Newly Installed Amp, Speakers Whining
I had infinity speakers in my car when I bought it, but the amp was taken out. I put an amp in yesterday and cannot get rid of a high pitched whine through the speakers only when the car is on. I also had typical alternator whine but found that be from a bad ground (it's fixed now). Here's the situation, if the cars on and running I have the whine. When I unplug the two rca's for the front speakers from the amp the whining goes away, same for when I unplug just the rear rca's. If three or more are plugged in the whining returns. Any suggestions on how to get rid of it because I haven't found any.
yeah, if you can run your power wire on one side of the car and the RCAs on the other side, then by all means do it...as having them next to each other will cause this...
That must be my problem too, for my first install i was in a hurry and just ran them together and also have a small whine anytime it is on. Not that much but at low volumes it is a little annoying.
It might be grounding issues between the HU and the amp. Some amp wiring kits have a small (18 or 16 ga?) that you run from the HU ground to and add it to the amps ground. This would eliminate a ground loop.
Try running an extra small wire from the HU's ground and add it to the amps main ground terminal.
I am virtually positive that it is because all the wires are ran together. When I redo it I am going to do it right and will see what happened.
I hope its as simple as that...Part of the problem was the screw I had didn't have a big enough head to hold the entire end of the grounding cable down, so the actually screw is only on about half of the connector at the end of the cable...maybe if I got a washer or a bigger headed screw it would fix it.
I Know whats wrong with it.
You have to ground your RCA's to the chassis.
I ahve a pioneer HU and as soon as i wrapped a wire aroung the RCA ground and tied it in to the body, all whine went away (i actually did this yesterday).
Read here,
http://www.canadiancaraudio.com/onli...ioneer-hu.html
Read here,
Read here,
Read here,
i've never heard of having to ground your RCAs to the chassis...just saying this as in my previous system, i didn't do this and was putting out some serious power and db...2300 watts rms and 160+ db!
This is actually the second time I've heard of doing this with the Pioneer head units, It's worth a shot since I have one.
Yea i grounded mine to the body, which is the same as ground to the deck chassis cause i grounded the chassis to the body as well.
I only heard about it a month or 2 ago, and i decided to give it a shot and it worked PERFECTLY... just threw some electrical tape on top so it wouldnt come off, and called it a day.
My 89' had no problems running over 1000w rms, throw the deck in the 99' and all i get is noise, so this finally fixed this.
Interesting, i have never heard of that but i will have to try it. Could be my problem as i have tried everything else except running the wires seprate.
the RCA is about the only thing that could be wrong other than the cables being run together.
