in the retractor cable are busted. You have to pull your fender, remove the motor, crack it open and clean it out. Then feed a new cable into it. The cable is plastic and is prone to breakage. The motor should be fine. The quick fix is to remove the antenna and cable thru the antenna hole. Then feed a new cable into it. The problem with the quick fix is the bits of plastic are still inside the motor.
__________________
-Aaron
1998 Tacoma Limited XtraCab 4x4 | De-badged TRD | 3.4L Auto | Factory E-lock & Moonroof | 882 2.5" OME Lift | 17" Enkei RTS Rims | Brembo Slotted Rotors | Slee Brake Lines | K&N Filter w/Deck Plate | Custom 654 Weatherguard Box | Stubbs Sliders | LineX-ed Bed & Sliders | Kenwood KDC-MPV6022 | OmniFi | JL 250/1 Amp | JL 8" w/Hidden Box
ac808m is offline
Old 12-03-2006, 09:01 PM   #3 (permalink)
4x4Lamm's Avatar
Bummer, fender removal sounds like a chore. Maybe i can suck em out with a shop-vac and a small tube?
Lamm
__________________
4x4Lamm is offline
Old 12-03-2006, 10:08 PM   #4 (permalink)
The bad news is I doubt you can suck out the broken bits. The good news is you don't really need to remove the fender, just a few of those plastic fender liner clips. Check out the below threads...
http://www.yotatech.com/showthread.php?t=79426
http://www.yotatech.com/showthread.php?t=87721
The below is for the whip mod, but steps 1-4 set out how to get to the power antenna motor.
http://www.4runners.org/articles/whip/
In all, it should take you longer to go out and buy the replacement antenna mast than to open up the motor and fish out the broken bits.
Good Luck-
-Scubaduck
ScubaDuck is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Odd cranking issue on 1st gen.!?!? shawn 86-95 Trucks & 4Runners 4 09-06-2006 02:08 PM
Odd wiper issue Brett636 95.5-2004 Tacomas & 96-2002 4Runners 1 10-11-2004 01:42 PM
Power Antenna - Stuck Up and No Motor Sound and other Antenna Questions PhxRunner 95.5-2004 Tacomas & 96-2002 4Runners 3 06-28-2004 03:37 PM
2009 InternetBrands, Inc.
